--TOYOTA FIBERGLASS GUIDE-- Glassworks, Fiberwerx, McNeil, Hannemann
Discussion in 'Long Travel Suspension' started by nelson18matt, Oct 13, 2011.
  1. Feb 16, 2017 at 10:35 PM
    #181
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  2. Feb 16, 2017 at 10:54 PM
    #182
    Ariyan
    Ariyan Well-Known Member
    NM
    4x4 TRD Sport
    SAS, 40s, and some armor.
  3. Feb 17, 2017 at 5:53 PM
    #183
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    I've been talking to them about doing a 4" on my truck so hopefully you'll have that option soon as well
  4. Mar 20, 2017 at 7:08 AM
    #184
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Im really considering pulling the trigger on some roadrunner rear bedsides for mine. That way if I go true LT in the rear, wont have to worry about that later on. I assume many are going with the 4 inch bedsides for their second gen LT rear setups?
    Coot
  5. Mar 20, 2017 at 7:11 AM
    #185
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Correct. Plus I'm pretty sure your tc sua so unless you cut the shit out of your bedsides you're already loosing bump travel
  6. Mar 20, 2017 at 7:14 AM
    #186
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Oh ok cool, I mean if I put glass bedsides on, my hope would be eventually to convert to a DMZ sua.
    Coot
  7. Mar 20, 2017 at 7:25 AM
    #187
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    thought you had SUA now..
  8. Mar 20, 2017 at 7:26 AM
    #188
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Would be different geometry I would have to relocate everything and replace the TC sua entirely.
    Coot
  9. Mar 20, 2017 at 7:41 AM
    #189
    Large
    Large Red
    Wish McNeil would make bed sides likes the 2x2 fronts for the 2nd gen ...
    Hennessy likes this.
  10. Mar 20, 2017 at 8:20 AM
    #190
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah gotya, I think I have seen some have said it is good to have the tent rack be attached via the bottom of the bed instead of the rails. This is because the fiberglass bedsides wont have as much loading capability in terms of weight and the tent could be an issue over time with the bedsides cracking. I don't know if anyone has experienced this necessarily happen to them, but I would see if you can get the contact points of your tent rack adjusted to bolt done along the bed itself.
    Coot
  11. Mar 20, 2017 at 8:51 AM
    #191
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Depending on shock size and placement as well as tire size, I believe you can get away with 33s with no spacers and pull the stock bedsides about 2" out and cut up where you need it. Maybe if you get the frame notched to tuck shocks in it would work with no rubbing
  12. Mar 20, 2017 at 11:00 AM
    #192
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    They've been talking about doing it @jakebray
  13. Mar 20, 2017 at 11:20 AM
    #193
    Large
    Large Red
    That would be sick ... I'd buy a set right now
  14. Mar 25, 2017 at 7:45 AM
    #194
    nate232
    nate232 Insta: @LT_YOTA
    Nate
    Hesperia, CA
    2015 TRD Off-road DCSB 4x4
    Don't know if this has been talked about. But glassworks has been bought out!! Maybe customer service will be a lot better:bananadance:
    RacecarGuy and mjp2 like this.
  15. Jun 6, 2017 at 4:00 AM
    #195
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    Glassworks has been bought out! I just got my fiber through the new advanced team, currently shipping (Guam) but i can say John and their whole team were awesome to work with even though i made it pretty difficult. Ill post back with pictures once i get it all installed. Would recommend over some of the others that are impossible to get a hold of
  16. Jun 6, 2017 at 5:41 AM
    #196
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    What kind of turn-around time was there on your order? What pieces did you get?
  17. Jun 6, 2017 at 3:31 PM
    #197
    Bobby18
    Bobby
    I got the 3-piece front end for the 2nd gen, cheaper than fiberwerx and was ready/shipped about 3 weeks after purchase which is I think sooner than they originally told me, that's just my experience though they're worth a call to find out or website has chat option
    Dalandser likes this.
  18. Jun 12, 2017 at 1:21 AM
    #198
    KiteGuam
    KiteGuam The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
    You local?
  19. Jun 12, 2017 at 5:05 AM
    #199
    Bobby18
    Bobby
    Hey man! No I'm from the states, on Andersen now for a while.
  20. Jun 12, 2017 at 9:46 PM
    #200
    KiteGuam
    Guam
    How long you here for?
