Toyota ATF TYPE T-IV for my 95
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Jun 29, 2020.
  1. Jun 29, 2020 at 5:36 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Going to do a drain/refill on my 95 auto tranny 4x4 6-cyl....Toyota ATF TYPE T-IV is what I need correct?
  2. Jun 29, 2020 at 6:04 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I thought it was spec'ed at TYPE 3, but the succeeding types will also work. So TYPE IV will work also
    vettehigh[QUOTED][OP] likes this.
  3. Jun 29, 2020 at 11:04 AM
    vettehigh
    Jon
    Upstate, NY
    So I think 10 or 12 quarts should be enough for full drain and refill.
    I can get 12 quarts of Toyota T-IV mineral transmission fluid for $85 shipped
    Mobil ATF 3309 is the same I believe
  4. Jun 29, 2020 at 11:29 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Drain and fill will only get about 4 quarts out at the most. Use the cheapest Dex III you can find, and it'll be fine. I use DEXIII in my a340 racetruck, cheapest i can get my hands on.
    cruiserguy likes this.
  5. Jun 29, 2020 at 11:31 AM
    vettehigh
    Jon
    Upstate, NY
    What about draining the hoses near the radiator too. Drain and fill a few times?
  6. Jun 29, 2020 at 11:33 AM
    cruiserguy
    Elijah
    SEKS
    And since you're messing with transmission fluid, might as well 'turkey baster' the power steering reservoir out and get some fresh fluids in there, if you haven't already.
    I think most guys here like that red/orange bottle Valvoline synthetic stuff for ATF.
    I guess if cost is really not a factor then Toyota ATF fluid is fine, of course.
  7. Jun 29, 2020 at 11:36 AM
    vettehigh
    Jon
    Upstate, NY
    I had a new OEM rack put in a few weeks ago along with fresh fluid all through:thumbsup:
    GQ7227 likes this.
  8. Jun 29, 2020 at 11:38 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Well sure that would get some more out. I just drain a fill every few oil changes because it's easy. I'm a little bit lazy sometimes.
  9. Jun 29, 2020 at 11:42 AM
    cruiserguy
    Elijah
    SEKS
    I agree with post above about a Dexron III fluid. Our old trusty auto transmissions will likely see little to no benefit from the 'upgraded' trans fluid formulas.
    Might be tough to track down some Dexron III but I'll bet you can get it cheap if you find some.
  10. Jun 29, 2020 at 11:47 AM
    cruiserguy
    Elijah
    SEKS
    That's how I did mine when I got my taco. Drained and filled like 3 times that first month and the shifting definitely improved and was noticeable.
    If you're going the drain and fill route, there isn't much benefit in doing extra disassembly or work to get an extra quarter of a quart or half of a quart out, know what I mean?(not necessarily asking you vasinvictor, just saying :D)
    vettehigh[OP] likes this.
  11. Jun 29, 2020 at 3:15 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Dex III was a name brand, it's not made anymore, however, you can find DeX III equivalent. You just have to read the label. I bought some the other day.
    cruiserguy[QUOTED] likes this.
  12. Jun 29, 2020 at 3:16 PM
    vettehigh
    Jon
    Upstate, NY
    Just going to stick with TYPE T-IV
  13. Jun 29, 2020 at 3:17 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    To the OP, careful draining all the fluid out and a transmission that has never been serviced. All the grit in the fluid is clutch material and if the clutches are really worn, it needs that grit to function.
  14. Jun 29, 2020 at 3:20 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The manual specifically calls for Dex II or III. IV is another thing entirely.
    EDIT: At least thats what I read once. I dunno, seems like there might be more of a debate about that then I thought...
    ANOTHER EDIT: Sounds like using Dex IV in a transfer case or power steering pump specced for DEX III might be bad.
  15. Jun 29, 2020 at 3:45 PM
    vettehigh
    Jon
    Upstate, NY
    I dropped the pan 2 years ago and cleaned it so well along with the magnets. I just want to drain out of the plug and refill thru dipstick
  16. Jun 29, 2020 at 3:47 PM
    vettehigh
    Jon
    Upstate, NY
    Where could I find a case of 6/12 of the Toyota II or III?
    Or either of these below?
    https://buyoil.com/mobil-mobatfdw-m...MI-oj4o46o6gIVg4vICh1BrgzUEAQYBSABEgIoy_D_BwE
    https://www.amazon.com/Valvoline-DEXRON-MERCON-Automatic-Transmission/dp/B002ZSM1RU/ref=sr_1_3?crid=2QRRED0TNHUEP&dchild=1&keywords=dex+iii+atf&qid=1593470976&s=automotive&sprefix=dex+III+%2Cautomotive%2C186&sr=1-3
    https://www.walmart.com/ip/Castrol-...MIlO24gJCo6gIVzZ6zCh3y9wW1EAQYASABEgL3NvD_BwE
    https://www.summitracing.com/parts/...MIrtvSwJCo6gIV1cDICh3QAgIhEAQYAiABEgLpofD_BwE
  17. Jun 29, 2020 at 4:21 PM
    cruiserguy
    Elijah
    SEKS
    You got me second guessing, I could easily be mistaken. This is from the Toyota auto transmission wikipedia page. But that's not necessarily the most reliable source.
    In 1998, Toyota releases the Genuine ATF Type T-IV Fluid Specification (JWS3309). This fluid was the Next Generation High-Performance ATF for Slip-Controlled Automatic Transmissions. This fluid replaces Type T-III, Type T-II and Type T fluids in all vehicles.
    I guess Toyota spec'ed our transmissions with their own Toyota fluid Type T-III, is that right?
    If so, I think Toyota Type T-IV does supercede the Type T-III, BUT I don't think an aftermarket Type T-IV necessarily meets the Toyota Type T-III spec. Hope I said that right.
    I used 12 qts of off brand Dexron III during 3 drain and fills when I bought my tacoma. That was 3 years ago. And haven't noticed any I'll effects....yet.:fingerscrossed:
    0xDEADBEEF[QUOTED] likes this.
  18. Jun 29, 2020 at 4:58 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Dexron II got replaced with Dexron III years ago
    Just read the label and make sure the fluid is suitable for systems that call for Dexron III and earlier
    Dexron IV and up are a completely different formula and should never be mixed. Do not put Dexron III in something that calls for IV and vice-versa.
    I did the same and everything is still good :thumbsup:
    Madjik_Man likes this.
  19. Jun 29, 2020 at 5:27 PM
    vettehigh
    Jon
    Upstate, NY
  20. Jun 30, 2020 at 11:55 AM
    onakat
    Canada
    2000 indestructaco!
