Toyota Dealership Negligence
Discussion in '2nd Gen. Tacomas (2005-2015)' started by POWHANA, May 17, 2013.
  1. May 17, 2013 at 6:32 AM
    POWHANA
    POWHANA [OP] Well-Known Member
    Lake Tahoe
    2012 Tacoma TRD Off-Road
    So there I was...I had just gotten my machine back from the 15,000 mile service. I usually have Les Schwab rotate my tires but I had the dealership do it this time. I drove 60 mph on highway, then was driving about 20 mph when I heard a metallic grinding after a small bump in road...felt like the rear driveshaft was disintegrating. I immediately stopped and found my rear left wheel had come off and the rear drum was just barely sitting on the edge of the wheel. Chewed the service manager out...they are fixing it. It had appeared that the bolts had been sheared off but after squeezing the drum/wheel together the lugs seemed to push further through the drum. So mechanic dude either left em off or didn't put em back on all the way.
    So I'm glad I didn't die on the highway. What are the thoughts of how much damage had been done? the lugs, wheel, and drum were pretty messed up, they are replacing. Any suggestions/thoughts of other extensive damage that could have been done to my drive train? :eek::mad::mad:
  2. May 17, 2013 at 6:51 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    IDK, the only other things that I would think of possibly replacing are the bearings and seals in the rear end, but I'm not sure those would even have been under any extra load when wheel came loose.
    Complete rear end? New truck?
  3. May 17, 2013 at 7:01 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    I always check everytime I got my vehicle back from the service at the stealership. I don't trust them. I heard of horror stories about their negligences...sorry that's happen to you ? I assume they refixed without charge,right ?
  4. May 17, 2013 at 7:09 AM
    POWHANA
    Lake Tahoe
    Yeah man I hear you...I will. Every time now. Yes they have given me a loaner Taco and are fixing the problem and are super apologetic. The tow truck driver dented the bottom of the body when two of em were trying to figure out how to tow my machine back to the dealership. So that has to be fixed as well. Bummer. I'm just wondering if there is any possible damage to the drivetrain
  5. May 17, 2013 at 7:12 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    at least they owned up to it and are making it right
    it does not excuse them from what they have done
    be thankful it could have been much much worse
  6. May 17, 2013 at 7:17 AM
    POWHANA
    Lake Tahoe
    I am super thankful no one was hurt, could have been real bad.
  7. May 17, 2013 at 7:24 AM
    97Blk_one
    Memfrica
    not so low
    Yeah, that would not be good.
    True that.
  8. May 17, 2013 at 7:31 AM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Holy Crap! That's scary. I know I should always check everything, but truthfully I usually don't. That is inexcusable.
  9. May 17, 2013 at 7:33 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    I would in a polite manner reiterate to the service manager how dangerous this situation could have ended due to a technicians lack of concentration/poor workmanship. I would use that to have them compensate me for my time, inconvenience, and scaring the baby Jesus out of me. Maybe have them comp you the 30k service since that will be the 1st service you pay out of pocket and also an expensive one
  10. May 17, 2013 at 7:35 AM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    I can guarantee that tech no longer has a job..
    I hate to hear things like this. I always do my maitenance, but I got that 2 year Toyota Care thing that comes with new vehicles. Free everything for two years.
  11. May 17, 2013 at 7:37 AM
    cjimenRR
    North Hollywood, Ca
    Not everything is free, only what you see in your scheduled maintenance book
  12. May 17, 2013 at 7:37 AM
    POWHANA
    Lake Tahoe
    I will. Good Idea about the 30,000. yeah, I think my wife is even more pissed than I. Were going down there this morning.
  13. May 17, 2013 at 7:40 AM
    POWHANA
    Lake Tahoe
    Right. They got me for an air filter, fuel filter already. And I pay extra for the synthetic, hopefully I'm gettin synthetic
  14. May 17, 2013 at 7:44 AM
    thunderbases
    thunderbases Well-Known Member
    Alabama
    15,TRD Off Road
    That is totally jacked up. Make sure they fix anything else that may have been damaged. Once you drive it off, they will say that they are not responsible for any further damage.
  15. May 17, 2013 at 7:46 AM
    cjimenRR
    North Hollywood, Ca
    A fuel filter?!?!?!?! The filter is not serviceable, there's no reason they should have even changed it at 15k! Also I'd love to see the part number for this so called fuel filter since its really only a strainer and can only be purchased with the fuel pump
  16. May 17, 2013 at 7:49 AM
    scottg918514
    scottg918514 Well-Known Member
    2013 DC, TRD 6-spd Manual, 4wd
    Another reason I do the work myself.
  17. May 17, 2013 at 7:49 AM
    97Blk_one
    Memfrica
    not so low
    I knew situations that happen in this shop, not at a stealership but a reputable carcare place. One of the oilchange guy did not put oil back after he flushed,didn't bother to plug it back, when the customer (older women) got her car back, she drove home. Her engine fried, when they investigated, no oil and plug were put back, She put them on local tv demand the place to pay for her car.
    Other situation same place, different customer, different service guy. Customer got his tire rotated, service dude put the tire back,but do not put all the wheel nuts back. Customer drove halfway, his rear tire fail off. Service dude got fired. Yeah...it's our vehicle,and our safty...you know they probably having a bad day at work...just sayin'
  18. May 17, 2013 at 7:54 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    that tire could have flown off and killed a mom driving a minivan full of rugrats
    holy crap that is a gross error. the employee that worked on
    that wheel should be fired immediately
  19. May 17, 2013 at 7:54 AM
    TIM.TRDSparks
    TIM.TRDSparks Well-Known Member
    Myrtle Beach, SC
    08 Taco DCLB RR
    CBI BUSHMASTER, BUDBUILT SKIDS SET, OME SUSPENSION, DAKAR LEAFS, TRD EXHAUST AND CAI PLUS MORE
    WOW!! I always double check any work no matter a dealership or someone else. Just a comforting way of mind. Glad no one is hurt!
  20. May 17, 2013 at 7:55 AM
    POWHANA
    Lake Tahoe
    Copy that. Thanks. I'll let em know this morning.
