Toyota Customer Experience Center
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muddog321, Apr 20, 2018.
  1. Apr 20, 2018 at 2:42 PM
    muddog321
    muddog321 [OP] Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    For all of you Toyota owners that have had problems that should have been reimbursed here is the Toyota address. Of course you will get a runaround and probably never get paid but as I get older I like to let them know what their defects are and what I think of the lack of dealer help with their know defects.
    Toyota Customer Experience Center - TRR
    Toyota Motor Sales USA Inc
    PO Box 259001 - Reimbursement Center Request
    Plano, Texas 75025-9001
    They will want detailed written receipts from a dealer of:
    Reason brought in
    Repair facility diagnoses
    Repair performed with part #s
    Proof of payment which must be a signed credit card slip, cancelled check, or credit card statement (paid on the facility receipt does NOT count).
    Good Luck to all - I struck out as usual but gave it a try to confirm that my 2009 Tacoma will be my last Toyota.
  2. Apr 20, 2018 at 2:52 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    What didn’t they cover?
  3. Apr 20, 2018 at 3:18 PM
    muddog321
    FL
    Rear springs when new were 3 leaf and dealer put in 4 as was bottoming out and when towing they again sagged down to stops so I had to put in OME to correct even as a recall was in place and they had none available - oh except for the new Tacoma's that have the same crap ones. Also my driveshaft was a loose mess clunking around and the dealer had no cure so I bought a Tom Woods and solved that one. I did not ask for reimbursement on the rest that was the rear diff was trashed at 100k so a complete rebuild (not by dealer as they would not even test without the original driveshaft). Both rear wheel bearings at the same time and both front wheel bearings too. Headlights melted due to daytime running lights so I replaced. Now have that front vibration due to drivers side front diff roller bearing.
  4. Apr 20, 2018 at 3:32 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    fast5speed[QUOTED] likes this.
  5. Apr 20, 2018 at 5:23 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I've had headlights, u joints and rear springs all replaced on Toyota's dime.
    I got no complaints
