Toyota Engine Flush additive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ExGunner, May 24, 2025.
  1. May 24, 2025 at 10:26 AM
    ExGunner
    ExGunner [OP] Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    Good Day maniacs :D
    My 2017 TRD Sport has 235,000KM on it. Im kind of obsessive about regular maintenance. Mileage is 97% highway speeds for 45 minutes daily up to 4+ hour runs one way. Would asking to have a can of Toyota's engine flush additive be beneficial to clean things out a bit better on my next oil change? I've been researching the topic, but it seems like it's a split opinion on good vs Meh for results.
  2. May 24, 2025 at 10:28 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What are you trying to flush from the engine?
    Chew and Canadian Caber like this.
  3. May 24, 2025 at 10:29 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If you have been changing the oil regularly there is no need for any kind of flush product.
    All quality oils have a well designed additive package to keep the engine clean.
  4. May 24, 2025 at 10:30 AM
    TacoDell60
    TacoDell60 Well-Known Member
    no
  5. May 24, 2025 at 10:37 AM
    ExGunner
    Paul
    I guess just built up crud you see in some engines that gets accumulated over time. Kind of why I'm asking people that know better than me.
    RustyGreen likes this.
  6. May 24, 2025 at 10:40 AM
    ExGunner
    Paul
    That's good. I know driving highway miles and the engine getting to operating temps all the time are quite beneficial vs short trips and the engine not getting a chance to properly warm up. I do run Royal Purple fuel system cleaner around every 25,000 km as well. My oil changes are done at the dealership so , except for maybe 3 , all my engine oil ,and basically all fluid changes, have been Toyota brand.
  7. May 24, 2025 at 10:55 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Sure there can be some exceptions but the overwhelming majority of the time you see an engine with built up crud it lived a life of long oil change intervals & low quality oils - just poor maintenance.
    "Solvents" and "Flushes" get a lot of marketing money, they play on the uninformed consumers fear of the unknown: "...well, this mechanic (oil changer) says I need it..." and they are pure profit for the shop.
    Think about it, they could just refill the bottle with any engine oil and "sell" the same bottle over & over.
    If all the money folks spent on "mechanic in a can" products was just put toward regular service the vehicles would be far better off.
    Canadian Caber likes this.
  8. May 24, 2025 at 10:57 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Just continue with good maintenance habits, run top tier fuel and the odd Italian tune-up.
  9. May 24, 2025 at 11:04 AM
    Vlady
    Issy, WA
    Why would you see a crud buildup if you change the oil regularly? if the oil cannot flush the imaginary crud, do you think the flush will?
  10. May 24, 2025 at 11:19 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    If you have changed your oil using good intervals in the 5000mi/6 months or close to for that amount of driving and used a good quality oil, there is nothing an engine flush will do to benefit you. I’d bet if you pulled your valve covers, you would find a clean valve train with minimal wear. Toyota motors do very well maintained like they should be with little need for anything beyond that.
    It’s even better you’re hwy driving a lot. Long hwy driving gets the oil up to working temperature long enough to burn off moisture and blown by fuel so it can work they way it’s supposed to.
    Canadian Caber and ExGunner[OP] like this.
  11. May 24, 2025 at 4:05 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You seem to be doing everything right so far so as the saying goes "if it aint broke dont fix it"
    Fireball 00, Tacosha and ExGunner[OP] like this.
  12. May 24, 2025 at 4:22 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I put a bottle of Techron in the tank once or twice a year to keep those injectors and intake system clean. But that's it.
  13. May 24, 2025 at 4:23 PM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
  14. May 24, 2025 at 4:44 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The crud doesn't form as long as you keep up with regular oil changes at ~8000 km.
  15. May 25, 2025 at 3:41 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Valvoline restore & protect full synthetic motor oil is a new product that cleans the internals slowly. It is about the same cost as other oils.
