Toyota Oil Pan Crush Washers Suck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loco38SUP, May 22, 2015.
  1. May 22, 2015 at 12:25 AM
    Loco38SUP
    Loco38SUP [OP] Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Did Toyota change the design of their crush washers recently? The last few received from the dealership loosened up and were leaking oil. At first I thought the drain bolt wasn't torqued properly but on the next oil change, I made sure it was plenty tight. I remember that they used to be blue on one side but the new ones are black on both sides.
    I decided to switch to the Nissan crush washers I had left over from a Frontier I used to own. The seal is much better and after 3000 miles there are no leaks. The part number is: 11128A http://www.courtesyparts.com/11128a...u-1998-2004-p-58770.html?cPath=2129_7649_9121&
    RJM
  2. May 22, 2015 at 1:16 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Strange, I have never had one to leak. I am partial to the older solid brass type, which I never replaced. I reused the one on my wife's old Camry for 187,000 miles and changed the oil every 3000 miles.
    That Nissan looks to be a brass crush washer, Is it brass?
  3. May 22, 2015 at 1:45 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Missed read the title to stuck washer. My friends rsx type s ways seems to fuse the washer to the bolt. Every oil change we need to bang it off with two screwdrivers and a hammer. But I'm getting off topic.
    Never have I used a new washer in the past 5 years of oil changes, with no leaks. Yes I'm too cheap to buy a new one because Toyota never included one with the filters I bought nor did the eBay seller I bought bulk filters from....my friends Honda dealer always includes a washer with oil filter tho. :crapstorm:
  4. May 22, 2015 at 4:44 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    OEM engine oil drain plug gasket part number is 90430-12031
    The following(URL at bottom of post) work just fine and are available at many mass marketers like O'Reilley's. I've lined them up with the OEM part above and I see no difference. 3 part numbers show up at the Dorman URL below. 2 are the same - the only difference being the count-per-package. I asked Dorman what was the difference between the 2 unlike part numbers since their specs were the same? Their reply follows and is in bold:
    They are all the same parts.
    We sell these under different lines and it would depend on which line the particular seller wants to stock.
    But they are all exactly the same.
    Thank you
    http://www.dormanproducts.com/gsear...oma&parttype=Oil Drain Plug Gasket&origin=YMM
  5. May 22, 2015 at 5:49 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    in over 33 years of changing oil on my vehicles I never change the oil
    plug washer, I reuse the same one that is always there...never ever had one single drop leak
    your mileage may vary
    Arctic Taco likes this.
  6. May 22, 2015 at 6:24 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Same here minus the 33 year part. I just reuse what's up there and never had one drip either. Nice find though on a new alternative for those who may be interested.
  7. May 22, 2015 at 6:28 AM
    Tacomamba
    Tacomamba Well-Known Member
    albq
    2013 Baja Edition Black
    Supercharger Roof rack Tube step Entune Tailgate mod ATC Camper OE Skid Plate K/N filter don't need anything else
    Your crush washer is sitting in wrong direction. The crush is what sits between washer and drain hole. At least in the picture below it is sitting in wrong direction.
    patbegley likes this.
  8. May 22, 2015 at 7:01 AM
    Kysport
    Kysport Well-Known Member
    Louisville, Kentucky
    2020 Silver Sky Metallic Limited
    Just switch it out with a Fumoto drain valve next oil change. I've been using them for many years. I never go off-roading but they even make a new style valve for those that do.
  9. May 22, 2015 at 7:06 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Same, but only around 15 years..
  10. May 22, 2015 at 7:15 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    ^This^ it's upside down in the picture. Lol
    I hate those stupid Nissan washers... They're such a pain in the ass to get off the plug when u want to change it. I prefer the Toyota ones and I've never had one leak.
  11. May 22, 2015 at 7:52 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I usually use a new crush washer with no issues. I've reused crush washers many times with no issue. I just installed a Fumoto valve yesterday during my 15K oil change. First time using the Fumoto. I have an RCI skid that protects the Fumoto valve so I'm not too worried about it. And I do go off road. I put the OEM drain bolt and washer in a mini zip lock baggie, labeled it, and put in the glove box just in case. Going to Moab on Monday so we'll see how well the Fumoto holds up but I'm not expecting any issues as they've been around a LONG time now and I've never heard a complaint yet.
  12. May 22, 2015 at 8:49 AM
    Loco38SUP
    North Seattle, WA
    The washer is made out of copper. The metal ones are nice since they hold up better over time. On my Frontier I would change it once a year and never had the drain bolt loosen up or leak.
    RJM
  13. May 22, 2015 at 1:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    never had any issues on mine. But it gets a new OEM rubber crush washer every oil change as i have 10 of them that came with 10 oil filters i bought.
  14. May 22, 2015 at 2:29 PM
    Pigpen
    Dan
    Northwest Montana
    I went Fumoto. It sits tucked up nicely under my Pelfreybilt IFS skid.
  15. May 22, 2015 at 6:49 PM
    oldstick
    oldstick Medicare Member
    GA
    Same here, 33 years thereabouts as well, with a dozen different vehicles or more. Never changed a washer and never had any leak from the oil plug. The economy being what it is, just something else to convince you is mandatory to replace. Kind of like spark plugs every 30K and many other examples.
