Toyota 8″ & 9.5″ 29 spline Double Drilled Pinion Flange - NEW
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by lucky, May 21, 2021.
  1. May 21, 2021 at 6:41 AM
    lucky
    lucky [OP] Well-Known Member
    NB, TX
    07 PreRunnerX4
    New, never installed. $45 to your door. Mainland US.
    Pinion Spline Count: 29
    Dual Bolt Patterns:
    60mm x 60mm
    66mm x 66mm
    Fits Differentials:
    Toyota 8″ Rear
    8” Reverse
    8” Clamshell
    Land Cruiser 9.5” - 8x/100/200 Series front or rear
    Seal Surface: 1.615″/41mm used with TOY90311-41009 Pinion seal
    Replaces Toyota OE Part number 41204-35100 & 41204-35110
  2. May 21, 2021 at 6:43 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    What's this do that a stock one doesn't?
  3. May 21, 2021 at 6:55 AM
    lucky
    NB, TX
    07 PreRunnerX4
    2 bolt patterns gives you some additional options when you start mixing/matching/swapping out driveline components. Not needed for a truck that has stock driveline and is staying that way.
    Key-Rei[QUOTED] likes this.
  4. Dec 9, 2021 at 12:55 PM
    lucky
    NB, TX
    07 PreRunnerX4
    bump
  5. Jan 16, 2022 at 2:26 PM
    lucky
    NB, TX
    07 PreRunnerX4
    ..again
