Toyota OEM clutch kit or NAPA?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Xbeaus, Oct 21, 2015.
  1. Oct 21, 2015 at 12:35 PM
    Xbeaus
    Xbeaus [OP] Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I am going to need a new clutch put into my 98 V6 5 speed. I do have a lift with 32 x 11.50 tires. Is the stock clutch still a good option? I have about 160k on my pickup right now. I do off-road it occasionally and use in stop and go traffic a lot.
  2. Oct 22, 2015 at 1:02 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Aisin is not bad I bought one from Napa and it was made in China!!
    I think if I needed another new clutch my next would be the Marlin Crawler 1200 pound kit
  3. Oct 22, 2015 at 1:16 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    OEM
    Only OEM.
  4. Oct 22, 2015 at 1:30 AM
    Shepdog08
    Shepdog08 Well-Known Member
    265/70 R16 BF Goodrich A/T's Plasti-dipped factory wheels More to come...soon
    Check out LCE. I've got their pro clutch in my truck and I love it.
  5. Oct 22, 2015 at 7:53 AM
    Xbeaus
    Beau
    I like the marlin crawler idea. Their prices are really good as well. They use some stock Toyota parts with the 1200 kit.
  6. Oct 22, 2015 at 9:05 AM
    orangeoutlaw
    orangeoutlaw Well-Known Member
    NorCal
    2000 Taco ex cab
    2.5 sway-a-way coilovers, camburg 1" uniball uca's, Bilstien 7100's rear, Deaver j59 leafs, Solo Motorsports rear shock hoop relocation kit,Pro comp LA paz 16x8 matte black wheels with Toyo MT 305/70/16, 1.25" billet spacers, diff drop, Exedy stage 1 clutch, warn 9000, bent up bumpers, halo proj headlights, led tails and turns, snug-top, kicker comp 12, infinity kappa doors, kicker amps, painted frame, snug-top shell, yakima high roller bike racks
    I went Exedy, like it so far.
    Wulf likes this.
  7. Oct 22, 2015 at 12:22 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Marlin or OEM.
  8. Oct 22, 2015 at 1:57 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Why OEM and not Aisin ??
    Yes I know you can`t buy the same clutch aftermarket except through Toyota.
    Just curious I really think it pretty much comes down to the driver
  9. Oct 22, 2015 at 2:06 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Not related but my 2 cents. Didn't want to pay $120 for a water pump for my 2001 corolla. Bought a Napa brand for $45. Pulley broke 6 months after having the water pump installed. That left me stranded 75 miles from home. So what did I do? Went and bought a oem water pump from Toyota. I'd buy oem.
    Kpatt9 likes this.
  10. Oct 22, 2015 at 2:07 PM
    Caligula
    Los Angeles, CA
    Aisin is an OEM manufacturer.
    Fallguy6666 likes this.
  11. Oct 22, 2015 at 2:11 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Yes I know this but you can`t buy the same parts through Aisin Aftermarket
  12. Oct 22, 2015 at 3:35 PM
    slander
    Hickory, NC
    Yea you can, Marlin sells aisin clutches.
  13. Oct 27, 2015 at 5:40 PM
    Xbeaus
    Beau
    Went with the Marlin Crawler 1200 Kit. At my local Toyota Dealer the tech who does the work has a few rock crawler toyotas. He looked at the Marlin kit and said it looks like a good kit. I will be spending about $600.00 to get it installed by Toyota. So for a little under 1K for the clutch kit installed. Not bad I think and I don't have to do it myself!
  14. Oct 27, 2015 at 5:51 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    The marten one is a 97 t100 clutch. Feels like stock.
  15. Oct 28, 2015 at 8:06 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I put an Exedy in my w59 a couple of years ago without any issues since. Everything was high quality, on par with the Aisin clutch I put in my first gen 4Runner.
    Wulf likes this.
  16. Oct 29, 2015 at 12:38 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    As long as you can afford the labor more power to you.
    Are you having them change the rear main seal while things are apart??
  17. Oct 29, 2015 at 3:40 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Rockauto.com has good prices on clutch kits, including the Aisin which is OEM. I just installed a luk kit in mine with a new luk flywheel all for under $300 from them. Absolutely nothing wrong with part store clutches though, I've installed AutoZone clutches in 350hp vehicles with zero problems so dont see why you would need anything fancy to handle the 190 ponies the 3.4 puts out.
  18. Oct 29, 2015 at 6:33 AM
    Xbeaus
    Beau
    Yes. I am having them do that as well.
  19. Oct 29, 2015 at 6:46 AM
    Phoenix autoworks
    Phoenix autoworks Stock but fun!!!
    Josh
    North Phoenix
    95.5 Tacoma 4x4 3.4 manual
    Stock but I use it anyway!!!
    1k? That should only be 6 or 7 hundred dollar job. Why so much? Cause dealer?
  20. Oct 29, 2015 at 7:06 AM
    Xbeaus
    Beau
    Yea. I'm having them replace the slave cylinder as well. I don't feel like doing the clutch in my driveway. Lol already replaced everything in the front end suspension wise. Time to let someone else do it! Lol. Plus it's getting pretty cold out where I live. Gonna snow any day now.
