Toyota recalling 228,000 Tacoma's due to oil leaks and possible loss of control of vehicle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1ChrisRuck, Apr 27, 2017.
  1. Jun 2, 2019 at 7:48 PM
    #4381
    BeardedBrother
    BeardedBrother Active Member
    2017 Tacoma TRDOR 4x4 DCLB Quicksand
    I bought my Tacoma in Nov. 2016 ('17 model). The VIN wasn't included in the the recall, but it was weeping. The dealer replaced the gasket in October 2017. I crawled under today to check it and noticed it is weeping again and quite a bit worse than the first time I saw it before it was repaired. Calling the dealer tomorrow. I am at 33k, so still within the warranty period and hope they will repair. Although, I am beginning to be concerned about this being an ongoing issue that isn't actually being repaired for good.
  2. Jun 3, 2019 at 12:32 PM
    #4382
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Forgot to update: This time around, dealer said that Toyota wouldn't consider mine a leak. They said it would be covered under the powertrain warranty so don't worry. They just cleaned it up and inspect it at the next service. If the marks show back up they'll replace the gasket and add some sealant to the paper gasket.
  3. Apr 1, 2022 at 12:25 AM
    #4383
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    They should just forget the paper gasket and use some Permatex High-Temp Red RTV Silicone Gasket Maker. That will definitely fix it.
  4. Apr 1, 2022 at 3:37 PM
    #4384
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    Reply: No problems OP...you will find there are a lot of great members on Tacoma World who have a wealth of information and can be very helpful. But, you have that select few of d***heads who will get pleasure in "trying" to make you look stupid like post #5.
    JJ Diablo likes this.
  5. Apr 1, 2022 at 5:56 PM
    #4385
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yea, that’s 5 years old bud. The OP hasn’t even logged in in a year and a half. Let it ride
    nDub and 98tacoma27 like this.
  6. Sep 28, 2022 at 3:39 PM
    #4386
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    Well that explains the leaking.
    Been bouncing all over the forum looking for patters and most of the fixes involve re-tightening the bolts > new seal with some speculating as to the breather being apart of the issue.
    Some say 18ft lbs and others say 28ft lbs for the bolts.
    Everyone trouble-shooting the issue should of course clean the area well so if the leak persists you can track it.
    But yeah...paper gasket...I just dont see that working well based on comments I've heard from Toyota Master Diag techs.
