Toyota Frame Settlement Postcard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Jan 7, 2017.
  1. Oct 1, 2017 at 5:43 AM
    #1161
    Tdawg0
    Tdawg0 Member
    Well brought my 05 in. It passed the frame inspection,which sucks. My truck got coated by the previous owner but it pretty much all came off allready. While they inspected my frame they broke my antenna off my truck,Thanks Toyota. What are you guys doing with your trucks if your frame is in crappy condition but it passed?
  2. Oct 1, 2017 at 9:05 AM
    #1162
    jca
    jca Well-Known Member
    You got lucky then. lol. I don't know how toyota makes priority out of orders, but I've been waiting on my DCLB frame since July.
  3. Oct 1, 2017 at 11:17 AM
    #1163
    Edwinc357
    Edwinc357 Well-Known Member
    Edwin
    2006 Toyota Tacoma
    Have you been in a rental all this time?
  4. Oct 1, 2017 at 6:13 PM
    #1164
    jca
    No. I don't like driving a car I don't own for long periods of time.
    Edwinc357[QUOTED] likes this.
  5. Oct 2, 2017 at 3:29 PM
    #1165
    darcycook
    darcycook Well-Known Member
    2005 4x4 Toyota Tacoma
    you need to look your self there has to be one 10mm hole go to a different dealer if need be ,find that hole it is there
  6. Oct 2, 2017 at 5:26 PM
    #1166
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Check the frame rails too...See if the metal sandwiched together is separating.
    TRDSport10 likes this.
  7. Oct 2, 2017 at 5:48 PM
    #1167
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Especially where the frame turns up by the leaf springs and bump stops
  8. Oct 2, 2017 at 5:51 PM
    #1168
    darcycook
    right by the cats take a pointed hammer peck around
  9. Oct 2, 2017 at 6:18 PM
    #1169
    Fordpuller
    Fordpuller Member
    NWPA
    06 Tacoma 4x4 Reg. Cab.
    Take it to the car wash too that's how I found one of mine
  10. Oct 2, 2017 at 6:59 PM
    #1170
    darcycook
    i found one on frame behind front right tier , had pick a little but it was there
  11. Oct 2, 2017 at 11:56 PM
    #1171
    brah.coma
    brah.coma Well-Known Member
    06 2.7l 5spd 4x4 Reg Cab
    Mine was at the drivers side cab mount. Looked like crap so I punched it with my fist and a chuck about 3 inches over popped off exposing a hole.
  12. Oct 3, 2017 at 1:40 AM
    #1172
    motoX007
    motoX007 Active Member
    2006 Trd off road
    My truck is done ! picking it up this morning. New tow hitch , TRD exhaust, sway bar links , front axel seals, and I already had blistien 5100 shocks on when I put the 3" lift in . Ill take pics today
  13. Oct 3, 2017 at 4:32 AM
    #1173
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    What did the tow hitch cost you? Can you share the part number? There are several listed on the web. Some are showing a price above $800.
  14. Oct 3, 2017 at 8:08 AM
    #1174
    ruskymx
    ruskymx Active Member
    2006 Indigo Tacoma
    I bought a Draw Tite hitch for mine since my OEM is a mess. If your truck has an OEM hitch already, you will need to order the bumper brackets from Toyota. They run about $45 per side. I'll take some pics once I pick them up and post part numbers. I am also going to have to figure out where to mount the wiring since there's a bracket welded to the hitch on my OEM one.
    N919HJ[QUOTED] likes this.
  15. Oct 3, 2017 at 12:15 PM
    #1175
    Jbwilson3791
    Jbwilson3791 Active Member
    Jared
    2007 Toyota Tacoma TRD Sport
    Anyone know if an alignment is a standard part of the procedure? My dealership said it wasn’t performed
  16. Oct 3, 2017 at 12:32 PM
    #1176
    N919HJ
    Ohio
    They can’t take apart your whole front end and not do an alignment. That’s BS and unsafe, call Toyota.
    I just dropped mine off today because the rear gas tank strap rusted out and dropped the back half of the tank almost to the ground. Got a rental, they are working on a truck for me. The manager said it could be months before they get the frame in. We will see....
  17. Oct 3, 2017 at 12:35 PM
    #1177
    N919HJ
    Ohio
    Is the draw tite rated for 6500 lbs? The only ones I found were class iii, only 5000lbs.
  18. Oct 3, 2017 at 1:12 PM
    #1178
    Jbwilson3791
    Jared
    The dealership said it wasn’t part of the agreement so I called corporate and they said the same thing so no alignment I guess. I’d like to hear if anyone had one performed as part of this process. So far I’m at discount tire getting my free balance and rotation, after not having my truck for months, got it back 3 days ago and it appears so far That Toyota cross threaded 3 lug nuts and broke the studs. I’m afraid this is just going to be the beginning of my problems.
  19. Oct 3, 2017 at 1:23 PM
    #1179
    darcycook
    i would go back and demand new wheel studs, thats a major f up. i mean what the f, cant put on lug nuts correctly. realy every f up they made i would call toyota corp.
    Edwinc357 and N919HJ like this.
  20. Oct 3, 2017 at 1:40 PM
    #1180
    RedWings89
    RedWings89 Well-Known Member
    Luke
    SE Virginia
    2014 SR5 DCLB
    Just got back from the dealership. After almost 8 weeks in a camry my truck is done! I brought in a lot of parts that I bought from various retailers for much, much cheaper than the dealership was quoting. Including shocks, struts, steering shaft assembly, sway bar links, rotors, calipers, and pads. All total cost me right around $1k in parts and $955 in labor at the dealer. They charged labor for some of the things that they wouldn't have had to take fully apart if I hadn't brought in replacement parts. Toyota ended up with a bill of $11,630.90. Some pictures below of the new frame and other parts.
    kilroy2963 and Edwinc357 like this.
