Toyota PowerTrain Warranty
Discussion in '3rd Gen. Tacomas (2016-2023)' started by truckguy101, Dec 7, 2023.
  1. Dec 7, 2023 at 4:35 PM
    truckguy101
    truckguy101 [OP] New Member
    My 2019 Tacoma, with 53k, had the engine go out. Most likely a leaky head gasket, from what they said. It was running fine, I stopped to do some errands. When I started it up, it popped,
    and blew smoke. When they looked at it, they said no compression in the cylinders, and the crank case was full of coolant. When they took it apart, the found a cracked cylinder. Rather than replace the engine, Toyota is rebuilding the engine. This is not what I expected from the warranty. This is my third and last Tacoma.
  2. Dec 7, 2023 at 4:37 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    :santa::popcorn:
    batacoma likes this.
  3. Dec 7, 2023 at 4:43 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    No way your truck is a 4cyl. What you got a V6?
  4. Dec 7, 2023 at 4:46 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I doubt they're rebuilding your bottom end. It's not practical to repair the cylinder liner.
    Toyota doesn't sell a long block. So you're likely getting a new short block and they're reusing any parts that are still OK from your current engine.
    cwdog, Chew, BLtheP and 1 other person like this.
  5. Dec 7, 2023 at 4:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Lots of people are saying that after seeing 2024 prices...
  6. Dec 7, 2023 at 5:02 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Any any other new vehicle.
  7. Dec 7, 2023 at 5:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    You can't 'rebuild' a cracked cylinder. Either something else was broken or you misunderstood the diagnosis.
    You're expectations were most likely incorrect. Read the warranty document carefully. It sounds like you are being repaired, which is what the warranty offers. Did you expect a whole new engine or something?
    That's fine. Keep in mind that all marquees have problems and all OE warranties are quite similar in the nature of what they will and won't do.
    Chew, Canadian Caber and auskip07 like this.
  8. Dec 7, 2023 at 5:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    This is probably a miscommunication or misunderstanding. As stated there is no such thing as a long block for this engine. They probably have determined all it needs is a short block. The standard procedure is to replace anything broken and reuse whatever else. I doubt there would be much better luck with other brands and their respective warranties.
    Chew and Canadian Caber like this.
  9. Dec 7, 2023 at 5:10 PM
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    Good call, no other truck manufactured has had a cracked cylinder before :thumbsup:
    Chew likes this.
  10. Dec 7, 2023 at 5:19 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I wonder what he expected from a warranty?
    Chew likes this.
  11. Dec 7, 2023 at 6:07 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    I guess it’s a huge disappointment or let down when Tacoma’s are constantly referred to as “bulletproof” “dependable” “rugged” “reliable” “high quality” and something like this happens.
    Preventive maintenance is very important to achieve longevity. However, shit happens and stuff like this happens with any mass produced vehicle.
    My brand new 1992 extra-cab V6 5spd 4x4 Toyota truck blew the head gaskets twice. Once under warranty and again out of warranty. Toyota and the dealer fixed them both times no charge. Did not know this was a common issue with the 3.0L back then.
    Kept the truck and enjoyed it for 14 years with no other issues. Just regular maintenance. Sold it for great resale too. Was a little shocked at that.
    Sorry OP, sucks that it happened to you. Luck of the draw and shit happens to the best of us.
    Sounds like they have you covered with a short block.
  12. Dec 7, 2023 at 6:14 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    While it sucks,,, there were a few million or more of these engines made, so a rational person would figure one or two,, or a few hundred would go up in smoke.
    Think of how many people that are in a serious financial jamb, because their out of warranty vehicles have had catastrophic engine/trans failures,,, so there's that to be thankful for this holiday season.
