Toyota OEM Accessory "Truck Bed D-Rings" different from Tie-down Points?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Prospector520, Feb 16, 2016.
  1. Feb 16, 2016 at 3:56 PM
    Prospector520
    Prospector520 [OP] Well-Known Member
    Arizona
    '17 Taco TRD Pro manual, '02 Taco TRD Prerunner auto
    I'm looking at options for a TRD Pro I'd like to order in a few months (a little premature, I know) and I was just curious how the Toyota OEM accessory "Truck Bed D-Rings" was different than the "four fixed cargo bed tie-down points" listed as a standard feature on the specs for the 3rd Gen. Tacoma.
    The "Deck Rail System with four adjustable tie-down cleats" is also listed under the standard features and I understand what that is. I mostly just want to know about the "tie-down points" and how they differ from optional "Truck Bed D-Rings".
    Thanks
  2. Feb 16, 2016 at 4:08 PM
    WIDGIN9
    WIDGIN9 Well-Known Member
    Earth, I think.
    2016 MGM 4x4 Limited, 2001 Black 4x4 SR5 Doublecab
    NRA Life Member Sticker, Body Armor 4x4 Step Rail, Leer Trilogy Bed Cover
    I believe the accessory are the d-rings while the tie-down points are the holes and bolts. My 2016 has the tie-down points which are worthless without the d-rings.
  3. Feb 16, 2016 at 4:34 PM
    Prospector520
    Arizona
    Thanks for the reply.
    I should probably just go look at a new Tacoma, but I think I understand what you're describing. The "holes and bolts" that are standard on the trucks are basically just bolts on the floor of all four corners with big steel "washers" with holes in them you can attach stuff to? Sounds like d-rings would be a little easier to attach stuff to.
  4. Feb 16, 2016 at 5:06 PM
    Kawirdr728
    Kawirdr728 Well-Known Member
    Austin, TX
    '18 Red DCSBOR
    I didn't order the d rings, but they came in my bed. One at each corner if I'm not mistaken (2 I know for sure at the back) the only thing I don't like about them is that they don't rotate. They sit about 3/4" off the bed, so sometimes wiggly a tie down in them is a bit difficult.
