Toyota Frame Rust Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Whiteghost184, Sep 1, 2017.
  1. Apr 19, 2018 at 5:00 PM
    #401
    JDB 2010
    JDB 2010 Well-Known Member
    2010 TRD OFFROAD CREW CAB SHORT BED
    Part #s for the manifolds I used are:Magnaflow 49341 & 49341. Yes they are pricey but I was attempting to put the best manifolds I could on without messing with headers. I don't know if I made a good choice yet or not, time will tell.
  2. Apr 19, 2018 at 5:02 PM
    #402
    JDB 2010
    I meant Magnaflow 49341 & 49342
  3. Apr 19, 2018 at 7:28 PM
    #403
    Jimmied
    Jimmied Well-Known Member
    NJ
    2009 TRDOR DCSB Silver
    So my truck is actually apart at this point and they ran into an unusual issue. The tech was starting the reassembly process and found that there was an issue with frame. Gas tank would not line up/ bolt up. I have a friend at the dealer who gave me a call. He said this tech is one of two who do all of the frames and tech has done so many so he knew something was up. They have a Toyota corporate tech/engineer coming down now to see what is going on. Has anyone ever heard of this? Part numbers were crossed check to confirm. Just a major fitment issue.
  4. Apr 24, 2018 at 11:45 PM
    #404
    DarderSauce
    DarderSauce Active Member
    2017 White Tacoma TRD
    Do you happen to have a copy you could share with us?
  5. Apr 25, 2018 at 4:07 AM
    #405
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Not anymore but I know I've seen images of the list posted by someone on this site. Probably earlier on in some of the frame swap threads. Try doing a search.
    lynyrd3 likes this.
  6. Apr 27, 2018 at 5:10 AM
    #406
    MountainMaker
    MountainMaker Well-Known Member
    Dan
    Castle Rock
    2005 Tacoma DCSB
    Headgasket and frame replacement
    Got the call yesterday that my frame and parts just came in. She said they have 3 trucks scheduled in front of mine and to bring it in for replacement in a month. Pretty excited! This is way better than the July timeline I got.
    Too bad I don’t have enough time to save up for a 2” lift... Might need to find 3rd gen take offs...
    lynyrd3 likes this.
  7. Apr 27, 2018 at 1:53 PM
    #407
    lindy
    lindy New Member
    Toyota included them in the frame replacement? My 06 is at the dealer (Koons of Westminster in Maryland) getting disassembled now and the techs encountered a rusted (frozen) bolt connecting AC compressor to frame. Want $250 to tap and replace bolt.
    I called the Toyota "corporate" number at the bottom of the WEP notice and they said "any repairs needed during frame replacement is customer's responsibility." I countered the bolt will not need to be repaired until the technician drills it out. My AC worked fine before I gave it to the dealer. Toyota said they "understand my frustration".
  8. Apr 27, 2018 at 3:29 PM
    #408
    lynyrd3
    Bill
    East Central Upstate NY
    :facepalm:
  9. Apr 28, 2018 at 5:30 AM
    #409
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    How is the a/c compressor bolted to the frame ??
  10. May 2, 2018 at 1:53 PM
    #410
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I just got a call today, my parts are in 4 weeks early so they are going to be putting mine together soon. I was planning on having them replace shocks and tires but the dealer told me they couldn’t replace my tires because “ I have fancy alloy rims”. Ever hear of this? A different dealer 4 years ago put the current tires on these wheels so I don’t know why this one can’t do it.
    Also, I’m having them replace my shocks and front struts and they are charging me 250 for assembly of the struts (they are brand new but in pieces). Does this seem high?
    lynyrd3 likes this.
  11. May 2, 2018 at 2:29 PM
    #411
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Are you running 20” dubs or bigger?
    lynyrd3 likes this.
  12. May 2, 2018 at 2:32 PM
    #412
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Nope, standard 16 inch wheels, 265/70 tires
    lynyrd3 likes this.
  13. May 2, 2018 at 2:40 PM
    #413
    crolison
    Ar vah da, CO
    POS
    they are pulling your leg / don’t want to do the work.
    $250 for the springs is high, that’s like 15-30 minutes worth of work.
    lynyrd3 likes this.
  14. May 2, 2018 at 2:49 PM
    #414
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    More than likely they don't want to take on the risk having to replace a rim if they scratched them, and they probably know they don't have the most skilled workers on the tire changers
    lynyrd3 likes this.
  15. May 2, 2018 at 5:51 PM
    #415
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I don’t know whether to be happy or worried. I was first told it would take 6 to 8 weeks to get the frame and another few days to replace it. Then the dealer calls me today, only about 2 weeks of waiting, and tells me they got the parts and we’re starting the work. They just called me at 8:48 pm ( who even knew the service Dept was open that late) and said it’s done and I can pick it up tomorrow.
    I just hope they took their time and did it right but it worries me how fast it seems like they did it.
    Anybody else have an experience like this? I was hoping for more of a warning because the rental they gave me came with only 1/4 tank of gas and I just filled it a few days ago. I’m going to ask them if they’ll give me money back for the gas I bought.
  16. May 2, 2018 at 9:08 PM
    #416
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    mine only took the dealer about a day and a half to do the swap.Check the bed alignment when you pick it up.i would make sure that the wheels aren't over torqued too.
  17. May 3, 2018 at 4:00 AM
    #417
    Brandzilla
    Brandzilla Active Member
    Brandon
    2006 Tacoma Trd
    Stock
    Did you answer the phone or did they leave a message? If they left a message then I would just keep driving the rental finish out the rest of the week.
  18. May 3, 2018 at 4:11 AM
    #418
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    They took my truck away .. can't drive it... there is a large list to have it replaced .. I'm way down on that list .. however .. This is my loaner ..
    I have to tow a horse trailer ..:thumbsup:
    lynyrd3 likes this.
  19. May 3, 2018 at 4:17 AM
    #419
    WillT11
    WillT11 Well-Known Member
    Will
    When mine came back, it came back with all four bolts that connect the lower control arm to the spindle hand tight. Also came back with a caliper that had seized during the long wait, granted that wasn't on them. I ended up putting on all new rotors, pads, calipers, front struts, rear shocks, front wheel bearings, and replacing my busted sway bar end links. Toyota had put new LCAs, brake lines, and fuel lines on with the frame change. 235A7D9D-81B8-4659-A4C8-DCD9B19B303D.jpg4BA49104-509B-4A58-BE08-EEEDD33484A9.jpg9EB7BFE7-7616-4428-8337-01482434B9EE.jpg8BF8029E-7680-4663-97EF-933B62ED90E1.jpg1F98C431-0491-4057-93A0-8F46FFD54D4F.jpg
  20. May 3, 2018 at 4:28 AM
    #420
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    That's good to know, I thought it would take at least 3 or 4 days to do it so I was surprised when they said it was done. I will definitely check things over, I had a frame replaced on my old 01 and they only hand tightened the exhaust bolts. The entire exhaust nearly fell off on my way home, I thankfully always carry some heavy work gloves and a locking pliers so I was able to fix it parked alongside the highway.
