Toyota can't fix my truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SwampThing07, Dec 24, 2009.
  1. Dec 24, 2009 at 11:36 AM
    SwampThing07
    SwampThing07 [OP] Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    Hey guys,
    If you have paid attention to my other threads you would know that i have had problems with bad vibrations on my truck. Well it happens around 35-40mph with light acceleration and it shakes the whole truck pretty bad. It doesn't do it all the time but when it does it sux. Im not talking about the lift shudder everyone gets, its more serious than that. And when you let off the gas it goes away, meaning its in the driveline somewhere.
    Anyways Toyota of Orlando replaced my transmission mounts and that didnt fix it. So then the forman rode in my truck and said it was the driveshaft. So they replaced that. Still not fixed. They said they have "exhausted" all of there options and are not touching the truck again because i have altered the height (lifted). I said they have to prove that it's the lift causing the problem, which obviously they cannot do because they don't even know what the problem is. Anyways they said they are touching it anymore.
    Well ive dealt with this bullshit before with Florida dealers and took it by my parents in georgia and always got my problem fixed. Well im up here for the holidays and made an appt. with them on saturday. He said on the phone that it sounds like a torque converter going bad. My uncle (repair shop owner) agrees. They said they would replace it under warranty up here if thats what it is.
    Anyone else heard of this? and im pissed with the Toyota of Orlando giving up and blaming it on the lift.
    Sorry for the long post.
  2. Dec 24, 2009 at 11:40 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    never owned an auto but from what i know that sounds like it could be a logical solution
  3. Dec 24, 2009 at 11:44 AM
    Kenny650
    Kenny650 Well-Known Member
    It's obviously the lift. Many people get vibes from lifting their truck.
  4. Dec 24, 2009 at 11:46 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Add some shims to lower the driveshaft carrier bearing. It's worth trying it for the $15 it costs to buy the kit.
  5. Dec 24, 2009 at 11:46 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
  6. Dec 24, 2009 at 11:47 AM
    SwampThing07
    Orlando, Fl
    like i said before its not the lift. I have had the lift on for 3 yrs. i know what a drivline lift shudder is. The new shudder shakes the whole truck, bad. Like your going over the speed slow down lines in the road.
  7. Dec 24, 2009 at 11:54 AM
    mjp2
    NJ
    Your carrier bearing could be wearing out over time. Get a camera under the truck and record what's happening.
    Always start with the easy/cheap stuff first. Just because things didn't shudder when you first lifted doesn't mean they can't start to later on. Parts wear out and fail all the time.
  8. Dec 24, 2009 at 11:57 AM
    SwampThing07
    Orlando, Fl
    wouldnt my carrier bearing have been replaced when they replaced my driveshaft? and by the way the truck is still under warranty
  9. Dec 24, 2009 at 12:05 PM
    FLtaco4x4
    FLtaco4x4 Member
    Your a num nutz dude. You're lucky the dealer even did what they did on a lift vehicle. Prove the lift causes the shudder??? DRIVELINE ANGLES!!!!!! You probly got lift blocks with your kit and you never checked your drive line angles. I had the same issue on a lifted super Duty. Dam lift company didn't even give me the correct blocks. FYI, lifts in general are cheapie. I'm much happier with home grown lifts or not lifting at all.
  10. Dec 24, 2009 at 12:06 PM
    SwampThing07
    Orlando, Fl
    Wow thanks for your contribution. I see you just joined.
  11. Dec 24, 2009 at 12:07 PM
    SwampThing07
    Orlando, Fl
    And "num nutz" if it was my drivline angle from the block it would have started the vibrations a long time ago, seeing how the lift has been on my truck for 3 damn years. And if the angle would have fucked up my driveshaft, it would have been fixed when they replaced it.
  12. Dec 24, 2009 at 12:09 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    And that means what exactly? Time on the interwebs does not equal competence. Time under a truck means more than time at a keyboard.
  13. Dec 24, 2009 at 12:10 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    chill out...geez
    this aint the type of place to bitch the guy out like that
    regardless of what you THINK he has done...he posted asking for advice on how to fix what is occuring now
    OP
    take the truck to the other dealer or try what MJP suggested first
    once those options are exhausted and if it doesnt get fixed...then...well...i dunno...but try the options you have currently
  14. Dec 24, 2009 at 12:13 PM
    SwampThing07
    Orlando, Fl
    Thanks tigerfan- whole reason i hate posting on forums. You ask for simple advice and there is always some dick that has to add something stupid and start crap for nothing.
    Thanks for all the true advice. we will see what happens but as of right now im hearing it could be the torque converter
  15. Dec 24, 2009 at 12:14 PM
    SwampThing07
    Orlando, Fl
    Yeh and this is my 3rd tacoma and probably the 6th lift i have put on.
  16. Dec 24, 2009 at 12:14 PM
    JimBeam
    JB
    2015 Tundra
    thats not the attitude we like to promote or allow here at TW
    stick around and you'll see that theres a lot more members who are a lot nicer and a lot more willing to help around here...even if you have a stupid question :)
  17. Dec 24, 2009 at 12:20 PM
    SwampThing07
    Orlando, Fl
    Yeh thats why i like tw compared to others. but if that keeps up im done here too.
    But i will keep you guys updated with what happens saturday.
  18. Dec 24, 2009 at 12:25 PM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    driver mod
    wouldn't there be slop in the carrier bearing if it was so far gone, i say check it and if thats not the case then i think your your headed in the right direction already, my .02
  19. Dec 24, 2009 at 12:28 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Wow, that sounds serious. I hope he shapes up...
    About your problem, if the truck is engineered a certain way and you alter the angles moving parts meet, i don't think you can discount the possibity that those changes may had a negative impact to some of those components over time, regardless of you being fortunate with similar alterations in the past.
    Is the next move going with your uncles suggestion?
    Either way, hope it works out before too many more swings and misses.
    Good luck.
  20. Dec 24, 2009 at 12:29 PM
    SwampThing07
    Orlando, Fl
    i got underneath and didnt see any physical damage to it. And im pretty sure toyota would have noticed it when they put the driveshaft in right? thanks
