Toyota Japan oil filter??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Dec 10, 2012.
  1. Dec 10, 2012 at 3:31 AM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi I got some Toyota Oil filter on ebay. I have a question this filter is the Japan one 90915-20004 its longer than the D1 and D3 that the dealer sells. Have anyone used this filter on the first gen??? I know the 2nd out of the factory come out with this filter. But would it work on my 2003 v6. Thanks on advance.
  2. Dec 10, 2012 at 4:17 AM
    Robnik
    Robnik Tree Surgeon
    Rob
    Greenacres, FL
    2012 4 Banger Auto
    Yes, it's equivalent to the D3, which is larger than D1 which is equivalent to the G1. See attachment:
  3. Dec 10, 2012 at 5:18 AM
    Hektor
    Texas
    Thanks. So I should be good to go. Since filter is longer do I need to put use more oil?
  4. Dec 10, 2012 at 5:58 AM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    You probably will want a little more oil but I would check it with 5.5qts in there and see if it's needed. Usually 5.5qts with the stock filter is about half way up on the dip stick.
  5. Dec 10, 2012 at 8:02 AM
    Robnik
    Robnik Tree Surgeon
    Rob
    Greenacres, FL
    2012 4 Banger Auto
    Correct^^^
  6. Dec 10, 2012 at 8:28 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Alcan Leafs,
    Hey OP, got a link? ;)
  7. Dec 10, 2012 at 9:11 AM
    Hektor
    Texas
    Would do thanks a bunch.
  8. Dec 10, 2012 at 9:13 AM
    Hektor
    Texas
    Let me check I got them last month.
  9. Dec 10, 2012 at 9:14 AM
    Hektor
    Texas
    Let me see
  10. Dec 10, 2012 at 9:24 AM
    The Driver
    Raph
    Well, hopefully you'll find it, but if not (heck, it's been a month!), thanks for at least trying!
  11. Dec 10, 2012 at 10:43 AM
    Hektor
    Texas
    Sorry. This is the seller name travisann. I checked buy he doesnt have any listed.
  12. Dec 10, 2012 at 10:46 AM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 15 Mustang GTPP
    Too few to list. 10 4runner SR5 4x4- 09 Pre-Runner TRD-OR AC- 14 Prius Two- 08 xB 03 Tacoma 5spd TRD OR 4x4
    If you want a comparable filter, I use Napa 1516 which is longer than OEM and pretty good quality.
  13. Dec 10, 2012 at 1:47 PM
    Robnik
    Robnik Tree Surgeon
    Rob
    Greenacres, FL
    2012 4 Banger Auto
    Hektor, if you do come across some 03 or 04's again, let me know. Japanese Denso's (red o-ring w/ metal "ears") are definitely superior to anything aftermarket. Wix or Napa Gold (same thing) & Purolator Pure1 will be my 2nd choice after my warranty expires.:rolleyes:
  14. Dec 10, 2012 at 2:18 PM
    Hektor
    Texas
    Ok, would do!!!
  15. Dec 10, 2012 at 3:08 PM
    The Driver
    Raph
    Txs!
    & Txs to U 2!
