Toyota genuine motor oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Apr 26, 2023.
  1. May 7, 2023 at 1:57 PM
    #141
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Toyota doesn't advertise their oil at all.
    zoo truck and 69 Jim[QUOTED] like this.
  2. May 7, 2023 at 1:59 PM
    #142
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    My 79 Chevy stepside has 420,000 on it and antique tags, my 91 Isuzu has 320,000 on it and antique tags. I plan on putting antique tags on this Tacoma in 25 years.
    grogie and RustyGreen like this.
  3. May 7, 2023 at 1:59 PM
    #143
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    We weren't referring to Toyota oil. Please keep up, and I do hope your truck will last for years also.
  4. May 7, 2023 at 2:18 PM
    #144
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I'm a little late to this party but I have never seen an oil well in Japan.
    69 Jim and Koolbreeze7 like this.
  5. May 7, 2023 at 2:42 PM
    #145
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I use 20-40 0il for my chain saw blade is that all right or should I use synthetic?
  6. May 7, 2023 at 5:39 PM
    #146
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I take you must of used only Toyota motor oil in your chevy, and Isuzu. Heaven forbid if they got that kind of mileage on them from some cheap dino motor oil.
  7. May 7, 2023 at 5:40 PM
    #147
    zoo truck
    None
    Actually straight 30w is best.
    Steves104x4 likes this.
  8. May 7, 2023 at 5:57 PM
    #148
    bmg88201
    Brian
    Quitman, AR
    2022 Tacoma Limited
    No, those older vehicles don’t use synthetic oils, I’m not sure if they even made synthetic oil in 1979, duh
  9. May 7, 2023 at 6:10 PM
    #149
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Probably because it's not their oil... they just put their name on it so they can charge more. I wonder what they'd charge if it said TRD on the label lol. :facepalm:For pretty much the same thing (same company) just buy Mobile One by the case when it's on sale at Costco.
    zoo truck likes this.
  10. May 7, 2023 at 6:51 PM
    #150
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I'll assume you haven't been reading the thread. It has been established that the Toyota product is an exclusive formula manufactured (by Mobil) for them.
    I find it (along with filters) to be priced fairly at my local dealer, obviously some dealers may choose to price higher.
    Junkhead and bmg88201 like this.
  11. May 8, 2023 at 2:29 AM
    #151
    erlltroll2002
    erlltroll2002 Member
    Brad
    SE VA
    '20 Army Green TRD PRO
    Diamondback Tonneau, Westcott 1" Lift, K02 33" tires
    I would agree with you. I have heard 5 years and actually used 5 year old oil in my mower. The oil looked just as it was brand new.
  12. May 8, 2023 at 2:54 AM
    #152
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Someone here mentioned they use the blood of a Chetah.
    69 Jim likes this.
  13. May 8, 2023 at 4:28 AM
    #153
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Old timers often used waste oil, but that's messy that's why use the 20-40 had a gallon of it for some thing. A chain doesn't care about viscosity no tight tolerance there.
  14. May 8, 2023 at 4:49 AM
    #154
    zoo truck
    None
    You're telling me they got that high mileage from regular motor oil? Sort of means you don't need any special Toyota sold motor oils then. duh?
  15. May 8, 2023 at 4:52 AM
    #155
    zoo truck
    None
    I've used a lot of spent 75w-90 gear oil in the past for my chainsaws. Love the aroma of the limited slip stuff as you cut through logs.
    Irons likes this.
  16. May 8, 2023 at 3:47 PM
    #156
    zoo truck
    None
    My dealer used mobil1 extended service during toyota care. I wouldn't say thats a cheap oil. Even when Toyotas care ended, they recommended 10k mile oil changes which I'm sticking to. I wouldn't say I'm one of those in the severe category.
  17. May 8, 2023 at 4:07 PM
    #157
    Firn
    Firn Well-Known Member
    White OR
    The real questions is, what common problems with the 3.5 are you trying to prevent?
    pahaf likes this.
  18. May 8, 2023 at 4:38 PM
    #158
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    If I wasn't using Amsoil I would use Pennzoil Ultimate Platinum. . . . . .great stuff. As far as CamGuard goes it really is a waste of money as is any oil additive.
  19. May 8, 2023 at 5:44 PM
    #159
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Congratulations on the new truck.
    Any major brand oil that meets specifications is fine, none of them need any third party additives. Change it every 5K and drive it.
    69 Jim, Wulf, Hoksamoen and 2 others like this.
  20. May 8, 2023 at 6:05 PM
    #160
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You do not need any additives for this engine. A quality 0w20, 0w30, or 5w30 synthetic will do just fine. Hell, even Supertech synthetic bought at Walmart is a very good oil. Don't overthink it.
    Taco_mike73, 69 Jim and RustyGreen like this.
