Toyota Care - apparently the techs do NOT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PhantomVirus, Dec 26, 2012.
  1. Dec 26, 2012 at 5:31 PM
    #61
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    For the actual work portion? sure. But you include getting the vehicle, bringing it in the shop, lifting it, and reverse of all that. Plus the tech has to do the paperwork for the vehicle, and go sign out the oil filter from the parts area. All takes time.
  2. Dec 26, 2012 at 5:32 PM
    #62
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I'd be careful, this Bitch is LOCO ESE!?!
  3. Dec 26, 2012 at 5:44 PM
    #63
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Meh..way it works at my dealership is there is an "inspector" that brings it in and racks it up..the inspector will take the tires off while the actual tech is handling the oil change..inspector will inspect everything in the motor compartment including checking lights and wipers.. once he gets the tires off he'll inspect underneath. When the tech is done with the oil change he will reinstall the tires while the inspector is typing everything in the electronic inspection sheet that ford calls Quailty Care Report Card.. each lube tech/ inspector team can usaully knock out 2 oil change/ tire rotation (works service) at the same time or or so using two racks next to each other
  4. Dec 26, 2012 at 5:52 PM
    #64
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Lol that also makes it a two man job.
  5. Dec 26, 2012 at 5:54 PM
    #65
    MonkeyProof
    SoCal- SGV
    Nah..inspector is hourly and the tech flags each job..;)
  6. Dec 26, 2012 at 5:54 PM
    #66
    PhantomVirus
    PhantomVirus [OP] Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    fair enough. and for the record - I appreciate your insight and point of view - chick or not :p
    Everything adds up. My issue was more that they left parts in the engine compartment than the time.
  7. Dec 26, 2012 at 5:54 PM
    #67
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I got a 3 or 4' section of 5/16" ID fuel line and permantly installed with a hose clamp. It's routed through a hole in the skid plate and tucked above when not in use. The end gets capped off after it's done draining... never had one drop on the driveway. I use 2 oil change pans... one under the drain plug and one under the filter drain hose.
  8. Dec 26, 2012 at 5:54 PM
    #68
    jandrews
    '09 FourDubDee TRD OR
    I was looking for that 5 gallon/30 dollar deal.
  9. Dec 26, 2012 at 5:59 PM
    #69
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    pretty sure?
  10. Dec 26, 2012 at 6:11 PM
    #70
    PhantomVirus
    Ron
    Don't care - chick, dude, trannie whatever.
    Good insight no matter the gender or the bender.
    I did miss the point on the timing of all the things that need to come together to get a car in / done & out.
  11. Dec 26, 2012 at 6:16 PM
    #71
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    My genatalia matters not, for I am sexy regardless.
    joeyv141 likes this.
  12. Dec 26, 2012 at 6:21 PM
    #72
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    The hormone therapy has done me wonders.
  13. Dec 26, 2012 at 6:29 PM
    #73
    netman1969
    netman1969 Meh!
    Dave
    Cookeville, TN
    Awaiting my 2024 Tacoma OR, Underground
    None yet, but sure to come!
    They haven't tried to pin it on me yet, but I am definitely prepared for that. I am guessing there is a checklist or shop materials list of some sort that the service tech had to complete at the 5000 mile. Thats proof that he cracked the cap on the brake fluid. On the other hand, there is no way they could prove that I did, even if I had. Which I didn't. :)
  14. Dec 26, 2012 at 10:09 PM
    #74
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    lol this thread is dumb. big deal, the guy made a mistake...
  15. Dec 12, 2019 at 6:24 PM
    #75
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    If it makes you feel better I am on my third one so far, found the light with one battery on Amazon for about $120 when i lost my second one. Hopefully it'll be my last one but I seriously doubt it.
  16. Dec 12, 2019 at 6:31 PM
    #76
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    He’s probably over it after 9 years haha but maybe it will make him feel better. Good on you! :D
  17. Dec 12, 2019 at 6:40 PM
    #77
    joeyv141
    New Jersey
    Didn't notice date, this thread was mentioned in another so I had some fun reading it. If he's like most he's lost a few more tools in random cars over those years.
    BuzzardsGottaEat likes this.
