Toyota engine for Range Rover
Discussion in '1st Gen. Tacomas (1995-2004)' started by MOJAVEsand, May 5, 2019.
  1. May 5, 2019 at 10:56 AM
    MOJAVEsand
    MOJAVEsand [OP] Well-Known Member
    Eric
    Lassen national park
    2017 TRD off road 6 speed manual
    Guys I have 1991 Range Rover, ( terrible vehicle by all means )
    On this thing engine is about to go out, I was looking at putting Japanese take out Tacoma engine,
    ( ultimate slap or Land Rover lovers face ;)
    I have few questions,
    the engine I wanna put it is 5VZFEE engine,
    what kind of manual transmission will work on those engines?
    and Range Rover is full time 4x4 with center dif lock,
    If I go head and use Toyota Tcase does It have center diff lock ?
    what kind of engine wiring and ECU will I need to make the motor run?
    Thank you very much,
    Eric
    Running Board Man likes this.
  2. May 5, 2019 at 11:20 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    This isn’t going to be an easy project.
    You’re going to have to rip out almost every single stock foot of Range Rover wiring from the engine bay, to the transmission, to the body, to the interior and replace it with a donor harness.
    Some body functions like AC, Radio, lights, locks, etc you may be able to keep but with extensive modification which requires merging the Land Rover and Toyota harnesses.
    I hope you like welding and fabricating too, because you’ll need to make all new engine and transmission perches.
    This is a lot of work, and definitely not worth it on a car like that. It will cost you a lot of money, time, and heartache.
    Fitting the engine and transmission is easy, but when you get to wiring it will be an absolute nightmare.
    If you’re OK wiring, fabricating, welding, and all of the stuff it takes to do it go for it. I would buy an entire wrecked truck. If you want to keep AWD/Center Diff Lock buy a later 3rd Gen 4Runner Limited (2001ish to 2002)
    Running Board Man and TXpro4X4 like this.
  3. May 5, 2019 at 11:21 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    The Tacoma R151F manual transmission is paired with the 3.4L 5VZ. The transfercase is center diff locked in 4wd high and low
  4. May 5, 2019 at 11:23 AM
    NM Lance
    NM Lance Well-Known Member
    Oh man! Subbed.
    My friend had a 1993 Hunter edition with a smaller V8... Most unreliable truck in the history of humanity. Would make an excellent trail rig with a Toyota drive train.
  5. May 5, 2019 at 11:32 AM
    IFGD
    IFGD Well-Known Member
    Ian
    Raleigh, NC
    2001 Regular Cab 2.7L
    If you succeed at this project, I will eat my shoe.
  6. May 5, 2019 at 12:17 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Easier to just install the Range Rover body on a Toyota Drive Train .
    It will be a interesting fun project
    The wiring will not be all that bad just like putting any other manufactures engine in a vehicle.given you have wiring schematics for every vehicle
    The fact it is a Range Rover means your all on your own exploring virgin territory lots of trail and error
  7. May 5, 2019 at 12:21 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    This
  8. May 5, 2019 at 12:29 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    x10
    Clearwater Bill likes this.
  9. May 5, 2019 at 1:50 PM
    MOJAVEsand
    Eric
    I hope it’s a brand new nice pair;)
    Consider it done ;)
  10. May 5, 2019 at 1:52 PM
    MOJAVEsand
    Eric
    Welding and fabrication is not a problem at all,
    as long as I can get the engine to start with proper wiring and ECU everything else should be easy.
    Transmission I am going with manual so I don’t have to deal with transmission control unit.
  11. May 5, 2019 at 1:54 PM
    MOJAVEsand
    Eric
    What year and model vehicle used that setup?
  12. May 5, 2019 at 2:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    This is likely very true. You should consider doing a lot of measuring and determine if it's a better path.
    It will be a project. (FTFY)
    Amen.
    And lets hope it actually sees a trail someday. :fingerscrossed: :D
  13. May 5, 2019 at 2:10 PM
    Wulf
    rock raisin
    Tacomas 1996-2004 and 4runner 1996-2000ish
  14. May 5, 2019 at 2:10 PM
    Wulf
    rock raisin
    Have you considered a 1UZ or 2UZ V8?
  15. May 5, 2019 at 2:16 PM
    MOJAVEsand
    Eric
    No I haven’t lookined into those,
    I was thinking v6 would be better option because Land Rover came with small 3.9 v8 that makes same amount of power as 1943 Russian sawing machine lol
    under the hood there is not much space for 2uz v8.
    plus I wanna do manual transmission.
  16. May 5, 2019 at 2:20 PM
    MOJAVEsand
    Eric
    Ok great that won’t be hard to find.
    So all the 4wd 4 runners and Tacoma’s in the years you mentioned came with center Diff Lock Tcase?
  17. May 5, 2019 at 2:24 PM
    IFGD
    Ian
    Raleigh, NC
    That said, I hope you do succeed. I love the look of that era RR and having it with a reliable Toyota drive train would just be sublime. Good luck.
  18. May 5, 2019 at 2:32 PM
    MOJAVEsand
    Eric
    they only look cool, and I agree, that’s why I am still hanging on to it.
    They are terrible in every possible way,
    Interior is so bad, it’s crumbling apart,
    Drivetrain is basically as bad as it could come.
    I think 98% of those Range rovers and discovery’s been turned into Coca-Cola cans long time ago.
    Discovery was so bad that Land Rover didn’t use that name in USA for a long time, they called it LR3 in Europe that’s discovery 3.
  19. May 5, 2019 at 2:36 PM
    Wulf
    rock raisin
    1999-2000 limited and 2001-2002 4runners have a multi mode tcase with AWD but the rest are center diff locked
  20. May 5, 2019 at 2:38 PM
    MOJAVEsand
    Eric
    Are those electronic transfer cases or manual?
    I really appreciate your knowledge and help.
