Toyota Fan Clutch Silicone Oil Part Numbers
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Jul 30, 2018.
  1. Jul 30, 2018 at 8:43 AM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    "The Toyota dealer says there are three types of viscous fan clutch silicone. They are rated at 3000 CST, 6000 CST, and 10,000 CST. (the higher the Cst rating, the higher the viscosity (THICKER fluid) All priced the same. The only reference to this stuff that the Toyota parts jock could find, was a TSB from 1975 specifying the fill procedure for the clutches of that year, The 3,000 Cst. was for all Toyotas except for the Celica (the only “sporty” car they offered in 1975), which got 6,000 Cst. The 10,000 Cst. was not assigned an application by the TSB. He guessed maybe the Land Cruiser but didn't really know. Anyway, the part numbers are 08816-03001, 08816-06001, and 08816-10001, respectively.(Each bottle is 18mL; you will probably need 2-3 bottles depending on your specific fan clutch)"
    http://www.zhome.com/ZCMnL/tech/FanClutch/FanClutch.htm
  2. Jul 30, 2018 at 10:16 AM
    tony2018
    tony2018 Well-Known Member
    Thanks Jon, Soo....what is currently in our oem fan clutches.
  3. Jul 30, 2018 at 10:25 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I don't understand why anyone would bother a new aisin fan clutch for the tow package from cockauto is $85 vs. spending $36 on three bottles of mystery goo to put in a used clutch that has other wear parts
  4. Jul 30, 2018 at 10:25 AM
    tony2018
    So I followed a link below the article and one guy used a syringe to force the silicon fluid in. I don't see how he was able to remove any though.
  5. Jul 30, 2018 at 11:37 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    You split the fan clutch in half by unbolting the two halves. You can get the same fluid from a RCHobby shop for $15 or Amazon.. Its used in the differentials.
  6. Jul 30, 2018 at 11:38 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I believe it's the 3000cst or wt.
  7. Jul 30, 2018 at 11:40 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    It only requires 2 bottles from Toyota or 1 bottle from a RCHobby store.
    mattyosh and Dalandser like this.
