Toyota dealership for alignment after OME install questions
Discussion in 'Suspension' started by MNmtb, Nov 17, 2016.
  1. Nov 17, 2016 at 6:29 AM
    MNmtb
    MNmtb [OP] Well-Known Member
    Jeff
    2015 Tacoma Lifted
    So i purchased my 2015 DCSB Sport from the toyota dealership and im installing an OME kit with Dakars and TC UCA's. When i bought the car, the dealership also gives me several free service items, one of which is a free alignment. So here are my two questions:
    1st Question - should i go to the Toyota dealership and take advantage of this. I know all dealerships are very different (Michaels in Bellevue, WA is where i purchased). I'm afraid that they will say that is just a basic alignment and what I want after the install is not included. Or should I just go to a dedicated shop.
    2nd Question - regardless of where I go for an alignment, I'm looking for some guidance on numbers I should spec. Its a 2015 DCSB Tacoma Sport. It has Duratrack LT 285/70/17's. Is mostly a DD but most weekends i head out onto dirt road for fishing, camping and prob head out and do some proper off-road activities several times a year. I'd prefer it not wander on the highway over best off-road characteristics.
    Given this what would you all consider proper numbers for
    Caster L/R
    Camber L/R
    Toe
    Thanks for everyone's help
  2. Nov 17, 2016 at 6:45 AM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    Go to the dealership and see what they will do for you - worth a shot. If not make sure you go to someone who knows how to adjust uca.
    Pretty much: Camber and toe to 0. Caster high as you can get it. Generally you should be able to get at least 2.. I guessing you have at least 3 due to the fact you are running dakars.
    I've been fortunate enough where I am able to use the stock UCA with little to no wandering. Not in any rush to get UCAs, but will eventually get some TC.
  3. Nov 17, 2016 at 7:12 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    What lift do you have?
  4. Nov 17, 2016 at 7:18 AM
    MNmtb
    Jeff
    2015 Tacoma Lifted
    Should end up with about 2.5 inches. Nitrocharger shocks, 885 springs, Dakars KIt is OMETAC05HKS. I don't have and ARB or other weight in the front so should give a little more than 2" if bumper isn't installed.
  5. Nov 17, 2016 at 7:28 AM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I would try the dealer first. I wouldn't be suprised if you have to go down the street though. I went to a guy who ONLY does alignment and owns a brand new Hunter machine. it's a dice roll either way.
