Toyota bad start
Discussion in 'New Members' started by Yvesthivierge, Aug 13, 2024.
  1. Aug 13, 2024 at 3:42 AM
    Yvesthivierge
    Yvesthivierge [OP] New Member
    Yves
    Good day
    I have a 2020 v6 toyota tacoma trd I am at 100,00 km starting to give me the 2 to 3 start before it start correctly in morning no code nothing in das
    buckhuntin-tacoma and HondaGM like this.
  2. Aug 13, 2024 at 10:32 AM
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    I bought a new Denso starter for $320.00 because I didn't want a remanufactured starter which costs about half $160 - $170. I have a clutch bypass switch that I use sometimes. My mechanic explained to me that the cause is the internal contacts not touching. When I 'quick-turn' the key 2 -3 times it'll crank up. I'm replacing it because I don't want to get to the point where it doesn't start at all - especially if I'm not near an incline where I can push start it. Have it checked by a mechanic to be sure.
  3. Aug 13, 2024 at 10:43 AM
    Yvesthivierge
    Yves
    Tks
    But my truck turn start on 2nd try has if nothing happen and no code in dash
    HondaGM likes this.
  4. Aug 13, 2024 at 10:49 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...
    buckhuntin-tacoma likes this.
  5. Aug 13, 2024 at 10:57 AM
    Yvesthivierge
    Yves
  6. Aug 13, 2024 at 5:08 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome aboard!
  7. Aug 13, 2024 at 5:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What happens when you turn the key?
    Does the truck crank and not start?
    Does it not crank?
    Or does it cranks, start and ide?
  8. Aug 13, 2024 at 6:41 PM
    Yvesthivierge
    Yves
    It does crank start only on the 2 or 3 try
  9. Aug 13, 2024 at 7:38 PM
    TnShooter
    Deogee
    STOCK
    So you turn the key and it cranks, but doesn’t start?
    Then you try again, cranks and doesn’t start.
    And eventually it starts?
    If so, I’d look for a crank signal. (Rpm)
    Does the tachometer move when this happens?
  10. Aug 14, 2024 at 3:13 AM
    Yvesthivierge
    Yves
    Good morning
    So what s happening exactly is first start of the day, it does
    Start on 1 and 2 time but stalled on the 3 time it start and all is good for the day it's only in the morning tks
  11. Aug 14, 2024 at 4:26 AM
    999 Well-Known Member
    Texas
    Is the battery getting low?
  12. Aug 14, 2024 at 4:33 AM
    Yvesthivierge
    Yves
    New battery
