Toyota OEM Receiver Hitches, Class 3, 4 and the Bumper
Discussion in 'Towing' started by WhiteDog, Mar 27, 2018.
  1. Mar 27, 2018 at 4:03 AM
    WhiteDog
    WhiteDog [OP] King of the Brittanys
    Brian
    Central Indiana
    My 2006 gen2 TRD has the factory towing package on it. It appears to be the class 4 HD receiver hitch. It is a terrible shape with 90%+ of the coating peeled (or loose) on it. More rust than coating IMOP. I thought about refinishing the hitch but with sand blasting and coating, I'm up to the cost of a new class 3 hitch.
    The replacement class 4 is almost $1000, too rich for my blood.
    My question is will the factory class 3 hitch mount up where the class 4 hitch resides now? Looking at the bumper, it appears to fasten to the class 4 hitch? Is this the same design for the class 3, or do I need to buy a new bumper if I downgrade to class 3?
    Used class 4 hitches are going for $750+ !!!
    Brian
  2. Mar 27, 2018 at 8:10 AM
    Indy
    Indy Master of all I survey.
    They pretty much all mount to the same location. It should cost about $100. $1000, I can buy 9 or 10 class 4 hitches so I'm not sure where you're shopping.
    But surface rust doesn't affect the strength of a hitch. For $100 I'd rather drop and repaint what I have than buy a new one that's all shiny. I can do some light sanding, spray some 'rust convertor' and spray paint for about $10. Because it will end up looking dirty and rusty no matter what.
  3. Mar 27, 2018 at 8:30 AM
    WhiteDog
    Brian
    Central Indiana
    Indy
    Thanks for the reply.
    Are there 3rd party class 4 hitches for a gen 2 Tacoma? I could only find class 3.
  4. Mar 27, 2018 at 4:07 PM
    Indy
    There were a bunch listed when I googled it, a lot are listed as 3/4 as well and I'm not motivated enough to see why that is. From a more practical standpoint a class 3 exceeds what your taco can do, going to a true 4 or even a 5 if you could find one doesn't do anything for you. No matter what setup you use if the truck maxes at 6500, many class 3 are rated for up to 10k with a wd hitch.
  5. Mar 29, 2018 at 1:29 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
  6. Apr 26, 2018 at 12:43 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    I'm in the same boat - my truck is getting a new frame next week an I'm not sure what to do.
  7. May 30, 2018 at 5:46 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    What have you done? I too am in the same boat, with a Frame recall job coming, and my factory hitch looks nearly as bad as the frame.... what did you buy?
    BTW - did you Recall frame come with the Lower Control Arms - on the front suspension ?
