Toyota blu logic bluetooth
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cjimenRR, Jul 23, 2009.
  1. Sep 2, 2009 at 4:57 AM
    #41
    Yesterdayz
    Yesterdayz Well-Known Member
    Port Jeff Station. NY
    09 Tacoma TRD Off Road
  2. Sep 2, 2009 at 5:09 AM
    #42
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    What would be a large button and what would be a small button? Like is the fog light switch a large one or small one?
    Also, Yesterdayz I didn't see where it said XM would be a problem. I am assuming that you mean on the back of the radio where this mount connect to?
  3. Sep 2, 2009 at 5:21 AM
    #43
    Yesterdayz
    Yes, I am assuming that the radio only has one extra input, since I added the XM Mod I am out of slots. Never took the radio out to see if there was a slot for blue tooth. I Emailed the other web site, see what they say.
  4. Sep 3, 2009 at 12:26 PM
    #44
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i have to get this since i just got a careless driving ticket and my ass reamed out for being on the phone and staring the dickhead cop in the face and not getting off my phone.
  5. Sep 3, 2009 at 1:37 PM
    #45
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    ouch.
  6. Sep 3, 2009 at 2:13 PM
    #46
    dwzild
    dwzild Well-Known Member
    Metairie, LA
    2010 MGM 4x4 Sport DC LB
    Hoo-rah! Sticker, Front Bed-bolt D-rings, Bed Mat, Weathertech Floor Mats, Sirius, TACOMAWORLD Sticker, Bak-Flip F1
    From what I understand, the XM adapter plugs into the same recptacle as the iPod adapter. You can only have one of those.
  7. Sep 3, 2009 at 7:08 PM
    #47
    cjimenRR
    cjimenRR [OP] Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Can't see the difference from the links you provided. I myself am using Sirius Sat. radio via a converter that plugs into the back of the factory radio slot designed for adding a cd changer or now a days an ipod interface. Rhe way this converter works is it tricks the radio into thinking it has a cd changer plugged into the back so when I wanna listen to Sat. radio i select "cd" on my radio. This does not interfere with my bluetooth setup. If I get a chance I'll take my radio out again and take pix
  8. Sep 16, 2009 at 1:54 PM
    #48
    car15
    car15 Well-Known Member
    AZ
    09 X-Runner
    Does the wire for the microphone reach all the way up to the rearview mirror?
  9. Sep 16, 2009 at 2:12 PM
    #49
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    This is a good find. i've been using my *(&rolla unit where I have to find a good radio station to use my phone and that thing blows. Thanks for the info!
  10. Sep 19, 2009 at 5:47 PM
    #50
    car15
    AZ
    09 X-Runner
    Yes! I had to answer it myself!
  11. Oct 3, 2009 at 2:11 AM
    #51
    Westdog976
    Westdog976 Well-Known Member
    Frankie
    Las Vegas
    4x4 SR5 TRD Sport S/B D/C Magnetic Gray
    MX black upper and lower girlles, debadged, limo tints, TRD CAI, flowmaster dual side exit cat-back, DRL mod, 33x12.5 Toyo Open Country M/T, 18x9 XD Monsters, 6" stage II pro comp lift, smoked LED tails and third brake light, mag gray eyelids, 5901 viper remote start alarm, one touch window modules, 10,000k bixenon hid headlights, 3,000k hid fogs, 4x4 switch LED mod, RBP nerf bars, weathertech floor liners, muth signal mirrors, avid light bar, kenwood excelon dnx9140 nav
    Ok, I just installed an aftermarket headunit that has bluetooth built in. My stock radio was the JBL headunit with bluetooth.
    My question is: Where are the mic wires?!?!!
    I really want to use the stock mic in my truck that is built into my rear view mirror, but I don't know where the wires to the mic are.
    My aftermarket headunit takes mini jack (trs) plug for the mic, so I created a plug and just need to know what wires to splice into.
  12. Oct 3, 2009 at 5:00 AM
    #52
    rb11701
    rb11701 Oh yeah!
    Rob
    The wires run down the passenger side pillar. As for the colors of the wires I am not sure. That was one thing that I could never find in my research. Not sure how many wires are in that pillar but I you could always do a test and see approach with t-taps. Might not be the best option however.
  13. Oct 3, 2009 at 5:23 AM
    #53
    Westdog976
    Frankie
    Las Vegas
    thanks RB, but i was hoping to get the plug and pins (or wire colors) that route directly behind the stock headunit. hopefully someone knows...
  14. Oct 6, 2009 at 7:27 AM
    #54
    cjimenRR
    North Hollywood, Ca
    3 wires total; red=accy, white=mic +, black=mic -
    connector is IN1, white in color, 8pin connector, located at fuse block assembly. So remove the coin holder door, you should see the fuses and it's the top connector on the left of the fuse block. Hope this helps
  15. Oct 6, 2009 at 1:27 PM
    #55
    Westdog976
    Frankie
    Las Vegas
    sweet! i will definitely check it out later tonight after work.
    the mic only requires positive and negative, so what is the accy for?
    also, do these wires route behind the radio? i only made a plug that is about a foot long.
  16. Oct 10, 2009 at 7:57 AM
    #56
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    That din next to the AUX and A-Trac is too small for the switch he pictured.
  17. Oct 10, 2009 at 7:59 AM
    #57
    65tacodude
    Wade
    Manteno, IL
    '18 Tundra Platnium
  18. Oct 10, 2009 at 2:39 PM
    #58
    spp
    spp OC, Kalifornia
    OC California
    The one pictured is not a Tacoma overhead console. Had Blu-Logic installed when I bought my 2010 and it seems to work just fine.
    Wish the buttons were on the wheel like our 2009 Camry but at least I'm legal now.
  19. Oct 10, 2009 at 5:17 PM
    #59
    rb11701
    rb11701 Oh yeah!
    Rob
    It's not a Tacoma console, but they do have a version for the Tacoma console. IMHO, that system looks kinda crappy. It has 2 little speakers from where the sound comes from. At least the Blu-Logic goes through the stereo system. Too bad it wasn't made by Parrot.
  20. Oct 15, 2009 at 7:49 PM
    #60
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    OK..so let me get this straight....
    This bluelogic plugs into the CD port on the back of the OEM head unit?
