Toyota Frame Settlement Postcard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Jan 7, 2017.
  1. Aug 1, 2017 at 9:06 AM
    #561
    Edwinc357
    Edwinc357 Well-Known Member
    Edwin
    2006 Toyota Tacoma
    They have to send a report and pictures to Toyota corp. Then Toyota corp sends the frame. Info from the dealer that my truck is parked at.
  2. Aug 1, 2017 at 9:08 AM
    #562
    motoX007
    motoX007 Active Member
    2006 Trd off road
    Thanks for the info!
  3. Aug 1, 2017 at 10:05 AM
    #563
    motoX007
    2006 Trd off road
    just called Toyota corp , they gave me a case # and said I would get a call back tomorrow. Hope this gets done soon
  4. Aug 1, 2017 at 11:54 AM
    #564
    Edwinc357
    Edwin
    2006 Toyota Tacoma
    You should get your inspection done soon. Frame replacement time I don't know but they should give you a rental for the time you wait for your frame replacement.
  5. Aug 1, 2017 at 6:41 PM
    #565
    David's Tacoma
    David's Tacoma New Member
    What do you do when the entire frame is covered with scaling rust--but no hole yet (in 2 years 75% of the entire frame will have 300 holes) can't get your spare down, can't change rear end oil without replacing the rear end, your cross member nuts are rusted 75% away. Guys--better check those transmission bolts!!! I love my 06 with 79,000 cared for miles that should be good for 10+ more years but the frame will kill it right after the campaign ends--Damn you Toyota!!!!!!!!
    darktaco and lynyrd3 like this.
  6. Aug 1, 2017 at 6:55 PM
    #566
    darcycook
    darcycook Well-Known Member
    2005 4x4 Toyota Tacoma
    some were on the frame is a very thin area, has to be , find it , than tap it out with a pick; or somthing
  7. Aug 1, 2017 at 7:13 PM
    #567
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Where are you located?
  8. Aug 1, 2017 at 9:20 PM
    #568
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    His other post mentioned he's from Northern Ohio
  9. Aug 2, 2017 at 3:44 AM
    #569
    lynyrd3
    Bill
    East Central Upstate NY
    My inspection is tomorrow but the last time at dealership mechanic said I will need a new frame in 2 years but probably will not fail inspection now :mad:
  10. Aug 2, 2017 at 11:29 AM
    #570
    darcycook
    only one hole 10mm needed
    lynyrd3[QUOTED] likes this.
  11. Aug 2, 2017 at 11:57 AM
    #571
    ruskymx
    ruskymx Active Member
    2006 Indigo Tacoma
    I received the approval for the frame from Toyota. My service manager said that they can't order parts yet until Toyota green lights the whole deal. I think inspections are happening now, but not much else. I'll see what I can find out and dig deeper when I get a chance.
  12. Aug 2, 2017 at 12:37 PM
    #572
    Edwinc357
    Edwin
    2006 Toyota Tacoma
    How long did it take for you to get approved?
  13. Aug 2, 2017 at 1:13 PM
    #573
    ruskymx
    2006 Indigo Tacoma
    My inspection was last Wednesday and I just got the answer today. My service manager told me that he had to send the pictures a second time because for whatever reason, it didn't work the first time.
    Now I wait. I'm going to find out what number I have to call for reimbursements because I did just replace all the brake lines from the cab to the axle and I'm also going to try and get reimbursed for the frame patch work that I had done. I had the frame inspected before I bought it and it failed then so I had it patched. A brake line started leaking two weeks later. The way I see it, I wouldn't have had to shell out the $900+ for that work if the frame would've been getting replaced the first time. I'll update here when I talk to someone at Toyota
    Edwinc357[QUOTED] likes this.
  14. Aug 2, 2017 at 3:53 PM
    #574
    Good guy j
    Good guy j Member
    Dropped off my truck on the 19th of July failed inspection. Was given Tacoma loaner. Was approved for frame replacement July 29 . Was told will be weeks to months for frame to come in will be kept in loaner whole time. 175000 miles original owner not offered any buyback just frame replacement
  15. Aug 2, 2017 at 4:01 PM
    #575
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    What model year?
  16. Aug 2, 2017 at 4:03 PM
    #576
    Good guy j
    Good guy j Member
    2006 access cab 4x4 off-road
  17. Aug 2, 2017 at 4:09 PM
    #577
    cliffyk
    Cliff
    Saint Augustine, FL
    Then it is covered by the just settled Brain Warner v. Toyota class action suit in which there is no buyback option for the original or any owner.
    Just curious, what state are you in? Toyota seems to be targeting the rust bucket states first...
    Also welcome to the forum, when you have a chance fill in your profile and we'll know these things.
    20RustyTaco06 likes this.
  18. Aug 2, 2017 at 4:13 PM
    #578
    Good guy j
    Good guy j Member
    In Illinois
  19. Aug 2, 2017 at 4:23 PM
    #579
    cliffyk
    Cliff
    Saint Augustine, FL
    Thank you. The class action website is useless as to what is going on, and any court records I can find still indicate the appeals are active. It appears that Toyota may have just thrown in the towel and moved forward with the campaign in a manner that satisfies the appeals and gets the ball rolling.
    I am sort building a list/database as to where they have been approving replacements, and as I said above it appears the so-called "cold-climate" states are the first being notified. Our local (Saint Augustine, FL) dealer has not yet received any notification of the class action suit settlement campaign...
  20. Aug 2, 2017 at 4:36 PM
    #580
    Edwinc357
    Edwin
    2006 Toyota Tacoma
    At least you didn't get a Camry
