Toyota Oil, Synthetic vs Conventional for short trips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yurizx6r, Oct 22, 2017.
  1. Oct 25, 2017 at 10:02 AM
    #81
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Show me your sources of that.
    Show me the science that says synthetic lubricates any better than the exact weight conventional oil at the correct OCI.
    Talking daily drivers here, not professional race cars or diesel trucks.
    Read CH 4:
    https://bobistheoilguy.com/motor-oil-101/
  2. Oct 25, 2017 at 10:38 AM
    #82
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    I'm confused @PackCon. Your source and link directly contradict your position and completely supports synthetic as being a better oil. And for more reasons than OCI. A few of them (from your link) being:
    Start-up temperatures
    Cold temperature performance
    Ability to maintain similar viscosity over a wide range of temperatures
    I don't know if it specifically "lubricates" better, but apparently it performs better. What am I missing?
  3. Oct 25, 2017 at 10:48 AM
    #83
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Not necessarily. i see the world "overkill" used in that article at least 2-3 times. The cold temperature thing is true, but it was noted at below 0 degrees at startup where synthetic kicks in and has the advantage. (where does the OP live? that might help in his decision.)
    If he lives in a relatively warm climate and changes his oil regularly (5k) there really is no advantage to using synthetic from how I read that article, but I am no oil expert
  4. Oct 25, 2017 at 10:50 AM
    #84
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I don't disagree. But I was selfish and read it from my perspective and not OP's. I live in a cold climate where below freezing and below zero temps are common.
    Shwaa[QUOTED] likes this.
  5. Oct 25, 2017 at 11:40 AM
    #85
    PackCon
    Connor
    No it doesn't. He states:
    Synthetics may have same advantages in extreme weather coditions (ie below -30F), turbo charged engines, race cars, and when one wants to increase OCI.
    Daily driving really makes no difference.
    Other parts of the site go on to discuss studies done by Blackstone Labs on various differences between conventional and synthetic. Their studies show as long at the oil is changed at its intended intervals there is no difference in engine protection. Of course this means outside of the factors listed above.
  6. Oct 25, 2017 at 11:41 AM
    #86
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Ahh...these engine oil threads never get old :D
    Some people seem to be stuck several decades in the past where the struggle of finding a good engine oil was more of a reality.
    These days, however, pretty much any oil that meets the minimum specifications required for the vehicle will be ok. So much has evolved in the oil industry. Heck, I've even seen guys running the walmart brand of engine oil for tens of thousands of miles with no issues:eek:.
    With regular dyno oil, changing the oil and filter at regular intervals is more important than the brand of the oil (as long as it meets the specs required for the vehicle). Synthetic can go longer...which minimizes waste.
  7. Oct 25, 2017 at 12:40 PM
    #87
    Yurizx6r
    Yurizx6r [OP] Well-Known Member
    2015 Pre Runner, TRD Sport
    I believe I owe everybody an apology at this point. Lol I just wanted to know what all the high milage Taco guys ran and if it would protect the engine better for short trips, but instead this evolved into another oil debate.
    koditten likes this.
  8. Oct 25, 2017 at 1:13 PM
    #88
    Shwaa
    Bay Area, CA
    So what did you decide?
    :popcorn:
  9. Oct 25, 2017 at 1:51 PM
    #89
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    buy the most expensive oil and be happy wasting your money
    DGXR, Sig45, asuchemist and 2 others like this.
  10. Oct 25, 2017 at 3:23 PM
    #90
    Yurizx6r
    I have 2 free oil changes from the dealer for buying my truck. So I'm just going to roll with the 5W-30 synthetic. I see no reason not to especially when it's free. In order to keep the warranty, I'm going to stick with the recommended change intervals, but once the free oil changes are up I'm going to do it myself, keep my receipts, and document that it was done by a buddy of mine who is working on his ASE certification right now.
  11. Oct 25, 2017 at 3:25 PM
    #91
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Not sure how many sources you need me to give you for you to realize your wrong but here ya go. If you actually read it you will find that it also states that synthetic oil molecules are much more round and similarly shaped than conventional thus providing better and longer wear protection.
    https://www.google.com/amp/www.hotrod.com/articles/synthetic-vs-conventional-oil/amp/
  12. Oct 25, 2017 at 3:57 PM
    #92
    PackCon
    Connor
    Your reference does not show that synthetic oils protect an engine from normal wear and tear as opposed to conventional. They assume that but don't show it.
    It states they last longer because of its properties so in other words longer OCI.
    For normal everyday driving there is no evidence synthetic protects an engine more than conventional provided they are changed at the correct interval.
  13. Oct 25, 2017 at 4:05 PM
    #93
    757yotas
    Virginia
    2007 TRD Sport
    Do your own research buddy, im not going to waste my time anymore doing it for you when i did it for 2 years in tech school. Its a proven fact that synthetic is better at protecting against wear cold and warm. If you want to put crap in your truck to save 5 bucks then go ahead lol
  14. Oct 25, 2017 at 4:29 PM
    #94
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    The fun oil threads.
    Follow the intervals recommended by Toyota.
    Use only TOYOTA branded oils. Only oil you should ever put in your truck. :homer:
    ___
    TRUST ME I AM A CHEMIST
    Blockhead likes this.
  15. Oct 25, 2017 at 4:36 PM
    #95
    scocar
    scocar Patron of the Farts
    digdug1, tgordo49, blu92in99 and 2 others like this.
  16. Oct 25, 2017 at 5:27 PM
    #96
    PackCon
    Connor
    Don't pick fights with people when you can't hold on an intellectual discussion about it. Don't call people out for being stupid while making general sweeping statements.
    Saying synthetic is better is so general it holds no meaning. Better for what? Wiping your ass?
    Specifics are important. The OP isn't an ice trucker with a turbo diesel, and he doesn't drive 200mph to work with a heavily modified engine.
    Your article talked about the benefits of extreme temp differences as well as the benefit of using a synthetic lower weight oil over a conventional. Never showed 5w-30 synthetic made any difference over 5w-30 convention at intended OCI.
    They must not teach science in tech school.
  17. Oct 25, 2017 at 5:55 PM
    #97
    757yotas
    Virginia
    2007 TRD Sport
    Id trust a tech school taught buy 30 year ASE techs and countless manuals and the companys that produce the product over a guy with zero qualifications on an online forum haha. Here is an artical buy Amsoil and it literally says "Synthetics don’t contain the impurities and molecular irregularities inherent to conventional oils." in the 1st few sentences. Its not made up bull shit buddy its a fact. You need to pull your head out of your rear end and accept that you were misinformed and move on while learning something new.
    https://www.amsoil.com/about/synthetic-versus-conventional.aspx
    Oh and here is that "Lab testing" you keep flapping your wings about.
    https://www.amsoil.com/lit/g3320.pdf
  18. Oct 25, 2017 at 5:58 PM
    #98
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Damn!
    I guess we are done with rational comments. Time to unsubscribe.
    KO
    Out!
    757yotas likes this.
  19. Oct 25, 2017 at 8:54 PM
    #99
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Guess I'll forget about asking about synthetic blinker fluid.
    757yotas and Yurizx6r[OP] like this.
  20. Oct 26, 2017 at 4:50 AM
    #100
    stolleee
    stolleee Well-Known Member
    Memphis
    2012 Tacoma Supercharged and 1970 Toyota FJ40
    Fox shocks, TRD Supercharger, leather, wheels/tires, exhaust, audio.... etc....etc
    slitespd and Yurizx6r[OP] like this.
