toyota emblem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by proto, Nov 10, 2010.
  1. Nov 10, 2010 at 8:31 AM
    proto
    proto [OP] Active Member
    11' access cab 4x4
    maybe i searched the wrong key words but how do i properly take off the toyota emblem on the grille and paint it?
  2. Nov 10, 2010 at 8:38 AM
    TacomaGRG
    TacomaGRG Well-Known Member
    Greg
    Danvers, MA
    09 SR5
    Westin Stainless Bull Bar Flowmaster 50 Dual Exhaust 17" FJ Cruiser Wheels Socks Devil Horn 3rd Brake Light Cover STK Pro Rack Carriage Works Black Billet Grille w/Devil Horns Stubby Antenna Avid Rocker Guards Rear Leaf TSB Rear Bilstein 5100s Front Bilstein 5100s @ 1.75 AFE Air Filter
    I used a screw driver to take mine off. But be careful. There are 3 small plastic tabs that hold it on the back and they can be easily broken.
  3. Nov 10, 2010 at 8:41 AM
    proto
    11' access cab 4x4
    yea i saw them i was wondering how to pop it out without breaking them i'll try a scew driver. thank
  4. Nov 10, 2010 at 8:44 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Squeeze the tabs together on one side....and once you get one side loose, the other will come loose easier.
  5. Nov 10, 2010 at 8:46 AM
    proto
    11' access cab 4x4
    and once i'm done it'll just snap right back in?
  6. Nov 10, 2010 at 9:03 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Yep. Sure will. Just gotta be carefull you don't break one of the tabs......always easier if it is warm outside.
  7. Nov 10, 2010 at 11:57 AM
    DBZ
    DBZ Hunter-Gatherer
    South Georgia
    2010 DC PreRunner TRD Off Road
    Fog lights anytime, DIY shorty antenna, carpet lined storage bins, debadged, tailgate hoseclamp, DIY washable cabin filter, AFe Pro-Dry air filter, Protecta bed mat
    With the hood open, if you look between the grille and radiator you can see the two chrome prongs/catches sticking through the back of the grille. Reach your hands down, one for each prong, and depress slightly with your thumbs while pushing towards the front of the truck/yourself. Push forward as far as it it will travel, which should be until your thumbs reach the back of the grille. Once there, move your attention to the front of the grille. The emblem should be tilted forward with a gap between it and the grille at the top of the emblem. Use your fingers at the gap and pull the emblem towards you and it will pop free.
    No need to use a screwdriver.
  8. Nov 10, 2010 at 1:34 PM
    proto
    11' access cab 4x4
    got it uot and just finished painting it :D looks 100% better than chrome
  9. Nov 10, 2010 at 1:34 PM
    proto
    11' access cab 4x4
    thanks for all the help
  10. Nov 10, 2010 at 1:46 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Good for you...and you're welcome! Post a pic when you git er dun!
    Thanks for your service too!
