Toyota platinum warranty (up to 100k), AC compressor dies at 98,6xxx.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jedirye, Aug 17, 2020.
  1. Aug 17, 2020 at 7:41 AM
    jedirye
    jedirye [OP] Wannabe
    Florida
    2013 Baja Supercharged
    I guess this is one of those warranty stories. I had blinking orange AC light, did minir trouble shooting but have extended warranty so took to dealership. Apparently it was my AC compressor, so somewhat expensive job.
    I'll only be paying for extra labor associated with taking supercharger off, etc. as they consider it aftermarket. It is a TRD SCer installed at dealership at like 700 miles on truck and had a warranty though. I might followup on that....
    But regardless, everyone has their own warranty stories, pro's, con's, etc. I'm fanatical about them for peace of mind and I'm not mechanical. This is just one of those stories lol
    TreeFortRichard and Jimmyh like this.
  2. Aug 17, 2020 at 2:08 PM
    jedirye
    Florida
    So they recommend flushing the system, but said I could monitor, etc. Flushing is like $280 and not covered by warranty. Is it necessary? Thats a lot of money...
    Also probably because its the temperature of the sun everywhere, the AC clutch assembly is on backorder... tear drop...
  3. Aug 17, 2020 at 2:14 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What happened to the compressor?
  4. Aug 17, 2020 at 2:14 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    A flush is wise anytime the system is opened due to a component failure because of the risk of FOD. If they replace the compressor and dont flush, but instead just recharge, and it fails again soon after they may blame it on debris that was in the system from the previous compressor failure and not warranty the new compressor. In fact, I believe most compressor warranties are only intact if the system is flushed AND receiver/dryer is replaced with new. This should have been made clear to you before you agreed to replacement. Also, did they give you any troubleshooting info about how they determined it was the compressor? A flashing AC light could certainly be the result of a bad compressor, but it can also be the result of a bad AC clutch, or simply a corroded ground wire at the clutch. AC clutch labor is about 30 min for a dealer or familiar mechanic.
    69 Jim likes this.
  5. Aug 17, 2020 at 2:26 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Curious as to why the SC has to come off. The A/C compressor is removed from below or through the driver's wheel well.
  6. Aug 17, 2020 at 2:46 PM
    jedirye
    Florida
    Honestly, they didn't give me much info ref. compressor. I read the numerous things it could be, but didn't know how to switch those relays people were taking about and figured the dealer would know.
    Whether or not the AC conpressor was "really" the item, or dealer fluff, either way I figured I'd be getting a new one under warranty? Could they be lying?? Maybe? I don't know. Not mechanical.
    So the super charger doesn't need to be removed for the conpressor and clutch assembly?
  7. Aug 17, 2020 at 3:00 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    No need to remove the supercharger to remove the A/C compressor. They are fleecing you.
    TreeFortRichard likes this.
  8. Aug 17, 2020 at 4:27 PM
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    Yet another stealership problem. Lawyer up.
  9. Aug 18, 2020 at 4:03 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Lawyer up to fight an estimate for ~ $280?
  10. Aug 18, 2020 at 4:11 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The most American response ever :rolleyes:
    TegoTaco, ace96, 69 Jim and 3 others like this.
  11. Aug 18, 2020 at 4:50 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LOL. No....
    whatstcp likes this.
  12. Aug 18, 2020 at 5:15 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I replaced the compressor clutch on my supercharged 2013, the main blower you don’t have to touch, but I did have to remove the fan, fan shroud, and s/c belt tensioner to access the bolt on the clutch, if I remember correctly I had to remove one of the lower idlers for the s/c belt as well to access the serpentine belt tensioner.
  13. Aug 18, 2020 at 7:32 AM
    dlopan
    Dave
    Albuquerque, NM
    It's not 400, it's free the first time. Always protect your rights.
  14. Aug 21, 2020 at 3:59 PM
    jedirye
    Florida
    Is there some Toyota verified place that I can see that you access compressor from below?
  15. Aug 22, 2020 at 10:25 AM
    jedirye
    Florida
  16. Aug 22, 2020 at 10:55 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    seriously?
    Jimmyh likes this.
  17. Aug 23, 2020 at 8:39 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    This is me replacing my a/c clutch...it's all Fan/Fan shroud and belt...and a lack of proper tool...and a sore hand...
  18. Aug 23, 2020 at 8:48 AM
    TreeFortRichard
    Brian
    BTW did you get your front wheel bearings replaced yet? Check them for play and say they sound 'grindy' if they are covered...get a new set :) ...also check the steering linkage for rust...they crap out too (although you're in Florida? so no salt..)
    jedirye[OP] likes this.
  19. Aug 23, 2020 at 9:00 AM
    jedirye
    Florida
    As an update, they said the tensioner for the SC belt was in the way of removing the AC compressor.
  20. Aug 23, 2020 at 9:01 AM
    jedirye
    Florida
    Need more.... "tips" lol
