Toyota Rear Axle Truss
Discussion in 'RuffStuff Specialties' started by Dan Fredrickson, Jan 27, 2014.
  1. Jan 27, 2014 at 11:51 AM
    Dan Fredrickson
    Dan Fredrickson [OP] Steel Hauler Vendor
    Dan
    Sacramento/Flagstaff
    '66 FJ45
    Here we are, along the same lines of all our Crowned Trusses. This is the truss all Toyota guys have been waiting for!
    This one, just like all of ours is shaped for maximum strength. The Crowned back will help keep your axle straight for years to come and if you combine it with the top truss you can feel free to jump it!
    The truss is made from 3/16" steel and the fill hole access port completely protects the plug. They are meant to be welded full length. Start in the middle with 4" welds on top and bottom then heavy tack it everywhere. Then work from the outside in with 3" stitches alternating top to bottom until done.
    These are slightly thicker than the housing and will definitely make that axle last til you are ready!
    Toyota Mini Rear Back Truss - RuffStuff Specialties
    DistortedAxis likes this.
  2. Jan 27, 2014 at 6:26 PM
    rcfreak201
    rcfreak201 Well-Known Member
    Is this kit for 2005+ tacomas? If so I'm interested.
    And has there been any real world testing with this kit?
  3. Jan 27, 2014 at 6:46 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    X2
  4. Jan 27, 2014 at 6:48 PM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
  5. Jan 28, 2014 at 7:06 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
  6. Jan 28, 2014 at 7:07 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Looks good but has any testing been done for it?
  7. Jan 28, 2014 at 8:42 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    This is the same truss we have been using for 5 years on all of our axles and it is the same except in one area. The difference is we made it thicker. It is 3/16" thick.
    We have used it on the very similar Ford 9" for 3 years without failure. It has been on 50% of all of our housings that have went out the door (Over 900 housings) in that time.
    It will not fit the newest housings with the 3.25" tubes, it is for the 3" axles. We will have a 3.25" model in a month or so...
  8. Jan 28, 2014 at 10:41 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    if this fits on my 2007 Taco, Im getting it! Taking measurements tonight.
  9. Feb 3, 2014 at 1:53 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Whats the word?
  10. Feb 3, 2014 at 1:54 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    forgot to take measurements that night :eek:
  11. Mar 6, 2014 at 8:06 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    When you need the right stuff, there is only one place to go! RUFFSTUFF!
  12. Mar 6, 2014 at 8:48 AM
    05TacoRunner
    Peoria, Az
    Have we determined if it will fit the second gen Tacoma axle yet?
  13. Mar 7, 2014 at 5:42 AM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Ventura, CA
    07 4Runner
    I don't think it will work on 2nd Gen Tacomas, I think they use the "8.4" diff that has the bearing back brace and deep bump on the back of the housing. Would be a lot of cutting and grinding to get it to fit.
    I put one on my 4th Gen 4runner housing, had to do a little grinding and I got it to fit BUT 4 runners use the "V6 8" diff"
    [​IMG][/
  14. Nov 19, 2014 at 9:42 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Time to get that axle build going!
  15. Nov 19, 2014 at 10:30 AM
    looks great.
  16. Nov 20, 2014 at 8:14 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Loving the weld on those as well :)
  17. Mar 14, 2016 at 5:07 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    The 8" Is already a strong axle for it's size, but help the housing hold everything together for even more abuse! :)
  18. Jan 7, 2017 at 8:06 PM
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    Hey Dan, any word yet on a version for the larger Tacoma/Tundra 8" axles?
