Toyota lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by head1996, Sep 25, 2022.
  1. Sep 25, 2022 at 6:30 PM
    head1996
    head1996 [OP] Member
    How much lift I need to run 33/12.50/15 on 10" wheels? Tks
  2. Sep 25, 2022 at 6:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lift won't help.
    /thread
    head1996[QUOTED][OP] likes this.
  3. Sep 25, 2022 at 6:34 PM
    head1996
    What do I need
  4. Sep 25, 2022 at 6:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Follow this pinch weld tutorial - Finally, the Pinch Weld Mod – ADVENTURETACO
    This won't ensure fitment, but will add some needed clearance.
    Reason why a "lift" won't work exactly the way one hopes is because of the suspensions geometry. Consider how your suspension cycles and understand that, it will (often) reach a point where your wheels are in the same position they are now as your suspension compresses and extends.
    A body lift could help add clearance from say, your flares but most people just trim/cut parts out anyway.
    A proper alignment with added caster helps aid in fitment as well.
    Considering a skinnier tire will lessen the chances of rubbing too.
    Wulf and head1996[QUOTED][OP] like this.
  5. Sep 25, 2022 at 6:40 PM
    head1996
    Ok tks
  6. Sep 25, 2022 at 6:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    In case you're on your phone and not a computer, it could be hard to see this but the site has a few nice features including a bunch of stickies.
    This should help in your case - Tire Size Calculator - Compare Tire Sizes | Tacoma World
    I'm not sure what the equivalent is in a 15" wheel but a common skinny 33" tire (mounted on a 16" wheel) is 255/85/16.
    I've used this size myself as well as several others I know personally.
    Rubbing does occur but most of it can be fixed with the pinch weld mod I posted above.
  7. Sep 25, 2022 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Welcome to TacomaWorld. Where the feedback you get may not be what you want to hear...
  8. Sep 26, 2022 at 7:27 AM
    head1996
  9. Sep 26, 2022 at 12:19 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Why not 33/10.5/15?
  10. Sep 26, 2022 at 2:11 PM
    head1996
    My son has already bought 33/12.5/15
