Toyota Care "less" Servicing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTruckinTX, Aug 12, 2015.
  1. Aug 12, 2015 at 10:38 PM
    TacoTruckinTX
    TacoTruckinTX [OP] Member
    TJ
    Port Arthur, TX
    2015 dbl cab long bed V6 4.0L 4x4
    Bug guard, need bars, Snugtop camper shell, Yakima integrated rack.
    So I'm taking my Taco in for first oil change under new owner two yr care package on monday. Heard rumors of not trusting the service from the dealer. Is it that bad or should I find the time to do it myself? Any experience good or bad you can share?
    Part of me says go buy Mobil 1 and just switch to full synthetic. I have 2015 v6 4x4.
  2. Aug 12, 2015 at 10:42 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Well you already paid for toyota to take care of it. But it's a hell of a lot quicker to do it yourself. Takes them at least an hour not including the trip to and from dealership, takes me less than 20 mins including the trip to the store for oil and filter
  3. Aug 12, 2015 at 10:43 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Just talk to the people at the dealer. I had a year with mine and I would bring in my oil and they would change it. So I got labor and filter and the other checks for free just the cost of the oil I wanted. And I bought mine used. Never hurts to ask.
    I went mobil1 from the first change.
  4. Aug 12, 2015 at 10:47 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Its the Internet. Every dealership is ran by idiots who hire only bottom of the barrel doughnut shop flunkies to install new motors and frame swap.
    I would do a free oil change at the dealer first and see if they mess something up. If they do, you should be covered. If they don't, no harm done.
    My dealership is great. If they weren't a 30 minute drive, they'd do all of my work.
  5. Aug 13, 2015 at 4:40 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Just remember to open the hood and check everything before you drive away when they are finished. Look for tools left behind and make sure they returned your dipstick. And most importantly ....make sure there is oil in your engine.
  6. Aug 13, 2015 at 4:54 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    My service department seemed pretty decent. Once they over inflated the tires which wasnt that big a deal ( 39 when they should be at 29). Another time had a slight scratch on my hood from them ( though I couldnt actually prove it).
    The biggest disadvantage is the time like another poster said. I would usually drop my truck off in the AM and pickup in the PM. Service place is 15 minutes from my house. Just had my last free oil change so Ill start doing them on my own again.
  7. Aug 13, 2015 at 5:05 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Can't tell you if they are good or not - but I never brought mine back to the dealership for service since new
  8. Aug 13, 2015 at 5:20 AM
    Pigpen
    Dan
    Northwest Montana
    Whether you choose to use them or not, grease your u joints now that it's time for service. That's not part of Toyotacare - so dumb. I let them do it for the two years without any known problems. I also paid for the 30k service (did my own plugs though), which still doesn't include greasing u joints. The tech overtightened my trans fill plug (man trans) to the point that it caused problems at the 60k service. I ended up paying for another trans service plus shop time for them to fix their eff up. The service manager said there was no way to prove it was his guy who did it. I also took it in for an alignment after my lift. They wouldn't try for the numbers I wanted (0 toe, 0 camber), just made sure it was "in spec". I drove away with the truck feeling worse than when I brought it in. They lost my business. I do my own services and take the truck to an independent mechanic for the things I can't do.
  9. Aug 13, 2015 at 5:22 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Every dealer is different, most people wont post if they never have a problem but if they do they are more likely to post about it which is why you read those stories and not good ones. Running semi synthetic and switching later wont hurt anything. I would just run the dealer stuff since you paid for it and then switch to synthetic when your Toyota care is done, that's my plan. I bought my 11 used and switched to mobil 1 at 30k no problems and my 08 I switched at 60k no problems.
  10. Aug 13, 2015 at 5:26 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I will use them until the free shit is done if I keep it that long. But I mark my rims on the inside, and mark the oil filter to ensure they actually did something. And I use a dye to put a spot on the air filter as well. And before I pull away I check it all, and remove the dip stick to check the oil.
    ODNAREM likes this.
  11. Aug 13, 2015 at 5:32 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I used it when it was free. DIY now that I'm paying out of pocket. If you want to verify the job - just check the dipstick before you get in the truck.
  12. Aug 13, 2015 at 6:23 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Mobil one and do it yourself.
  13. Aug 13, 2015 at 7:45 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you are already questioning it.... dont even bother.
    Grab a 5qt jug of your favorite oil, grab a 10 pack of oem filters on ebay for 45 bucks and do the oil changes yourself.
    Drain the oil and while your waiting for it to drain grease the driveline (something that the dealer WILL NOT do).
    The whole process will be less time than the drive time to get to the dealer.
    OH btw.... first hand experience with them almost starting my truck with no oil in it.... just saying.
  14. Aug 13, 2015 at 9:16 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    I'm not a flunkie! I choose not to go to school
  15. Aug 13, 2015 at 10:44 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    that is what I did. I figured I paid for it and if anything went engine wise under warranty then they had the oil change records. Now that said my dealer is a simple exit off the IH one light and an on ramp right after. Depending on traffic at the light it might be 2 - 3 minutes diff on the way home from work. Not including the time I spend there of course. I would have spent time at Discount for tire rotations anyway. Now that I am paying for oil changes I do them myself.
  16. Aug 13, 2015 at 10:54 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Regarding the oil changes, one poster mentioned they took in their own synthetic and had the dealer use that oil....I would never do that, how can you trust them to actually use the oil you brought in? Dealers are screwy enough already, unless I was watching them change the oil personally, I would never trust them to use what I brought in....
    Just a thought....
    Lester Lugnut likes this.
  17. Aug 13, 2015 at 12:14 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Take advantage of it for the time being.If they make any mistakes it's on them.Your Tacoma is under warranty.Then you can do your own service after the complimentary 2yr service has expired.Good luck!
  18. Aug 13, 2015 at 1:27 PM
    TacomaMike37
    13' DCLB MGM
    If you are that close then I would definitely use the dealer. Just mark the tires and oil filter, double check the oil before you leave and you are good to go.
    TacoTruckinTX[OP] likes this.
  19. Aug 13, 2015 at 5:20 PM
    TacoTruckinTX
    TJ
    Port Arthur, TX
    Thanks for all the words of wisdom. Long live our Tacos!
  20. Aug 13, 2015 at 5:41 PM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    I've never had any issues with my dealership for "Toyota care" service appointments, other than stupidly long wait times.
