Toyota case managers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomasr1950, Aug 12, 2009.
  1. Aug 12, 2009 at 7:27 PM
    thomasr1950
    thomasr1950 [OP] 19 Tacoma TRD Off Road
    central us
    Has anyone had any dealings with a case manager? I've had a vibration with my truck since i bought it. The selling dealer has done a wheel balance, then a rotation& road force balance, i still have an issue. Now the dealer said they used the wrong adapter. I'm unable to call the dealer due to my work schedule, i tried to set up an appt. on a Sat. but they won't check it out on Sat. I received a voice mail from them telling me about the adapter, bring it back a 3rd time. I don't want to go back to this dealer, it's an hours drive, time & gas on my part & the scheduling issue. I contacted Toyota & had a case mgr. involved, their saying i have to take it back to the dealer that did the work. If i take it to another Toyota dealer i may have to pay a diagnostic fee. I told them i shouldn't have to pay anything. Their customer relations manager doesn't return calls, Toyota says there is nothing they can/will do. I'm dissapointed in the service after the sale. The dealer & Toyota are both about to loose a customer. I love my truck but i want service after the sale & Toyota to back me up. What do other Tacoma owner suggest i do? I'm about ready to pay for a road balance out of my pocket but if it's a tire/wheel issue then Toyota won't back me up since a Toyota dealer didn't do the work
  2. Aug 12, 2009 at 8:34 PM
    JKD
    JKD Well-Known Member
    Check your state's lemon law very carefully. They usually have provisions for both "time out of service" (time that it spends in the service department instead of in your posession) and for repeat attempts to repair the same problem.
  3. Aug 12, 2009 at 8:41 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    x1
  4. Aug 12, 2009 at 8:45 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Definitely! X2!
  5. Aug 12, 2009 at 8:47 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you have a Discount Tire (or it's other names, america's tire ect), talk to the store manager and they'll do the road force test on the tires. If it's determined they're out of spec (like mine were), they won't charge for it, and you'll get a credit on your rubbers toward some new tread. Once I swapped out for the BFG AT KO's, most of the issues went away, as much as can be expected with an AT tire at least.
  6. Aug 12, 2009 at 10:55 PM
    TacoOwner?
    TacoOwner? Well-Known Member
    Joshua
    Camas/Spokane, WA
    '10 4x4 Double Cab 6M
    Anti-thief tailgate, anytime rear-view camera, anytime locker mod
    Yes. Let us know what happens?
  7. Aug 13, 2009 at 2:55 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    If it is a tire issue then check into having them replaced under the tire manufacturers warranty. Take it to any reputable tire company that sells that brand and they will know who the warranty works and get it straightened out for you.
    Tire warranty is seperate than your truck warranty, check your paperwork from the dealer and there should be a pamplet specific to the tires. If you don't have the paperwork then check the manufacturers website, it will have their warranty info.
    http://www.bfgoodrichtires.com/bfg/tireWarranty.do
    http://www.dunloptires.com/dunlop/warranty.pdf
    If its not the tires then good luck at the dealer and you will probably have to go along with what the Toyota people say unless it falls under the lemon law in your state.
  8. Aug 13, 2009 at 6:33 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    I have been going down this path for 3 months. I am finally to the point where Toyota is putting tires of my choice on the truck.
  9. Aug 13, 2009 at 6:49 AM
    thomasr1950
    central us
    How were you able to get Toyota to replace your tires? You must have a better case mgr. than me, they won't budge at all, even after i tell them they are loosing a customer. They insist i go back to the selling/servicing dealer a 3rd time. They didn't fix the issue the 1st two times, now it maybe out of pocket expense for me to get the issue fixed. I am going to try Firestone & see if they will check the tires.
  10. Aug 13, 2009 at 7:11 AM
    dalsmthme
    Ithaca, NY
    The case manager is worthless. They have been no help. I have been working with the dealer even though they are clearly unable to do there job. Long story short. I had the wheel vibe. Took it in, they told me nothing was wrong. Took it to Goodyear for tire warrentee, they told me the wheels were bent. Took it back to Toyota, they had it 4 days and diagnosed it as drivline and performed the spring TSB because they said it had axel wrap. That caused a nasty driveline vibe that they thought was a drive shaft. They put a new drive shaft in and that didn't fix it. They put the old springs back in which put me back to square one and Toyota refused to work on it further. I then took it to an independent place that has a roadforce balancer and spent my own $70. They had to rotate a couple tires to even get them to balance. That helped a lot but there was still a shake there. Took it back to Toyota and had to argue them to death before they finally agreed to put tires of my choice on the truck. This was after Toyota told the dealer not to work on the truck any more. A ride with the service manager changed his mind.
    Bottom line, you have to battle this your self. Case managers don't work for you, they work for Toyota. You need to plead your case with the dealer and push that a vibration isn't normal like to tell you it is. I was told point blank by the service manager that Toyota doesn't care is the customer is happy, it is about money and who is going to pay. The dealer won't do anything that Toyota tells them they won't pay for. Toyota wants to be convinced with data and customer satisfaction is not a data point.
    Go in there, stay calm. Ask the service manager to go for a ride. As long as the truck vibrates, he should fix it. Have them pull a set of wheels off of a truck on the lot and take it for a drive. Make sure you ask to drive it to. That way they can't tell you they tried it when they didn't. If he arguse with you, ask him if he would make payments on a truck that vibrated. I bet you his attitude will change. The dealer also sells tires, so they can warentee tires from the manufacturer.
