Toyota Mechanics in Tacoma World
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LILBEAR, May 5, 2018.
  1. May 6, 2018 at 5:37 AM
    IowaTaco
    IowaTaco Well-Known Member
    Zach
    Central Iowa
    2018 Quicksand TRD Off Road
    I let mine warm up in the winter, but that's because my background is in Diesel engines where a cold flushing your block and then driving can ruin you engine quickly. Not sure if it's the same with this engine.
  2. May 6, 2018 at 5:38 AM
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Mine takes about 45 seconds to 1 minute for the rpms to kick down then I drive it but I keep the throttle light initially. But then again I’m in California and it’s garaged.
  3. May 6, 2018 at 5:44 AM
    LILBEAR
    LILBEAR [OP] Well-Known Member
    Winnipeg , Manitoba
    2018 Tacoma SR5 Black
    None brand new
    I always say treat it kind and it should last a long time.
  4. May 6, 2018 at 6:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No need to wait several minutes in the Summer, fire it up, wait a few seconds and drive off at a moderate speed.
    tcjacado likes this.
  5. May 6, 2018 at 4:05 PM
    LILBEAR
    Winnipeg , Manitoba
    None brand new
    But does your truck do what mine is doing?Start it up it is idling 1100 rpm.if i put it in gear within a few minutes the idle drops down to 500 rpm but it gives a little lunge when you let off the break and that is reverse or drive.
  6. May 6, 2018 at 6:12 PM
    shakerhood
    Southern Ohio
    I start mine up and wait a few seconds and drive off moderately
  7. May 6, 2018 at 6:16 PM
    shakerhood
    Southern Ohio
    In the Winter i start it and let it idle while i scrape snow and ice off.
  8. May 6, 2018 at 6:37 PM
    IowaTaco
    Zach
    Central Iowa
    Winter is definitely going to depend on location. In Colorado I would only warm mu truck up for five to ten minutes, here in Iowa I give it 20-30, but in North Dakota I would let it go for almost an hour. These times are for a 98 Chevy Truck but concept is the same.
  9. May 6, 2018 at 6:38 PM
    LILBEAR
    Winnipeg , Manitoba
    None brand new
    I have mine in the garage plugged in.Still looking for good command start for winter.
  10. May 6, 2018 at 6:43 PM
    LILBEAR
    Winnipeg , Manitoba
    None brand new
    Holy shit that is a long warm up are u running a diesel? Winter in Canada average -30 to -35 my hemi truck would warm up in 10 minutes.
  11. May 6, 2018 at 7:05 PM
    IowaTaco
    Zach
    Central Iowa
    That truck doesn't have a block heater. Its a gas engine, I just wanted the engine to be at operating conditions before I drove it.
  12. May 6, 2018 at 7:11 PM
    LILBEAR
    Winnipeg , Manitoba
    None brand new
    OK I get it.You have a block heater in your Tacoma right.How long does it take in the winter to warm it up? And what is the average temp.there in the winter where u are at?
  13. May 6, 2018 at 7:16 PM
    IowaTaco
    Zach
    Central Iowa
    No block heater in the Taco. The average temp at 4 when I leave for work in Iowa winter is around 0°F, I let the truck run for 15-20 minutes. By then it's at operating conditions, block is heated up, oil is at right temperature, everything is good to go. I treat my gas engines same as my diesels.
