Toyota field tech/engineer coming to look at my truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jul 26, 2023.
  1. Jul 26, 2023 at 12:45 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    So the dealership and Toyota corporate called me back and have set up appointment in a few weeks for an engineer/field tech to look at my tacoma for the multiple problems I seem to have. One is the continuing loud bearing/humming noise that is coming from the rear of the truck and seems to be getting louder(rear diff was replaced once already). I have a pull to the left when applying the brake pedal, and finally the water dripping onto the passenger side floor mat when using fresh air mode with my a/c running. You guys have any experience dealing with these engineers that come to Toyota dealerships to help the techs? Are they typically on the money and what’s my chances of him coming up with a solution to these problems. Truck has 5k miles. Completely stock.
  2. Jul 26, 2023 at 12:58 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    In Gm land they were usually pretty decent when they came, however expect the noise to be noise resonance from the leaves through the cab. There is an old bulletin they applied to my truck for it. It helped... for the pull they'll probably service all four corners of your brakes, adjust the drums then check for a loose front end component. For the hvac system dripping it's probably condensation on the outside of the case. Maybe they'll wrap it with something but that one they may just say it's normal
    Gfenza89[OP] likes this.
  3. Jul 26, 2023 at 1:01 PM
    Gfenza89
    The noise in the rear I’m really thinking is a bad wheel bearing. It changes when turning sometimes(the sound). So you think the engineer will actually take his time to go over my truck thoroughly?
  4. Jul 26, 2023 at 1:06 PM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    The field reps Toyota has are very knowledgeable and helpful, at least when I worked in service at a dealership.
    Our rep was verrrrry knowledgeable, and was genuinely curious about any issues.
    Top quality people from my experience.
    Tocamo, joba27n, TRDRed and 1 other person like this.
  5. Jul 26, 2023 at 1:12 PM
    Gfenza89
    Good to know !
  6. Jul 26, 2023 at 2:30 PM
    TheSpartan
    TheSpartan Well-Known Member
    Gorgo (22 Army Green TRD Sport DCSB)
    I've seen many threads here and elsewhere about the dripping AC issue.... as far as i remember, Toyota doesn't consider it a problem
  7. Jul 26, 2023 at 2:34 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    So your dealership is unable to diagnose a potentially bad wheel bearing and an issue with condensation dripping, that they need to call in a field rep? Interesting
  8. Jul 26, 2023 at 2:48 PM
    Gfenza89
    I think with all my complaints they just want a higher authority to look at it I guess…
  9. Jul 26, 2023 at 2:49 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i got the same dripping a/c issue on the passenger side floorboards with the fresh air mode enabled. I did park under a tree for a couple years and always had to clean all the junk out. I want to try removing the cowl and cleaning everything out. I think there's some debris in there that is absorbing moisture/rain and it starts to drip when it starts pulling in air from the cowl.
  10. Jul 26, 2023 at 2:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Sometimes a higher authority is needed to say what the dealer can do. I had an MR2, 3000 miles out of warranty and the Temp gauge went out. The Toyota Rep told the dealer to fix it free because it is not like I abused the Temp gauge.
  11. Jul 26, 2023 at 2:57 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Not toyota but my clutch blew out on my old vw gti vr6 when it had less than 15k on it. The service writer had it out for me for some reason because it was lowered. Ironically that same service writer drove a lowered modified audi a4. Dude denied my warranty claim I called bs so vw sent a tech out to the dealer. I had requested to be present during the inspection which vw granted. The tech was there for 15 min looked the service writer straight in the eye and said if I ever have to come back here for BS like this I'll make sure you're no longer a service writer
    The cause a faulty bolt in the clutch housing sheared and shredded the clutch 100% covered.
    oconnor and Lawfarin like this.
  12. Jul 26, 2023 at 2:58 PM
    Gfenza89
    The field reps have that much power? Wow .
    ndoldman59 likes this.
  13. Jul 26, 2023 at 3:00 PM
    OnePuttBlunder
    AZ
    IDk if he did or not but dude was pissed he had to drive out from the proving grounds to look at it. His opinion was it was 100% clear a manufacturer defect and the service writer was just being a dick
  14. Jul 26, 2023 at 3:22 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    the service writer probably assumed you didn't know how to use a clutch properly. but if they didn't even look at it, that's on them.
  15. Jul 26, 2023 at 3:28 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    What about the timing cover leak
  16. Jul 26, 2023 at 3:47 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    My 1981 Toyota 4x4 MT blew the trans bearings, out of warranty. I took it apart and took the bearings to Michigan bearing who guaranteed they had every bearing ever made. I spent the whole day with them, at the end they were 1000's off. Said I'd have to go to the dealer. Went to the dealer and told them what happened, they went in the back and brought out all 4 bearings. They gave them to me. Even said if I brought the truck to them they'd put it back together for nothing. I did the repair myself, but that sold me on Toyota, even to this day. OP, I hope you get the same results like I did.
    soundman98 and ndoldman59 like this.
  17. Jul 26, 2023 at 3:57 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    My Ac drips on my 15, 18 and my 23.
    Aren't you the guy who put oil stop leak putty all around your timing cover on your brand new truck hoping it would help stop a leak further down the road? Don't take this the wrong way but hopefully you tried to scrape that off cause if a field engineer sees that he's gonna think you're a kook.
    Not trying to be rude but maybe you just being a bit OCD about the truck and focusing on problems that aren't really there? I'm on my 3rd tacoma, they all make noise and clunks and drive like ancient trucks, buzz, vibrate etc.
    Field reps/engineers don't have "that" much pull. They are the bridge between the dealer and Toyota when it comes to issues like this. Toyota corporate ultimately makes the call but it's based on what the engineer says.
    If you have been to the dealer 10 times already and the have attempted to fix the brake issue more than 3 times or if you have been without your truck for more that 30 days just lemon law the truck. The laws are cut and dry and if you meet the requirements it's a quick and easy process.
  18. Jul 26, 2023 at 4:05 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Which of course was caused by being lowered :rofl:
    soundman98 likes this.
  19. Jul 26, 2023 at 4:05 PM
    trouble_shooting
    trouble_shooting Active Member
    Trig
    2021 TRD Off-Road
    ^^^^ This, I’m guilty of it at times, if you go looking for problems, you most certainly will.
  20. Jul 26, 2023 at 4:10 PM
    Gfenza89
    Mines not leaking is yours?
