Toyota platinum warranty cover TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TDubber, Dec 11, 2012.
  1. Dec 11, 2012 at 11:40 AM
    TDubber
    TDubber [OP] Well-Known Member
    Dale
    Pinole, CA
    2017 DCSB MT
    Sweet ones.
    Just like the title states. The dealer said my TPMS sensors aren't communicating with the system even after a reset. I have the platinum warranty, would this be covered? I can't find the info online or in my stupid little warranty packet. Just thought someone would know.
    Thanks.
  2. Dec 11, 2012 at 4:10 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    They should be covered. They are not a wear item.
  3. Dec 11, 2012 at 4:18 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Maybe yes/maybe no. TPMS sensors have batteries, and since you have an 08 it may be one or more batteries died (life is suppose to be around 5 years give or take) - don't know if platinum warranty covers or not, and on the other hand, may be something besides batteries, which MAY be covered.
  4. Dec 11, 2012 at 4:20 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Take it to a tire shop. How does the dealer know that they are not working?
  5. Dec 11, 2012 at 4:31 PM
    TDubber
    Dale
    Pinole, CA
    2017 DCSB MT
    Sweet ones.
    Long story short, I had it in there after 6 other visits to get spacer/wheel/tire issue worked out. After I got everything finally squared away, TPMS light came on. Took it in to be "reset" and they told me its more of an issue than that and I need to take it to the dealership I bought it from (an hour drive away). Figured I could just make them fix it if it was covered. But being my first "new-ish" vehicle with a warranty it's new to me to have a dealer fix something free of charge. Also new to the tire pressure sensors.
  6. Dec 11, 2012 at 5:08 PM
    uhmmmar15
    uhmmmar15 Active Member
    Uhmmm
    Texas
    I would just take it to discount or tire shop that deals with TPMS sensors I remember when I worked at Toyota I would replace the sensors and then hook up computer to the OBD and reprogram take maybe about 5min to dismount the wheel from tire to switch the sensor out and maybe another 5minutes to reprogram the sensor to the computer and charge the customer 1.2hours!
  7. Dec 11, 2012 at 5:19 PM
    uhmmmar15
    Uhmmm
    Texas
    for labor and then another $100+ on sensor
  8. Dec 11, 2012 at 5:20 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Get the dealership that's been working on the spacer/wheel/tire issue to fix it... sounds like they damaged one.
  9. Dec 11, 2012 at 6:13 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    That.
  10. Dec 11, 2012 at 6:16 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    this and the sensor should be warranted. does the tire pressure light not flash?
  11. Dec 12, 2012 at 8:10 AM
    TDubber
    Dale
    Pinole, CA
    2017 DCSB MT
    Sweet ones.
    It flashes when turning on the truck then goes solid after ~30 seconds.
    Thanks for the suggestions. I just was thinking if they are covered, I can go to a dealer close to me and get it fixed for free. Save time and hassle.
