Toyota care plus question Y/N
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Do58, Aug 4, 2016.
  1. Aug 4, 2016 at 1:04 PM
    Do58
    Do58 [OP] Well-Known Member
    2015 white tacoma limited
    i have a 2015 tacoma and I just hit 20k. I have been getting free oil changes & basic maint. until 25k with my toyota care. So I received an email stating that toyota care is about to be up BUT I can spend $179 and receive
    Up to 4 additional services
    2 years of 24 hr roadside
    Service reminders
    The services are
    Oil and filter replace
    Rotate tires
    Multi-point vehicle inspection
    Inspect and adjust all fluid levels
    So my question is how much are the parts (filter and oil) if I was to do the changes myself? Like I had mentioned, I haven't had to do anything. (Took advantage of original offer). I know that this is how the dealer makes their money but I have to say that I have a really good dealership. I know that most would say they prefer to do their own so they know it's done their way (the right way), but I was thinking for the inspection rotate and oil MAYBE it's worth it. Thoughts?
  2. Aug 4, 2016 at 1:58 PM
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    A vague estimate is about $30 worth of oil at each change for the V6, the filter is about $5 and replacing the drain plug gasket is about $1 each.
    To each their own and I'm not much of a mechanic, but changing the oil on the Tacoma is a pretty easy task. I also get my tires rotated at Costco for free so I don't have to take that into consideration when doing my own maintenance.
  3. Aug 4, 2016 at 2:09 PM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Honesty, it's up to you. Less than $50 a pop for oil changes ins't that bad, particularly if you don't have the time, inclination, space, tools or know-how to do it yourself. The dealer isn't raping you at that price. The roadside assistance and other stuff is a bonus. Keep in mind that their end game is is to get you back in there so they can upsell you on a big 30K mile service , 45K mile service, 60K mile service, etc. And brakes, and throttle body cleanings, and tranny flushes, and all sorts of other questionable things that they make money on.
  4. Aug 4, 2016 at 4:25 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    U can DYI with synthetic and filter for about $30 - U don't say but U are probably getting regular oil at the dealer for $45 - not much diff in $$ but synthetic is the way to go if U R keeping the truck.
  5. Aug 4, 2016 at 4:31 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    local dealer has a 3 oil change with tire rotations package for $75, see if they or another dealer has something like that maybe :notsure:
  6. Aug 4, 2016 at 6:16 PM
    hollandhunter
    hollandhunter Well-Known Member
    2015 Tacoma DCSB sr5 4x4
    I wont let anyone maintenance my truck but myself. For personal reason. I have the toyota car right now but i dont use it. They can keep it. I let them do the first 2 and was not impressed. An went right back behind them and had to check everything that was touched. But if you dont like doing it go for it. Not alot of difference in price. Cheaper if you do it yourself though as well.
  7. Aug 4, 2016 at 6:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have the Toyota Care too and still do my own maintenance instead of letting them mess with it.
  8. Aug 4, 2016 at 9:09 PM
    Pigpen
    Dan
    Northwest Montana
    FYI Toyota care does not include greasing your drive shafts. Use that knowledge however you chose.
    TRDSport10 and shakerhood like this.
  9. Aug 5, 2016 at 8:00 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    And if it was included it more than likely wouldn't get done.
    Lester Lugnut likes this.
