Toyota alignment after lift?
Discussion in 'Suspension' started by Fabulous, Sep 13, 2010.
  1. Sep 13, 2010 at 1:55 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    So I got my lift in, and after settling for almost a week I ended up with 2.25" in the back, and 2.1" in the front. My question is this...if I take it to my local Toyota dealer to get it aligned will it be done right? I talked to them on the phone, and all the guy could tell me is that they would do it to what is on the computer, and nothing else. I told him it was lifted, and again he said all they can do is what is on the computer. If I get Toyota to do it will the stock specs make it ride correctly? I know that 0 toe, 0 camber, and 2.4-3.1 caster is what I'm looking for, but they couldn't tell me what Toyota's setting are?! Alternatively I can take it to this smaller shop that put together my front shocks/ springs for free, and they said they will do whatever specs I give them, but they are not a high tech shop, so I have some reservations...
  2. Sep 13, 2010 at 4:39 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I took mine to toyota of Poway (in San Diego) and they did the alignment right. But I'm only at 2" in the front.
  3. Sep 13, 2010 at 11:49 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    never take my truck to toyota dealler for alignment because some of my friends work there said those guys never adjust your caster , toe or camber right unless when you take ur truck back to complain its still pull left or right . You know how long does it take ?
  4. Sep 14, 2010 at 7:17 AM
    Fabulous
    Fabian
    Calgary, AB
    I had my alignment done by Toyota back in June previous to installing my lift, and it was pretty good, but from the looks of things they did play with mostly the toe/ camber as they were off. The other shop down the street from me said what ever I want they will do it for me.
  5. Sep 14, 2010 at 7:31 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Just ask for a printout of the spec sheet and you'll be fine.
  6. Sep 14, 2010 at 9:29 AM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    Toyota dealerships are useless... take it somewhere else..
  7. Sep 14, 2010 at 9:33 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    B/S you can enter the specs if you like
  8. Sep 14, 2010 at 9:35 AM
    Fabulous
    Fabian
    Calgary, AB
    They do provide the sheet, but the problem is if they don't get enough castor done, they will charge me another $100 to do it again, and I just want to have it done once. I heard that at 2" of lift I might have a hard time getting enough castor, but that I will need at least 1.8/ 1.9 to ensure it doesn't wander. If they are lazy and only get say 1.7 then that won't do it for me, and I'll have to get it done again, which would piss me off.
