Toyota coolant..and converting
Discussion in 'Technical Chat' started by ABA180, Apr 16, 2013.
  1. Apr 16, 2013 at 6:39 AM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Kenwood CD, MTX/Jensen amps, Rockford/Polk speakers.
    I know that you aren't supposed to mix the usual green coolant with the Toyota coolant..don't worry, I didn't!
    This came up recently..GM had the Dexcool (AKA Deathcool) and some people were flushing it entirely and converting to the green, due to issues with the Dexcool.
    Is it possible to do the same with Toyota's red stuff? And have there been issues with the Toyota stuff that would cause a change to be beneficial?
    Discuss.
  2. Apr 16, 2013 at 6:46 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser
    Stuff
    IIRC the Toyota red is fine. The Toyota pink is what's causing problems.
    Don't quote me on that though
  3. Apr 16, 2013 at 6:52 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    What problems? I haven't heard anything about any tacoma coolant issues:confused:
  4. Apr 16, 2013 at 6:56 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    07 FJ Cruiser
    Stuff
    I've heard of the pink (giggitty) messing up the water pump, at least on first gens.
  5. Apr 16, 2013 at 9:18 AM
    ABA180
    East Bridgewater MA
    Either the red or the pink, how would one convert over?
  6. Apr 16, 2013 at 9:47 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    07 FJ Cruiser
    Stuff
    Flush system thoroughly and fill with desired coolant
  7. Apr 16, 2013 at 9:58 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I flushed the Toyota red coolant after 3 years on my 09. Moved to Prestone, cheaper, easier to find, and I usually flush the coolant every 2-3 years anyway.
  8. Apr 16, 2013 at 1:10 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Years ago, on an earlier '84 Toyota, I converted from green to red Toyota OEM coolant. Immediately, I had leaks where I didn't have them before. Not severe leaks, but constant, slow, oozing leaks of the red stuff. Nothing dripped to the ground.
    At the next coolant change, I went back to good ol' Prestone, and no more leaks.
    YMMV
  9. Apr 16, 2013 at 8:46 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Pre 2004 is Toyota long life(red) 2004+ Toyota super long life(pink). You can drain and flush all pink coolant out and fill with what ever you want. However if you overheat your engine or any other cooling related problems you will be on your own for repairs. I have seen where other shops have flushed with the wrong coolant with no issues to the vehicle at the next flush.
  10. Apr 18, 2013 at 7:42 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Is Toyota red (the non premixed stuff) compatible with the pink in 2005+ taco's?
  11. Apr 18, 2013 at 7:47 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    if the convert back hadn't fixed the leaks I would have said that maybe you knocked some 'clotting' loose that were stopping oozing leaks with the first flush.
    I had people tell me years ago with old trucks "Whatever you do, don't flush the coolent unless it's shit brown, the sediment closes up leaks for you and a flush will cause leaks" :eek:
  12. Apr 18, 2013 at 7:51 PM
    Ryanv
    15 4Runner
    Acording to a 2002 tsb it is safe to mix. Personally I would not, if I had to use long life is would flush and fill with long life
  13. Apr 19, 2013 at 5:27 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It is difficult to get all of the red/pink coolant out of the system. There will still be some residual left in the radiator, heater core, and engine. You would have to flush the system well, with the thermostat removed, and pull the heater core lines to flush them independantly.
    If you don't get the old stuff out, and convert to green, it will react and turn to a gel. I don't recommend using anything other than the factory coolant. You are risking much for very little reward.
