Toyota Frame Rust Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Whiteghost184, Sep 1, 2017.
  1. Apr 15, 2018 at 10:07 AM
    #381
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    :rofl:They probably dont even have any undercoating in stock! Wonder if they even have a spraybooth for it built yet, that could be another reason it wasnt mentioned. You Floridians and your wonky dealers hahah
  2. Apr 15, 2018 at 10:56 AM
    #382
    gmc8
    gmc8 Well-Known Member
    Gary
    Smoky Mountains
    After doing some spring cleaning of the under carriage I noticed a bit of paint peeling and some minor surface rust forming on many of the frame welds. I cleaned them up, painted with epoxy paint and gave the frame a good coat of fluid film. My truck is a 15 with 16k miles that's been garaged and only seen snow once. I don't have much confidence in 2010 being the end of the frame issues.
    Hawco636 likes this.
  3. Apr 15, 2018 at 12:16 PM
    #383
    Markcal
    Markcal Well-Known Member
    I live a few towns over from you, just curious what dealer in MA you use and does a great job doing inspections? I'm almost 100% sure my frame will pass this October when my truck reaches the 12-year service date. I will be happy if my truck lasts as long as my 1988 Nissan truck, which was 18 years, but my next truck will be sprayed a minimum once a year will Fluid Film before the salt hits the roads.
  4. Apr 15, 2018 at 12:28 PM
    #384
    Markcal
    If you live in Florida the reason the CRC undercoating wasn't applied is that FL isn't a "cold weather" state, so it doesn't qualify. IMO people living near the ocean should have the undercoating applied, as the frame is exposed to the constant salt spray.
    On May 21, 2017, a settlement of claims in a class action lawsuit involving 2005-2010 Toyota Tacoma vehicles regarding frame corrosion was approved. This finally approved class action settlement includes inspection of the customers frame, and if the frames meet or exceed the Rust Perforation Standard based on the court ordered inspection criteria, the frame will be replaced at no cost to the customer. Toyota is currently preparing parts for frame replacement.
    This settlement will also include CRC (Corrosion Resistant Compound) application. Toyota is currently preparing parts for CRC application process. Once available, CRC application will be covered under a separate Limited Service Campaign (LSC), and will only be available for vehicles registered in Cold Climate States that pass frame inspection criteria and did not:
    • Previously have the frame replaced and/or
    • Previously had the frame sprayed with CRC under any previous campaign
    Background:
    Toyota has received reports that certain 2005-2010 model year Tacoma vehicles operated in specific Cold Climate States ( District of Columbia, CT, DE, IL, IN, KY, MA, MD, ME, MI, MN, NH, NJ, NY, OH, PA, RI, VA, VT, WI and WV) with road salt usage may exhibit more than normal corrosion to the vehicles frame.
  5. Apr 15, 2018 at 12:46 PM
    #385
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I am a tech at Ira Toyota in Danvers, part time as I'm still in the T-TEN program. We usually have a couple frame jobs going on in the shop with the next ones waiting out back. We even store some Taco's over in Topsfield at the new car lot because THERE ARE JUST SO MANY DAMN FRAMES! If it passes we have a really nice spray booth where we CRC coat the frames. The techs do not rush their frame jobs either.
    Not biased because ive seem them spend hours going over frames with hammers tapping on sketchy spots or even using needle scalers as well to make sure nothings hiding underneath.
    lynyrd3 likes this.
  6. Apr 15, 2018 at 12:49 PM
    #386
    Markcal
    We have the same year Taco, just curious how your frame is holding up or has it been replaced already?
  7. Apr 15, 2018 at 12:53 PM
    #387
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I bought my taco used 2 years ago just about. The frame was replaced prior to my purchasing at Rockingham Toyota in NH as the previous owner lived on the Haverhill/Plaistow border. Cant say how the old one looked but the new frames been under the truck for about 2 1/2 years now and the only place it gets the tiniest bits of surface rust is at the welds, so i touch em up with a wire brush and paint them really good every now and then. After winter i also hand scrub the frame and shoot water down the rails because i do get up to Nh to offroad.
    lynyrd3 likes this.
  8. Apr 15, 2018 at 12:56 PM
    #388
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Gonna go out on a limb and say the frame was trashed though. Guy used it for yardwork/lawncare till around 2013. Im gonna assume the original trailer hitch matched the frames texture so im sure it needed a good ole frame job!
    lynyrd3 likes this.
  9. Apr 17, 2018 at 10:32 PM
    #389
    DarderSauce
    DarderSauce Active Member
    2017 White Tacoma TRD
    Thanks for the advice, I've been keeping my eye out for Springs and Shocks. Any idea if this CL posting is reasonably priced for front springs/shocks?
    https://minneapolis.craigslist.org/hnp/pts/d/tacoma-4runner-fj-cruiser/6555783962.html
    Not too familiar with different suspension options/setups. Main goal with suspension replacement is extended use before replacement would be required again. I think the CL ad has everything required for front suspension replacement; also believe it would serve as a levelling kit but not positive. If someone could confirm I'd appreciate it.
    Will likely do bushings and tie rods as well. Any brands you'd recommend? I've had good luck with Moog's in the past but not sure if others have had success with the Moog brand with Tacomas.
    Correct me if I'm wrong, but aren't the upper and lower ball joints included with new control arms? If so the Tech mentioned lower control arms are included in the frame replacement. Can anyone that has had their frame replaced let me know if any parts (such as control arms) were replaced along with the frame ?
    @JDB 2010 - Where did you buy the new manifold and what was the part #? Trying to find the best price but doesn't look like I'm going to get new for less than $500.
    Once my frame swap is complete I will let everyone know if my dealer threw in any additional parts.
    Thanks so much for all the help!
  10. Apr 18, 2018 at 5:30 AM
    #390
    SphericalCow
    SphericalCow Member
    I just wanted to add my truck to the list.
    I have a 2006 Prerunner SR5 (~ 193,000 miles). In the fall the dealer noted we qualified for leaf spring replacement, which they did. This spring I was getting some vibration under acceleration, took it to an independent mechanic who noted I may qualify for the warranty repair (for prop shaft u-joint?). Anyway, dealer looked at truck and quickly called to tell me my truck qualified for frame replacement. I wasn't expecting that. Well, after a couple weeks waiting for the frame, they replaced it. So far so good. So, brand new leaf springs and brand new frame on a 12 year old truck with nearly 200,000 miles. Yes, Toyota screwed up with this frame debacle, but they are trying to make it right (for the most part)... and I can't imagine what this is costing them.
    Good luck to those hoping/waiting for the same!
  11. Apr 18, 2018 at 5:32 AM
    #391
    lynyrd3
    Bill
    East Central Upstate NY
    My new frame won’t be to the dealer for 2 months they told me .
  12. Apr 18, 2018 at 4:39 PM
    #392
    Joe from MN
    Joe from MN New Member
    2004 Tacoma Extra Cab 4x4
    Wheels
    Just took my 2004 Tacoma in for frame check after my mechanic noticed holes on each side above the rear shock mounts. They found other really rusted areas. The dealer declared it unsafe and gave me a loaner car to drive home!
    I will find out in a few days if Toyota will replace the frame or buy the truck back.
    Toyota’s “Customer Service Experience” help line was very helpful and said that year had the frame warranty extended out to 15 years from the date it was put into service. 1-800-331-4331
    Markcal and lynyrd3 like this.
  13. Apr 18, 2018 at 4:40 PM
    #393
    lynyrd3
    Bill
    :fingerscrossed:
    Markcal likes this.
  14. Apr 19, 2018 at 4:40 AM
    #394
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That's a good price for everything you get, but it will provide some front lift and you may need to do an add-a-leaf in the rear to match things up -- just depends on how much lift you get out of it. Most likely around 2 to 2.5 inches, and it may ride a bit stiff in the front unless you add a bumper/winch. But probably tolerable.
    Moog should be fine. The main exception is u-joints, where you should go with Dana/Spicer.
    Usually when you buy an aftermarket control arm, it has bushings and ball joint installed. I can't confirm whether the replacement includes the lowers, but you'd still need the uppers.
  15. Apr 19, 2018 at 5:04 AM
    #395
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    My frame replacement included new complete lower control arms.
    DarderSauce and lynyrd3 like this.
  16. Apr 19, 2018 at 7:21 AM
    #396
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    They all should
    lynyrd3 likes this.
  17. Apr 19, 2018 at 7:35 AM
    #397
    balljoint
    Dave
    Ontario
    '18 DCLB
    When I had my truck in for the frame replacement I requested a copy of the parts list. This answered all my questions.
    lynyrd3 likes this.
  18. Apr 19, 2018 at 12:19 PM
    #398
    Joe from MN
    Wheels
    Just found out my 2004 was approved for frame replacement. This is good because I just put $1000 into it!
  19. Apr 19, 2018 at 12:51 PM
    #399
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Same here, mines waiting for the next 6 to 8 weeks. I know I’ve seen it somewhere but can’t find it, is there a list of parts that are replaced as part of the frame swap? I’m going to have them put new shocks and front springs on but want to start planning for whatever else I may need.
    lynyrd3[QUOTED] likes this.
  20. Apr 19, 2018 at 1:21 PM
    #400
    lynyrd3
    Bill
    I was at the dealer today and saw a truck loaded with new frames
