Toyota recalling 228,000 Tacoma's due to oil leaks and possible loss of control of vehicle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1ChrisRuck, Apr 27, 2017.
  1. Nov 16, 2017 at 2:16 PM
    #4261
    iiitsmikey
    iiitsmikey Well-Known Member
    Sarasota fl
    2017 MGM SR5
    My paperwork says they gave me a new diff. The last time I went, then just changed the gasket.
    nDub[QUOTED] likes this.
  2. Nov 17, 2017 at 7:20 AM
    #4262
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Back in! A couple months back they just re-torqued, the weeping began again soon after, they
    said earlier that all parts are in so I'll have it back later today. It was a pain in the ass, had to go
    back and forth with them because they stated "we did this already and you're back and this is outside
    of the recall". I said, No, you didn't perform the recall work, you cleaned and tightened the bolts and
    the issue is back, you need to fix it. He stated I need to speak with the manager, left for 15 min. came
    back, reworked the service order so they'd get paid for a job they failed to do right the first time.
  3. Nov 17, 2017 at 3:00 PM
    #4263
    Taco351
    Taco351 Well-Known Member
    Robert
    NLR/Sherwood
    2017 Tacoma Double Cab 4X4 TRD Off-Road White
    K&N air filter/LED lights/Magna Flow Muffler/TOYO AT2 Tires and lots of fun stuff.
    After reading these posts, I bet they are replacing the differential housing; not the entire axle. I wonder if part of the issue is a casting problem with the differential housing. Does anyone know if the problem is the gasket or over torquing the nuts? I've stated earlier, 18 ft lbs on a differential housing seems really low.
  4. Nov 17, 2017 at 3:56 PM
    #4264
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    The Toyota Official procedures is:
    1. No leaks, re-torque and send you on the way.
    2. Signs of any leak, seep, etc. Drain Diff fluid and measure amount drained. If it is above a certain amount, new gasket.
    3. If it is less than a specific amount (meaning loss of fluid) equals new diff.
    Many dealers blew customers off and ignoring weeps and seepage which was against the Toyota Official recall instructions. Now because of this, Toyota will probably have to replace more diffs than if the dealers took care of it correctly the first time.
    Toyota Corp through a press release said they introduced a "new re tightening" procedure in march of 2017. This indicates the Asian factories these axle/rear end assemblies were made were not torqued properly in the first place.
    Taco351[QUOTED] likes this.
  5. Nov 17, 2017 at 4:37 PM
    #4265
    Taco351
    Robert
    NLR/Sherwood
    I thought I read the Tundra and Tacoma rear ends are manufactured in Marion, Arkansas.
  6. Nov 17, 2017 at 4:50 PM
    #4266
    baron55
    More Like assembled there. They assembled the rear ends with all the parts made China/Asia
  7. Nov 18, 2017 at 2:55 AM
    #4267
    BlkTaco47
    BlkTaco47 Unhinged
    Still no repair :( another typical visit with Haley Toyota of Richmond Va. .... Called
    after 8 hours of having the truck with a promise this time it would get done - nope!
    "sorry we forgot to get to it, it's still out in the lot and never made it in" Worst dealer
    I've ever dealt with from purchase to this visit.
  8. Nov 18, 2017 at 3:48 PM
    #4268
    rz2mbc
    rz2mbc Well-Known Member
    This leaking diff B/S was the last straw for me......went in to the Toyota place with appox 7500 miles on truck, NO LEAKS. So they sent me on my way. Noticed a spot on driveway at 9000 miles. Went back to Toyota and they stated we will keep the truck till parts arrive to fix issue.......NO IDEA OF TIME FRAME. After NUMEROUS issues with this crap truck I got rid of it.......have not looked back.
  9. Nov 18, 2017 at 3:49 PM
    #4269
    rz2mbc
    TRADE IT !!!!!
  10. Nov 18, 2017 at 3:50 PM
    #4270
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Oh Brother...!! :rant: :facepalm:
    Deet likes this.
  11. Nov 18, 2017 at 4:36 PM
    #4271
    Taco351
    Robert
    NLR/Sherwood
    What did you buy?
  12. Nov 18, 2017 at 5:29 PM
    #4272
    rz2mbc
    2017 GMC Canyon Denali. Runs circles around the Gen 3 Tacoma.
  13. Nov 20, 2017 at 2:04 PM
    #4273
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
    I dunno... Seems like you're missing us already. I mean, you did come back at least long enough to troll this thread... :boink:
    NJtaco421, remgu2000, over60 and 2 others like this.
  14. Nov 21, 2017 at 1:25 PM
    #4274
    Taco351
    Robert
    NLR/Sherwood
    Update on my rear diff. First, I didn't realize the recall was not on Off-road or Pro versions because they have a larger rear end. I contacted my dealer yesterday, spoke to a service advisor and sent them a pic of my rear differential. I had an appointment for tomorrow. He called and said not to come and that they were ordering a new updated gasket. He also said most of the trucks that are having problems we're over torqued at the factory. So, I wait for the part to come in and they are giving me a loaner. So far I'm really happy with this process. He also said the part was only available on manual allocation. Meaning it had to be special ordered from the dealership.
  15. Nov 21, 2017 at 3:51 PM
    #4275
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Just had mine done, was told the howl is normal. I have an appointment at a differenial/transmission shop locally to get a second opinion.
    nDub likes this.
  16. Nov 21, 2017 at 5:49 PM
    #4276
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Keep us updated!
  17. Nov 21, 2017 at 7:01 PM
    #4277
    Mstinson15
    Mstinson15 Member
    On order
    My dealer in Oklahoma told me they have zero issues with diffs because their trucks all come from the same place and they don't see any issues or have serviced any recalls. I was asking them about it before I ordered my 2018. Seems like BS to me. I wonder if the 18s will be any better off at all.
  18. Nov 21, 2017 at 7:03 PM
    #4278
    Goldstar34
    Goldstar34 Well-Known Member
    2016 Tacoma Extended Cab Inferno
    Bakflip. Redback Spider Gear shift knob
    Did they tell you which plant your's came from? Mine was from Texas and it was held up for three months.
  19. Nov 21, 2017 at 7:07 PM
    #4279
    Dirtridercrf250
    Don't buy one you'll have the same issues
  20. Nov 21, 2017 at 7:20 PM
    #4280
    Mstinson15
    Mstinson15 Member
    On order
    They told me San Antonio I think with a arrival date to Houston on 5 December. Should be here in OK around Dec 10th
