Toyota Frame Rust Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Whiteghost184, Sep 1, 2017.
  1. Oct 30, 2017 at 6:19 PM
    #61
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    In Canada you had until last December 31st to have your frame inspected. The class action suit is only currently in the USA as far as I know. Not sure how a Canadian truck would work currently in the USA.
    Best bet would be to contact a knowledgeable dealer, and if the first one is of no help, call another
    roadking1 likes this.
  2. Oct 30, 2017 at 8:15 PM
    #62
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    it is not a recall.Considered a Warranty Issue
  3. Oct 31, 2017 at 6:47 AM
    #63
    Edwinc357
    Edwinc357 Well-Known Member
    Edwin
    2006 Toyota Tacoma
    Just take it to see what happens
  4. Oct 31, 2017 at 12:16 PM
    #64
    MountainMaker
    MountainMaker Well-Known Member
    Dan
    Castle Rock
    2005 Tacoma DCSB
    Headgasket and frame replacement
    Because I purchased my taco this year (used) I am ineligible for any frame work/oiling, correct?
  5. Oct 31, 2017 at 1:55 PM
    #65
    Gsujake
    Gsujake Member
    Jake
    2009 Double Cab Tacoma 4x4
    I called today and the dealership said they wouldn't look into the frame warranty issue since the truck was 1st sold in Canada.
    I followed up with a call to corporate. Corporate was helpful. They informed me of the leaf spring recall that I knew about and said the frame warranty issue will not show on the website with the VIN since it's not a recall.
    Corporate also said that a US dealership is not required to do a frame inspection on a truck from Canada even though the lady has never heard of a dealership denying such. She asked for the name of the dealership and the name of the person I spoke with.
    Also, the dealership that turned me away is required to swap my leaf springs, so that should be fun.
    TRDSport10 likes this.
  6. Oct 31, 2017 at 4:12 PM
    #66
    Northern Taco
    any good dealer would take pictures of your frame and submit them with your paper work and wait for approval from Toyota. Ultimately Toyota approves or denies the frame replacement, and if it's approved the dealers make a good chunk of change off the process
  7. Nov 1, 2017 at 9:12 AM
    #67
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    The settlement agreement stated that owner of vehicles purchased after 12/2/2016 were not class members, therefore not eligible for remedies provided in the settlement.
    However Toyota's warranty enhancement program ZH6 click here (this is the frame inspection/replacement component) makes no mention of this, and there have been reports of trucks purchased after 12/2/2016 being accepted under the program...
    AgBase likes this.
  8. Nov 1, 2017 at 10:13 AM
    #68
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    The warranty is transferable and goes with the truck.
  9. Nov 1, 2017 at 10:30 AM
    #69
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    It must have been foreshadowing....but with my old 2005, every Fall I unloaded 3+ cans of black spray paint on the under carriage.... got the recall notice and laughed.... when i sold it the frame still looked brand new..... doing the same on my 2015
  10. Nov 1, 2017 at 10:46 AM
    #70
    Muddinfun
    Muddinfun Well-Known Member
    Poof
  11. Nov 1, 2017 at 10:48 AM
    #71
    cliffyk
    Cliff
    Saint Augustine, FL
    However this "warranty enhancement" is the remedy brought about via a class action suit. Class action lawsuits have class members (humans) that are eligible o receive benefits derived by a settlement; and as worded those who purchased a 2005 to 2010 Tacoma after 12/2/2016 were not class members. Therefore in this matter the remedy "follows" the class members (owners).
    That said, and as stated above, Toyota does not at this time seem to be enforcing this restriction. I believe one or more of the yet to be adjudicated appeals were contesting this class restriction so perhaps Toyota just said "screw it"...
  12. Nov 1, 2017 at 12:07 PM
    #72
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    Got my warranty “enhancement” sticker a few days ago. Threw it in my glove box.
    I feel so enhanced and protected....
  13. Nov 1, 2017 at 3:12 PM
    #73
    supermagic
    supermagic Active Member
    2007 Black Taco Base Access Cab 4x4 V6 Manual
    Well, no wonder it's not working for you. You did it wrong. You were supposed to peel it off and stick it into your warranty book. I mean, how else do you expect it to work? Magically by *just* being in the glove box? No no no no, you've got to energize it by peeling it off. Doesn't work unless you do this. I know. If you put it in crooked it won't work, either. Use a T-Square. The bigger, the better.
    KeystoneGoodie likes this.
  14. Nov 1, 2017 at 5:22 PM
    #74
    vram74
    05 Prerunner SR5
    Damn, I’m just seeing this. I panicked earlier, ran to the truck, grabbed the sticker and violently slapped it directly to the frame. Backed away, screaming “What naw, biotch!”.
    Will Toyota send me another sticker?
  15. Nov 1, 2017 at 6:00 PM
    #75
    supermagic
    I hope so, because it's supposed to IN THE WARRANTY BOOK. I'm not sure any other option will help. The warranty book is clearly more important than any of us realized. It's probably just the part of a vast, multi-dimensional cross-temporal being as it protrudes into our particular reality.
    But, since this being is cross-temporal, it probably doesn't matter *when* you comply. You can wait for another sticker to arrive. Probably.
  16. Nov 2, 2017 at 7:01 AM
    #76
    vram74
    05 Prerunner SR5
    Printed/bound within the core of a dying star and suspended inside the temporal nexus for eons until found by Toyota.
  17. Nov 3, 2017 at 11:11 AM
    #77
    rayhullphoto
    rayhullphoto Active Member
    Update on my truck, the dealer said the parts are on order. They are estimating that it will be 6 weeks or so for the parts to arrive. They said installing customer replacement parts is not a problem (e.g. Bilstein shocks, UCA etc) as long as its a bolt on part (just need to sign a waiver releasing them from warrantying the parts). I will be in the loaner car (2017 Camry) for quite awhile.
  18. Nov 6, 2017 at 11:09 AM
    #78
    MountainMaker
    Dan
    Castle Rock
    2005 Tacoma DCSB
    The service tech said that they can inspect and replace using the WEP bypassing the ownership from the lawsuit.
    I’m taking it in for a frame inspection on Friday.
    Edwinc357 likes this.
  19. Nov 7, 2017 at 11:51 AM
    #79
    cliffyk
    Cliff
    Saint Augustine, FL
    That makes them sound like great guys, however the WEP is the implementation of the class action suit settlement agreement--it was Toyota not the dealer who chose to not enforce the purchase date ownership restriction...
  20. Nov 7, 2017 at 12:58 PM
    #80
    MountainMaker
    Dan
    Castle Rock
    2005 Tacoma DCSB
    Yeah, I hope they are good guys. Ideally they my frame needs replacing and carry it out with minimal headache.
