Toyota Frame Rust Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Whiteghost184, Sep 1, 2017.
  1. Aug 22, 2023 at 12:07 PM
    #1201
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Good luck on that. Many have tried. All have failed.
    Why you ask? Because as has already been stated, the frame replacement program was not a voluntary recall. It was a court ordered settlement. Toyota has every right to say they've honored every aspect of that court order if your truck is past the cutoff date.
  2. Mar 14, 2024 at 2:19 PM
    #1202
    Too Stroked
    Tom
    So you ignored the notifications and now you're ticked off at them. Sorry, not buying it.
    tak1313, Micbt25, JmsWms and 2 others like this.
  3. Mar 14, 2024 at 3:30 PM
    #1203
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    You missed the point. Your son screwed you...not Toyota.
  4. Mar 15, 2024 at 4:19 AM
    #1204
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    My brother in laws Tacoma’s frame was replaced on his 2005. I went to the dealer and got the anti-corrosion spray after I got the notice and the techs were trained in the application of it. I get yearly oil spray applied to the frame so hopefully corrosion is prevented.
  5. Mar 15, 2024 at 7:50 AM
    #1205
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    The key point of submitting the truck under recall was so Toyota could examine the condition (at the time), and replace the frame immediately if necessary, or to apply the corrosion compound. Whether the compound ACTUALLY works to prevent the eventual demise of the frame can be debated, but they cannot be blamed when they weren't even given the opportunity to examine/apply it.
    If the rules of the recall were followed, the corrosion inhibitor was applied, the frame still rusted beyond use within the warranty period, THEN Toyota refused to warrant the frame, that would have been another story.
  6. Mar 15, 2024 at 12:41 PM
    #1206
    545
    545 Well-Known Member
    2015 Access Cab
    Why are you spamming all over this forum your discontent with Toyota?
    We all think you are wrong, so it can’t be for us. What do you get out of this? Does it make you feel better? Just don’t buy anything from Toyota if that’s what you want to do.
    O'DubhGhaill and Micbt25 like this.
  7. Mar 15, 2024 at 12:47 PM
    #1207
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Instead of blaming everyone else (your son & Toyota) I think you should take a long look into a mirror :) If you were close to the deadline, your experience probably would have been a positive one. However, what you are/were asking for is unreasonable. Suck it up!
  8. Mar 15, 2024 at 1:01 PM
    #1208
    tak1313
    2013 Base 2WD
    Not sure what kind of accommodation you were expecting, considering even IF you took the truck in during the time frame, it's still 6 years AFTER the extended warranty would have been applicable (if the truck was actually first put in service in 2005, make that 7 years) - or am I missing something on the math?
    Being a "40 year customer, who has bought 5 Toyotas" doesn't play into it. If it was that the truck was done under the recall, then 1 year after the drop date the truck had a full hole (meaning it was degraded pretty bad before the hole was found), and they did absolutely nothing (maybe discount on a frame swap?), then I could see a valid complaint.
    It's Toyota - not Costco. I would think even Costco would have a problem if you tried to return something 18 years later because you weren't satisfied...unless you had the receipt.
    O'DubhGhaill likes this.
  9. Mar 15, 2024 at 4:46 PM
    #1209
    Micbt25
    TM
    What’s wrong with you, seriously that’s not a rhetorical question?
