toyota rear axle compatabilities
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Aug 25, 2009.
  1. Aug 25, 2009 at 5:19 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i have an 02 non trd tacoma. could i take any 1st gen rear axle that has a locker and swap it out with mine so id could have a locker.
  2. Aug 25, 2009 at 5:20 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    yes
    but if the gears in the front dont mach the rear you will need to change them so they match
    also you need to get the wiring harnest that connect the rear locker accuator to the locker swich
    and a swich also
  3. Aug 25, 2009 at 5:30 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    where can i get the harnesses...and how can i see if the gears match
  4. Aug 25, 2009 at 5:38 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    for the harnest id check all the local junkyards
    or ebay
    and as for the gears go by this:
    For "open" diffs:
    Block the tires at one end of the vehicle to keep it from rolling, and then jack up a tire on the other end.
    Place the transmission in neutral and release the parking brake if you are checking the rear diff.
    Spin the tire exactly TWO full revolutions while at the same time counting exactly how many revolutions the driveshaft spins (marking the driveshaft and tires beforehand will make it easier to count revolutions).
    The number of revolutions the driveshaft spins is your gear ratio.
    If it spins just over 4 times, then the ratio is probably 4.10; 4-1/3 = 4.30; 4-1/2 = 4.56; just under 5 = 4.88; 5-1/3 = 5.29, etc.
    For limited slip (LSD or "posi"), locking differentials, spools, etc.:
    With these types of diffs, you won't be able to turn one tire w/o the tire on the opposite side of the axle turning with it.
    In this case, follow the directions above except raise both tires off the ground and turn them exactly ONE full revolution while counting driveshaft revolutions.
    Again, the number of driveshaft revolutions is your gear ratio as mentioned above.
  5. Sep 2, 2009 at 6:04 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    what is the difference between a locking differential and a limited slip or are they the same. what are the benefits to having either??????????????
  6. Sep 4, 2009 at 8:33 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    Both tires are locked together with a locker and with a LSD the diff uses a clutch pack to transfer power to the wheel(sometimes wheels) that need it. The negative to a LSD is that the clutches wear out quickly, very quickly if used in wheeling situations. Lockers are the way to go as long as they are selectable, not good on the street if they are not selectable.
