DRL Failures, Locker Indicator Flashing, and Chasing Electrical Gremlins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Dec 11, 2019.
  1. Dec 17, 2019 at 11:37 AM
    #501
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Just had the battery and alternator tested (while installed) at Oriely’s. Everything tested good and “passed”.
  2. Dec 18, 2019 at 4:02 PM
    #502
    therealprotaco
    Gilbert, AZ
    Sent my oscilicope findings to Toyota yesterday and got a promise of a call back today before close of business (7pm CST for Toyota). Of course the guy calls as I'm on hold for a scheduled client call so I ask if I can call back in 30 minutes. He says that is fine but won't give me any direct contact info, just tells me to call the 800 number and ask for him. 30 minutes later I call the 800 number, wait on hold for a while, the CSR tries to get in touch with the guy who I'm supposed to be talking with and "he has left for the day". The CSR says he will schedule for a call back tomorrow but can't guarantee a specific time for the call. I ask if we can just schedule a call and he says he can't do that but can ask for a specific time. I have asked for 1:00pm AZ time tomorrow. We'll see if I get a call at that time or not.
  3. Dec 18, 2019 at 4:06 PM
    #503
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Yeah those all look the same to me. Did they do any testing without the truck running?
  4. Dec 18, 2019 at 4:16 PM
    #504
    therealprotaco
    Gilbert, AZ
    I do not believe so. If they did, I did not receive any readouts for those tests.
  5. Dec 18, 2019 at 4:21 PM
    #505
    0xDEADBEEF
    Hmm. I don't think a load test will rule out an alternator, since they aren't checking it for noise.
    Seems like your best bet is to keep pushing Toyota. You didn't find the root cause, but you did prove that it's not the lights making noise.
  6. Dec 18, 2019 at 4:35 PM
    #506
    therealprotaco
    Gilbert, AZ
    That’s basically where I’m at right now. My real issue is I’m coming dangerously close to the 1yr mark to send a lemon law notice.
  7. Dec 18, 2019 at 4:56 PM
    #507
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    So what happens if;
    a) you file notice, and they then fix the truck...
    b) you don't file notice and you live with things frying out... and electrical gremlins in a computerized truck...
    Theme from Jeopardy playing in background....
  8. Dec 18, 2019 at 5:10 PM
    #508
    0xDEADBEEF
    What's it take to label it a lemon? Seems like that might get Toyotas attention, possibly not in a helpful way.
  9. Dec 18, 2019 at 5:17 PM
    #509
    therealprotaco
    Gilbert, AZ
    The honest answer is I haven’t really looked into it because I don’t want them to buyback the truck, I want them to fix it. I love the truck. I don’t really dislike anything about it other than this stupid DRL.
  10. Dec 18, 2019 at 5:19 PM
    #510
    MikeyD.25
    MikeyD.25 Well-Known Member
    Why don't you swap in a different/new alternator and run the O scope test(s)? That way you'll be certain that it either is or isn't the alternator causing the spikes. If, when you swap the alternator, the results mimic the readout on the right then Toyota is on the hook for a new alternator and you possibly found the culprit blowing out your DRL's.
  11. Dec 18, 2019 at 5:22 PM
    #511
    therealprotaco
    Gilbert, AZ
    That is something I would definitely look into depending on how this all plays out. The reason I didn’t do that yet is because I first had to prove that the aftermarket parts were not causing the failure. At this point it should be Toyota’s job to diagnose what actually is.
  12. Dec 19, 2019 at 1:52 PM
    #512
    therealprotaco
    Gilbert, AZ
    Anyone want to place a bet on whether I got a call at 1pm? How about whether I have gotten a call as of now (2:51pm)?
  13. Dec 19, 2019 at 2:04 PM
    #513
    DCSBMurph
    DCSBMurph Well-Known Member
    Joe
    Maryland
    2020 Voodoo BlueTRDOR
    Stock for now
    Negative. They probably wont even call tomorrow
    therealprotaco[OP] likes this.
  14. Dec 19, 2019 at 2:44 PM
    #514
    therealprotaco
    Gilbert, AZ
    So he actually called! No good news though. Even though the scope charts are pretty clear, the dealership apparently put in the documents that the scope findings (I'm paraphrasing) "support the FTS findings that the aftermarket parts are at fault and that with aftermarket parts removed, the voltage spikes were less frequent and less intense". I guess they aren't so awesome after all but I can't blame them for catering to "the guy that signs their checks".
    I explained to the CSR supervisor that this is clearly not the case and he can see with his own eyes what the spikes look like with and without the parts and that there is little to no change. He said that he is not a tech and can't make a diagnosis. I explained that you don't need to be a tech to see the difference between the stock truck and my truck with all my aftermarket parts removed.
    He said he will follow up with the FTS tomorrow and see if they want to revise their decision. He will follow up with me tomorrow by end of day. I asked him to send me an official arbitration package in the meantime.
  15. Dec 19, 2019 at 3:37 PM
    #515
    DCSBMurph
    Joe
    Maryland
    Stock for now
    Sounds like you are headed down a very long rabbit hole. I applaud you for your persistence but there is one thing we all need to take away from this. Remove all aftermarket stuff before going to the dealer for warranty work. Once they see it and can possibly tie it to a failure it's pretty much game over or you are in it for the long long long haul. I dunno about you but my time is too valuable to spend chasing phone calls and replying to emails.
  16. Dec 19, 2019 at 4:24 PM
    #516
    aussiecrum
    aussiecrum Active Member
    Phoenix
    Still shopping for it
    OP, The new scope images look very similar but you should do a statistical analysis just to be sure. If you have similar time frames for each test done, it should be relatively simple to establish mean numbers of spikes per chart or per minute as well as standard deviations for each. It’s easy for them to say whatever until you prove there is no difference between the noise.
  17. Dec 19, 2019 at 4:34 PM
    #517
    T4RFTMFW
    T4RFTMFW Well-Known Member
    “Mod at your own risk” has never been more relevant.
  18. Dec 19, 2019 at 5:41 PM
    #518
    therealprotaco
    Gilbert, AZ
    It’s just very unfortunate that even with the data laid out in front of them, I have a feeling that I’ll end up in arbitration.
  19. Dec 19, 2019 at 6:11 PM
    #519
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Lemme know when u go to court. I'll yell shit From the peanut gallery lol.
  20. Dec 19, 2019 at 6:18 PM
    #520
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    Fuck it we should rent a bus and fill the whole courtroom with TacomaWorld members !!
