Toyota Recall on 3rd light gasket issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harley1340FXDG, Jun 10, 2022.
  1. Jun 10, 2022 at 4:00 PM
    Harley1340FXDG
    Harley1340FXDG [OP] Member
    Hi All
    My 2017 TRD Sport.....received a recall from Toyota Canada that there is an issue with the 3rd light gasket that can cause water insert the cab etc.....that they will change the gasket at "No Charge"....yeah right....my gasket is split on top of the gasket and maybe let water in the lens or something...so 2 weeks ago i've went to my nearest Toyota dealer from my place...lot of peoples told me their service there is so so...but when you don't know you don't mind that much....so i've took an appointment and drive 1h from my place to go there + the time i've lost at work...they took my taco inside....the guy told me it would take around 1h to change it...ok i'll wait....30 min after a guy came to me and told me we can't fix your taco your lense is broken....and i said so ?? probably the water that the gasket let enter or something broke the lens ?? he said it is not covered by the recall and we will take another appointment and the lens will cost you 250$ plus tax...it's not really a $$$ thing the problem but the waste of time and probably broken cause of their faulty gasket or they broke it when they tried to change it during the 30 min it was inside the garage...i said it's ok i'll fix it myself and you can check out my face for the last time in this dealer......was wondering if i was the only one that the charge of a new lens was happening to ??? or it is a kind of way to just have to change the gasket of 10$ and after let the client pay the bill finally ?? i've found a new gasket on internet and a nice smoked light lens for 120$ Can. at my place...just hope it will do the work though.....you can be sure next time i'll contact another dealer.
  2. Jun 10, 2022 at 4:18 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I’ll never understand why people will go out of their way to drive 1 hour or more to a dealership that they don’t fully trust/know
  3. Jun 10, 2022 at 4:20 PM
    Harley1340FXDG
    Cause the others are 3-4h from my place..and i'm not sure if they're better....but in the future i'll have to consider something
  4. Jun 10, 2022 at 4:25 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The broken gasket isn't likely the reason for the broken lens. Even if it was, good luck proving it. The campaign doesn't cover the lens itself, just the gasket.
    They're not just replacing the gasket, they have a whole new way of putting the 3rd brake light on. New plastic and gasket and glue, etc. I believe mine took about 3 hours.
  5. Jun 10, 2022 at 4:35 PM
    Harley1340FXDG
    Yeah i know i'll not win my point with it...but it's only when the crack in the lens is right where the crack is in the gasket and they only things that goes on my bed liner with a leather cover is my grocery bags ...i'm used to do 95% of my mechanic chores so i think i'll continue....the point of my thread was just cause i was curious if someone else then me had the lens broken issue too...
  6. Jun 10, 2022 at 4:49 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    same thing here in Colorado. Broken lens on the passenger side obviously from initial install. No leakage. So the dealer tells me they will replace the broken tail light at my expense. No water damage = No way they will cover the cost under LRC. Bought it online and did the work myself (about 2 hours of time) but dealer won't sell me the trim plate because I would not let them do the replacement. You must do the LRC to get the trim and the dealer will not sell otherwise (at least here). Spent about $80 USD to replace part. Dealer wanted about $750 to replace part with trim. Total screw job. IMO - just buy the replacement part and use Marine RVT to seal around it once installed. GL.
  7. Jun 10, 2022 at 4:51 PM
    RedWings44
    Michigan
    I mean, it is entirely possible (depending where you live) that water got in and froze, causing the damage. However, I suspect you'd also see water damage on the headliner as well.
  8. Jun 10, 2022 at 4:58 PM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    "Thanks for taking a look at it, however it wasn't broken when I arrived, now please get your supervisor for me."
    Be polite, be professional and walk that shit up the ladder.
  9. Jun 10, 2022 at 5:00 PM
    Harley1340FXDG
    Exactly what i'll do...thanks for your reply.....i've bought this gasket https://www.amazon.com/MbuyDIY-Compatible-2016-2019-Assembly-single-sided/dp/B08BY9X61W?th=1 and i'll had a good sealant to it and install a smoked lens found also on Amazon and check once a while if it does the job
  10. Jun 10, 2022 at 5:06 PM
    GoldenBrew
    Golden, Colorado
    I replaced the entire assembly - the gasket was part of the lens. The Toyota replacement part (lens) includes a new- thicker gasket. THE LSC uses this part and covers the marine rtv with the trim. There is another thread on this subject which has a link to the Amazon seller for the new revised part.
  11. Jun 10, 2022 at 5:34 PM
    GoldenBrew
    Golden, Colorado
    here is the revised Toyota part number for the lens 81570-04051 probably find it on ebay or equal.
  12. Jun 10, 2022 at 5:41 PM
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    Wouldn't they replace the gasket and put your broken lens back on? Or just give you the gasket?
  13. Jun 10, 2022 at 6:48 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Had mine done in 3hrs from the dealer easy peasy of course I didn’t go in with a cracked/broken lens:notsure:
