Toyota Credit Given
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PSJ, Aug 2, 2011.
  1. Aug 2, 2011 at 7:51 PM
    PSJ
    PSJ [OP] Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I did the gas pedal recall solely to get the free mats since I had a crack in mat of the driver"s side of the all weathers that came with the truck, which was allowing water, etc to seep thru to the carpet. Well, for those who have done this, you know the replacement mats are not "all weather" compared to the design of the original mats. So, I was having troubles getting the work done, which turned out to be a "computer issue", but wondering why the dealer had not called me to schedule the fix, I contacted Toyota. In the conversation I mentioned the original mats were valued at $200, and were a better product then the mats that replaced them. The rep then offered me a $100.00 credit due to the fact I was not happy with the replacement mats. Just as a FYI...
    So, what do I buy with the $100.00 credit? I have to go to a dealer to buy anything. So, I was thinking of buying the parts needed for the rear diff breather mod, which leaves me about 80 bucks or so. What else can I get with my limited budget?
    Any suggestions greatly appreciated...
  2. Aug 2, 2011 at 7:55 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I'd get a tow package if you don't have it.
  3. Aug 2, 2011 at 7:57 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    bed mat?
  4. Aug 2, 2011 at 8:06 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, Sickspeed shift knob, mud flap delete, white lithium grease mod for creaky clutch pedal
    You got replacement mats?
  5. Aug 2, 2011 at 8:18 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights
    Soooo, your original all-weather mats cost more than a front set of Weathertech floorliners?
  6. Aug 2, 2011 at 8:30 PM
    PSJ
    Sebastian Inlet
    Installed
    Have one
    Yes
    Window sticker value- but even at cost they are more expensive. Does not sound normal for a Factory part?
  7. Aug 2, 2011 at 8:31 PM
    TACK
    Nevada
    I didn't get any replacement mats. WTF.
  8. Aug 2, 2011 at 8:38 PM
    PSJ
    Sebastian Inlet
    They are not bad for free, but they are flat compared to a the original with a "catch all" built in. I just saw they have re designed them to be more like a all weather mat design like the originals or aftermarket products.
  9. Aug 2, 2011 at 8:42 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    plan on installing any aftermarket lights..or anything that needs a switch...?
  10. Aug 2, 2011 at 8:47 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    oem spark plugs and wire set ..... plus whatever ya can get for your truck...lol.....
  11. Aug 2, 2011 at 8:51 PM
    robgeetar
    robgeetar Unofficial member of the Rebel Alliance
    Robert
    Whittier, CA
    09 4cyl base
    Not much at all: Antenna X Eurostyle 13", plastidipped retro wheels, and retro decals
    x2 :mad:
  12. Aug 2, 2011 at 9:02 PM
    PSJ
    Sebastian Inlet
    That's on my list- I but what they want for a oem switch 35-40 bucks? I saw some scion switches with illumination and that fit our holes for around 13 bucks online
  13. Aug 2, 2011 at 9:03 PM
    Maverick904
    Kameron
    Northeast Florida
    yeah..just a heads up..they need minor trimming..but they work.
  14. Aug 2, 2011 at 9:32 PM
    PSJ
    Sebastian Inlet
    Looks like you may know the Indian River Lagoon...:D
  15. Aug 2, 2011 at 9:33 PM
    Maverick904
    Kameron
    Northeast Florida
    i do i do...have yet to fish it tho.
  16. Aug 2, 2011 at 9:45 PM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    I've taken both my company's tacomas into the dealership for this recall and haven't received any replacement mats... as previously stated
    WTF!?
  17. Aug 3, 2011 at 8:29 AM
    PSJ
    Sebastian Inlet
    I do not have the recall letter in front of me, but maybe they only replaced the All Weather Mats in the recall if you had them. If my mat did not have a crack in it, I would not have let them replace them, because the originals had a lip to keep water, mud etc. contained, and the new ones are heavy duty rubber, but flat and no lip. Designed that way to give more clearance between the gas pedal and mat I am sure. Maybe check the letter to see. I do remember the letter stating replacing the mats though? :confused:
  18. Aug 3, 2011 at 8:34 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Get a couple oil filters, air filter, cabin air filters and maybe some oil? Not cheap through the dealership, but if you gotta spend the cash at the dealership, at least it's stuff you know you'll use.
  19. Aug 3, 2011 at 9:12 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    X2 but not the oil,,,,, Mob.1 at wolly world... Jim
  20. Aug 3, 2011 at 9:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I would score the adjustable intermittent wiper stalk if you don't already have it. PM sent about replacement original all weather mats.
