Toyota OEM Cargo Divider questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by perkj, Feb 28, 2017.
  1. Feb 28, 2017 at 1:56 PM
    perkj
    perkj [OP] Well-Known Member
    Couple question for you all that have the Toyota OEM Cargo Divider. As I understand it the divider drops into the holders that attach to the rail system. So my questions are:
    1. Can the divider itself be flip up in those holders as opposed to it facing down into the bed?
    2. Can it also be flipped sideways to use as a small platform?
    3. what is the total height of divider section?
    Thanks in advance!
    This is the cargo divider I'm referring to:
  2. Feb 28, 2017 at 5:45 PM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    What are those containers?
  3. Feb 28, 2017 at 6:00 PM
    perkj
    Thanks man, exactly what I needed!
    MilkTeacoma[QUOTED] likes this.
  4. Feb 28, 2017 at 6:07 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    rotopax
    MilkTeacoma likes this.
  5. Feb 28, 2017 at 9:40 PM
    Hiyosilver
    Hiyosilver Have Fun, Will travel!
    Los Angeles, California
    2017 silver DCSB OR
    17" TRD Rims and Ko2 Tires
    This is a great idea!
  6. Mar 1, 2017 at 6:51 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Positioning it horizontally may be useful when you need to get it out of the way to carry some longer items... like 2x4x8's or something. I had not thought of positioning it horizontally until seeing the OP's post.
  7. Jul 12, 2017 at 8:00 AM
    tucsat
    tucsat Member
    Salt Lake City
    2017 Red TRD Off Road Double Cab
    Nothing... yet
    I have this cargo divider and I cannot rotate it whatsoever. if I loosen up the L shaped brackets to rotate I can only get one side to come out the track at a time. Have you had this same problem?
  8. Jul 12, 2017 at 11:41 AM
    MilkTeacoma
    MilkTeacoma Well-Known Member
    You gotta loosen up all the brackets, if it's not straight or lined up, then you will get some binding and won't be able to change the position of the divider.
    GPsevinSixx likes this.
  9. Jul 22, 2017 at 11:37 AM
    Bugmanbrian
    Bugmanbrian Well-Known Member
    Brian
    2018 sport
    Exactly what I am looking for
