toyota leveling
Discussion in 'Suspension' started by nienhouse1, Mar 13, 2021.
  1. Mar 13, 2021 at 2:46 PM
    nienhouse1
    nienhouse1 [OP] New Member
    2017 Toyota Tacoma TRD
    2" lift spacer in front, 285/75 R16 BF Goodrich Tires
    got a 2" spacer in front, want to level it out, slight sag, I think a 1" block in red might be to much, has anyone ever seen a 1/2" or better a 3/4" block before? if so where?
  2. Mar 13, 2021 at 2:50 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
  3. Mar 13, 2021 at 3:06 PM
    Tigris99
    Tigris99 Well-Known Member
    St Louis
    2021 AG Trail edition
    I'm curious why you put a 2" up front to start with? Not being rude, truly curious because at least to my eyes that seems excessive to try and level the truck out.
    By the way unless you plan on rarely putting anything of any weight in the bed or have air bags, I would leave the rear a tad high. Doesn't take much weight to drop an inch in the rear sadly.
  4. Mar 13, 2021 at 3:12 PM
    nienhouse1
    the 2" spacer made the front slightly higher than the rear, didn't bother me with a little sag in the rear but now I'd like to level it out, a 1" block would make a little rake but like you said with any weight in bed then that might be the better option, just curious on the smaller blocks!
  5. Mar 13, 2021 at 3:25 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    No spacer lift.your truck the correct way
  6. Mar 13, 2021 at 3:35 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You won’t notice a 1/4” difference in the rear. A full or empty gas tank will change the level that much.
  7. Mar 13, 2021 at 4:55 PM
    Tigris99
    St Louis
    2" is a bit much for a spacer IMO but a little bit to level hurts absolutely nothing
  8. Mar 14, 2021 at 8:24 PM
    WacoTacoma
    WacoTacoma Active Member
    Hunter
    Colorado Springs, Colorado
    Silver 2012 trd sport
    King 2.5 /TC UCA 33" Falken MT 16" SCS Ray 10 DIY Wedge Camper
    Toytec has 1/2" shims
