Toyota Factory OEM Tonneau Cover Leaks Everywhere
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gbpckrs, Jun 29, 2017.
  1. Jul 16, 2020 at 12:09 PM
    #41
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    My factory one has leaked since day 1. I'd say it lets in about 10 percent of the rain
  2. Jul 16, 2020 at 12:27 PM
    #42
    Flowie
    Flowie Well-Known Member
    2017 TRD OR
    None yet
    I have a factory cover...it leaks but not badly. Just a couple spots get a 1/4 cup of water puddled up.
    I have noticed closing tailgate first then shutting the tonneau down onto it seals better.
  3. Jul 16, 2020 at 1:13 PM
    #43
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i have not read the whole thread so apologies if already suggested.
    i don't have an OEM cover but when i installed my generic 3rd party cover, i noticed some leakage. at night, i put a bright light source outside the truck bed, especially near the cab, and climbed in the bed,
    under the cover, and discovered where rain was getting it, especially when driving. i remember gluing some closed cell foam blocks in areas near the cab, under the caps. i'm not talking about the bulkhead rail gaps. there are other gaps in the corners near the cab. terrible design of bed if it was intended to be water proof. it does really well now.
  4. Jul 16, 2020 at 4:34 PM
    #44
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I have a Diamondback, but before that I had an Extang.
    I noticed a small amount of water I thought was entering near the cab, but was not an issue since it stayed below the bed mat.
    I sealed the tailgate and it's now gone. Makes me think the issue is at the tailgate, bit may pool near the cab if your truck nose is down a little.
    For the record, I have a winch so bumper weighs down up front.
  5. Jul 16, 2020 at 6:41 PM
    #45
    Chicken_Taco
    Chicken_Taco Well-Known Member
    Comfortably numb on the Darkside of the moon
    2019 Midnight Black Tacoma TRD Sport
    Working on it ...
    I believe the hard covers are considered “water resistant“ but not so much “waterproof“. Mine is fairly dry under normal circumstances. If we have a crazy crazy heavy duty rain I have a few drip marks if I open it up on the bed pad. But nothing major
  6. Jul 16, 2020 at 7:57 PM
    #46
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Toyota Factory OEM Tonneau Cover Leaks Everywhere.
    Take it off and throw it in the nearest dumpster. Problem solved.
  7. Jul 17, 2020 at 1:59 AM
    #47
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I get water in the tailgate when it is driven in the rain or after I wash it. I added some rubber molding to the inside area where it meets the tailgate and that fixed it. I removed the shims also in the middle section and that took care of the drips in the middle, never had the leaks up by the cab area. Now its a great seal, maybe a few drops here and there. Nothing to worry about, it wasn't really bad to begin with.
  8. Jul 30, 2020 at 9:29 AM
    #48
    fryrice
    fryrice Well-Known Member
    MA
    2020 MG Access Cab SR w/ SX pkg
    Does your Diamondback leak? I plan to get one.
  9. Jul 30, 2020 at 9:39 AM
    #49
    The_Devil
    E
    It does not leak front the front or sides. I spend allot of time adjusting the closed pressure so it would be tight, but still be able to close with one hand. I recently added the Extang bed seal since I would have water in the corners near the bed. Seems to work well but I cannot say 100%.
  10. Dec 16, 2020 at 7:13 AM
    #50
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Move your bed cleats, they may be lifting the tonneau cover (close the cover and use a flashlight to see if they contact)
  11. Dec 16, 2020 at 8:01 AM
    #51
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Imo, if the cover had been installed right, you shouldn't have any leaks...at least anything to write home about. Been 9 months my factory tonneau cover has been on...if anything i think it has settled to seal even better. I've had a few inches of snow melting on it...no leakage underneath. Bed insides are completly dry.
  12. Dec 16, 2020 at 8:02 AM
    #52
    Draco-REX
    Draco-REX Well-Known Member
    OH
    White 2019 TRD Pro MT
    Too many mods and I haven't even started yet..
    I don't have the hard tonneau to check, but maybe some camper tape along the underside would help? Just spitballin here.
  13. Dec 16, 2020 at 10:40 AM
    #53
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Thank you for the advice, I appreciate it! But the slight leak doesn't bother me. I don't really expect something like this to be 100% water-tight over a long period of rain, just water resistant.
    Anything I want to remain 100% dry goes into my boxes.
  14. Dec 21, 2020 at 8:32 PM
    #54
    Taco Pat
    Taco Pat Well-Known Member
    Patrick
    SoCal
    2018 Tacoma TRD Off Road
    I mainly only store things which are able to get wet in the bed. I also use it for camping and had read that the cover was only water resistant so I bought two 50gal tubs for gear/clothes/food stored in the bed. That’s my short term solution until I buy a topper and build a camping setup
  15. Dec 21, 2020 at 8:50 PM
    #55
    Aje0010
    Aje0010 Well-Known Member
    Alec
    2019 Quicksand TRD-OR MT
    I don't have a specific write up on this but I made a few adjustments that made mine almost completely waterproof. Each of the latches on the underside of the cover have a small plastic cover. Pop those off. The actual latches are bolted down to the cover but under the latches are little spacers. If I remember correctly I had 1 spacer under each latch for the front two thirds of the cover, and 2 spacers under the rear most section. I played around with a combination of taking certain ones off, and eventually I got a good combination of spacers that pulled the cover tighter to the bed. I also swapped some of the spacers between the back and front etc to get a good combination. Just play around with it until it fits tighter. The rearmost section on mine requires a good slam to close fully with 2 clicks, but if it doesnt get the second click, press firmly like 2 inches back from the seal and it'll click the second click, locking it completely down.
    Hope this helps. If anyone is interested I'll go take pics and make a short write-up.
