Toyota downgraded driveshaft?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AllTacosFloat, Jan 18, 2021.
  1. Jan 18, 2021 at 1:22 PM
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I was part of driveshaft vibration recall years ago and last year went in for a bad u joint. They said no charge and replaced the driveshaft... cool. A couple months ago i notice i only have 1 zerk at the front of the driveshaft not the 5 i had before. What's up! Was i robbed? Is this new? Should i just shut up and replace them with zerks when or if they fail? When i asked Toyota they told me it came with just one. I did buy my truck used but it had 5. Thanks for any advice.
  2. Jan 18, 2021 at 1:24 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    What?
    ABNFDC and SR-71A like this.
  3. Jan 18, 2021 at 1:26 PM
    eon_blue
    Azusa, CA
    New Tacomas don't have any zerks on their rear driveshafts, so at least you got one I guess. Nowadays they are considered lifetime parts or whatever they call it, that don't need servicing like the older ones do. Whether or not that's true is another matter of debate.
  4. Jan 18, 2021 at 1:27 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You got a new drive shaft under recall .
    That new drive shaft came with one grease fitting . Things change vendors change .
    If you want you can change the joints to ones that have grease fittings .
    Simple fix or buy a complete new driveshaft with as many fittings as you desire.
    FishnTx and whatstcp like this.
  5. Jan 18, 2021 at 1:30 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    They did the same with mine last April.
    Covered in full, new joints, carrier bearing and rebalance.
    No zerks in new joints.
    I'm disappointed as well.
  6. Jan 18, 2021 at 1:40 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    They didnt steal anything from you,they put on new u joints that no longer come with zerks for the most part.
    So let the drama go in your title.
  7. Jan 18, 2021 at 1:40 PM
    AllTacosFloat
    Boston ish
    Glad to hear it happened to someone else i guess:( But not really. Might look into a backup driveshaft. Just thought why only 1 zerk when before it was 5. It is under warranty for like 12 years or something, maybe let it ride.
    ToxicTwin[QUOTED] likes this.
  8. Jan 18, 2021 at 1:42 PM
    AllTacosFloat
    Boston ish
    Sorry maybe should have been a ? Instead of !. Sorry if i offended.
    ToxicTwin likes this.
  9. Jan 18, 2021 at 1:44 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I'd ride it out as long as you can with the replacement and then just replace the u-joints with greasable versions whenever the time comes. They wont last as long without zerks so just keep an eye out for any new vibrations or rotational squeaking noises when taking off from low speeds.
  10. Jan 18, 2021 at 1:48 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    its a non serviceable item now, so no zerks.
  11. Jan 18, 2021 at 1:53 PM
    lynlan1819
    Tacoma
    Lifted
    Just check the dealerships work from now on,I do everytime before I leave the lot to make sure its done to my satisfaction.
  12. Jan 18, 2021 at 1:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it makes anyone feel better, non-greaseable joints are usually stronger.
    However, I still prefer the greaseable type.
    69L46Vert and 06Tacooo like this.
  13. Jan 18, 2021 at 2:00 PM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    Yeah I guess they are "lifetime" parts, we shall see if that is accurate.
  14. Jan 18, 2021 at 2:02 PM
    eon_blue
    Azusa, CA
    Toyota Stole His Driveshaft, You Won't Believe What He Looks Like Now
    Hendrix834 likes this.
  15. Jan 18, 2021 at 2:02 PM
    TnShooter
    Deogee
    STOCK
    The absolutely are Lifetime parts.
    They will last the lifetime of the part.
    Don’t let it be confused with the lifetime of the truck as a whole.
    06Tacooo, Jimmyh, TRDSport10 and 4 others like this.
  16. Jan 18, 2021 at 2:03 PM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    Well said!
  17. Jan 18, 2021 at 3:10 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I drive a 2010 I didn’t know there was a recall. But saying that I don’t feel any vibrations. Is it more like a TSB?
  18. Jan 18, 2021 at 3:18 PM
    AllTacosFloat
    Boston ish
    Was pretty sure it was a recall.. may have ended in 2019? . I only bring this up because I'm sure i feel a little u joint action happening.
  19. Jan 18, 2021 at 8:51 PM
    TacoTuesday1
    SD CA
    lifetime means designed to fail at 100k
    you could have kept the old part
    they probably threw it in the trash
    eon_blue[QUOTED] likes this.
  20. Jan 19, 2021 at 3:50 AM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    It's a Customer Support Program "ZH2"
