Toyota can't fix my truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SwampThing07, Dec 24, 2009.
  1. Dec 24, 2009 at 12:31 PM
    SwampThing07
    SwampThing07 [OP] Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    well its also the toyota in Ga's suggestion and thats what they are checking on saturday.
  2. Dec 24, 2009 at 12:40 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
  3. Dec 24, 2009 at 12:41 PM
    SwampThing07
    Orlando, Fl
    if thats true, then with all the lifted tacomas on this forum and others, how come im the only one this is happening to?
  4. Dec 24, 2009 at 12:43 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
  5. Dec 24, 2009 at 12:45 PM
    SwampThing07
    Orlando, Fl
    is that all you can do man? thanks for the help
  6. Dec 24, 2009 at 12:46 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Because as much as they are mass produced- Use, loading, environment all effect how the truck breaks in. Some folks have issues with vibes right away...some don't ever have a problem.
    My 3 inch lift didn't need shims or spacers and I have no vibrations. Down the road- Who knows what'll happen.
  7. Dec 24, 2009 at 12:48 PM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    i would try for the warranty work if thats not the fix then you simply got some new parts for free
  8. Dec 24, 2009 at 12:49 PM
    SwampThing07
    Orlando, Fl
    Yeh after this is fixed or dealt with im seriously thinking about taking off the lift and working on a beater truck for my fun.
  9. Dec 24, 2009 at 12:49 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    It seemed seasonal :p
  10. Dec 24, 2009 at 12:53 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Definitely would have been. Maybe different build tolerances between your original and the new one?
    My approach to issues like this is the address the easiest and cheapest solutions first. It's silly to drop the transmission and mess with the torque converter if there's a $10 part you can bolt in place in 10 minutes first. If the spacer fixes the issue, you just saved yourself a ton of time, money, and headaches. If it doesn't you're out $10.
    Also, I rarely trust work done by anyone but myself. Get under your truck. Is the driveshaft actually a new one? Wiggle the driveshaft and see how much play there is in that carrier.
    Most times it's something simple that's overlooked. Start with the simple stuff and make sure you're the one eliminating those as options rather than taking someone else's word for it.
  11. Dec 24, 2009 at 12:55 PM
    SwampThing07
    Orlando, Fl
    yeh only reason im doing it this way is because its under warranty and if it does turn out to be something expensive i would like that to take care of it/
  12. Dec 24, 2009 at 12:58 PM
    mjp2
    NJ
    You're not. There's a reason why Tom Woods makes money selling 1-piece driveshafts for our trucks.
    Personally, I'm running a full custom 2-piece driveshaft with a double-cardigan joint and Ford Super Duty carrier bearing.
    Toyota couldn't help me with my vibrations either. Same goes for a lot of people. Remember -- those guys only work on stock trucks with stock truck problems.
  13. Dec 24, 2009 at 1:05 PM
    mjp2
    NJ
    No kidding! I started working on my truck and it's resulted in more time on jackstands than on its tires over the past 2 years. :p
  14. Dec 24, 2009 at 1:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That was a lot of the problem with your vibrations- Toyota doesn't make jackstand vibration dampeners....
  15. Dec 24, 2009 at 1:07 PM
    #35
    mjp2
    NJ
    I'm far from stock. :eek:
  16. Dec 24, 2009 at 1:08 PM
    #36
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    my truck is lifted
    only issue ive found is the gas mileage dropped when i put bigger tires on...and welded and bolted a bunch of armor to the truck...
    i had a span where i popped a CV axle every couple of weeks but that has settled itself out where i dont have that issue anymore
    no weird vibrations or noises either
  17. Dec 24, 2009 at 1:13 PM
    #37
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    what about wheels/tires? some imbalance, tweaked wheel, or maybe a tire out of round? My truck does something similar to what you describe, but on a lesser scale.... just kinda has a little bounce from the rear at around 45mph, my last truck did it too... im thinking it may have something to do with my wheels... i've hit a couple rocks and tree stumps with em off road. :cool:
  18. Dec 24, 2009 at 1:13 PM
    #38
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Funny...Cause I've altered cars (engines, suspensions, electronics) and I've had stock cars- and I haven't had more issues with the worked on ones.
    It's a personal thing- but I have enjoyed the vehicles I've had...and made them be what I wanted.
  19. Dec 24, 2009 at 1:15 PM
    #39
    mjp2
    NJ
    THAT is a great point.
  20. Dec 24, 2009 at 1:16 PM
    #40
    SwampThing07
    Orlando, Fl
    exactly^. i didnt spend this much money on a truck to keep it stock. Obviously if im on forums i like modding my vehicle.
    Funny thing is, i found out last night that Viet2100 has vibrations like we get from the lift and he doesnt even have a lift.
